Problem with PIC161519 / XC8
Results 1 to 5 of 5
    Apr 2016
    Default Problem with PIC161519 / XC8
    Hi every one,
    First, please excuse my bad english (I'm from France).
    I'm a beginner on MPLAB X IDE 3.26 and I would like to make a little program allowing to light a LED PORT B0 but I get errors that I do not understand. Here is my program named TextXC8 :
    TestXC8.h :
    * File: TestXC8.h
    * Author: dymentional
    * Created on April 25, 2016, 1:53 PM
    // PIC16F1519 Configuration Bit Settings
    // 'C' source line config statements
    #include <xc.h>
    #include <xc.inc>
    #include "xc8debug.h"
    #include "TestXC8.h"
    // #pragma config statements should precede project file includes.
    // Use project enums instead of #define for ON and OFF.
    // CONFIG1
    #pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
    #pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
    #pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
    #pragma config MCLRE = OFF // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
    #pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
    #pragma config BOREN = OFF // Brown-out Reset Enable (Brown-out Reset disabled)
    #pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
    #pragma config IESO = ON // Internal/External Switchover (Internal/External Switchover mode is enabled)
    #pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
    // CONFIG2
    #pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
    #pragma config VCAPEN = OFF // Voltage Regulator Capacitor Enable bit (VCAP pin function disabled)
    #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
    #pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
    #pragma config LPBOR = OFF // Low-Power Brown Out Reset (Low-Power BOR is disabled)
    #pragma config LVP = ON // Low-Voltage Programming Enable (Low-voltage programming enabled)
    #define _XTAL_FREQ 8000000
    TestXC8.c :
    * File: TestXC8.c
    * Author: Dymentional
    * Created on April 25, 2016, 2:11 PM
    #include <xc.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <pic16f1519.h>
    #include <htc.h>
    #define led1 PORTB.F0 //RB0
    int main(int argc, char** argv) {
    OSCCON = 0x72; //Configure le registre OSCCON en oscillateur interne
    PORTB = 0b11111111; //Init des pattes du µcontroleur
    TRISB = 0b11111110; //Bit 0 du Port B en sortie
    /*while (1)
    LATBbits.LATB0 = ~LATBbits.LATB0; //crée une boucle de 1s
    for (int countDelay=0; countDelay <20; countDelay ++)__delay_ms(50);
    }*/he
    while(1)n I
    //Delay ~1 second (8MHz Internal Clock)
    __delay_ms(8000000); //specify clock cycles directly
    And when I build the project :
    CLEAN SUCCESSFUL (total time: 302ms)
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory '/home/colin/microchip/colin/TestXC8.X'
    make -f nbproject/Makefile-default.mk dist/default/production/TestXC8.X.production.hex
    make[2]: Entering directory '/home/colin/microchip/colin/TestXC8.X'
    "/opt/microchip/xc8/v1.37/bin/xc8" --pass1 --chip=16F1519 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=std -P -N255 --warn=-3 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/TestXC8.p1 TestXC8.c
    make[2]: *** [build/default/production/TestXC8.p1] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    TestXC8.c:39: error: (192) undefined identifier "_XTAL_FREQ"
    (908) exit status = 1
    nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/TestXC8.p1' failed
    make[2]: Leaving directory '/home/colin/microchip/colin/TestXC8.X'
    nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
    make[1]: Leaving directory '/home/colin/microchip/colin/TestXC8.X'
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    BUILD FAILED (exit value 2, total time: 1s)
    What can I do ?
    Thank you very much !
    Dymentional
    Default Re: Problem with PIC161519 / XC8
    This looks like C.
    This is a Pic BASIC Pro forum.
    This is not a "C" forum. However there are some people here with "C" background... I am not one of them...
    EN82fn
    i'm a bit rusty on xc8 and as dave says this is a pbp forum not C
    but for what its worth
     * File: TestXC8.c
     #include <xc.h>
     #include <stdio.h>
     #include <stdlib.h>
     #include <pic16f1519.h>  not sure this is going to help , if project set up correctly in mplabx this is unnecessary
     #include <htc.h>
    #include <TestXC8.h> // will help
     #define led1 PORTB.F0 //RB0   ?????????????????
     /*while (1)
     }*/he
     while(1)n I
     __delay_ms(8000000); //specify clock cycles directly   no way
    // delay_ms is delay milliseconds not clockcycles
    // the function prototype uses ints  which limits range to much less than 8000000,from memory  its less than 1000 ms depending on clock }
    Oct 2014
    Lagos Nigeria
    Hi Dymentional, as has already been stated this might not be the right place but being familiar with xc8; I think you need to place the following
    #define _XTAL_FREQ 8000000 // OSC FREQUENCY IN Hz
    at the top of the code. Then
    __delay_ms(1000) // DELAY FOR 1 SECOND
  1. Replies: 8
    Last Post: - 11th November 2004, 20:08
