18F4550 issue with simple program.
Results 1 to 12 of 12
    Feb 2004
    Michigan, USA
    Default 18F4550 issue with simple program.
    I'm having a problem getting a really simple program to run on an 18F4550. It just a couple of blinky LED's to verify the PIC is alive. I can program it fine and read back from the device but cannot get this program to work.
    I'm running this on a 20mhz resonator using HS+PLL with PLL/5. MCLR is disabled, low voltage programming disabled. What am I missing?!
    Define OSC 48
    Define ADC_BITS 10 ' Set number of bits in result
    adval var word ' Create adval to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10001111 ' Set PORTA analog and right justify result
    TRISB = %00000000
    TRISC = %00000000
    RCSTA.7 = 0
    loop1:
    Portc.6 = 1
    Portc.7 = 1
    pause 200
    portc.6 = 0
    portc.7 = 0
    pause 200
    goto loop1
    Oct 2009
    Default Re: 18F4550 issue with simple program.
    deleted after posting
    you might need another read of the hardware manual for a 18F4550
    ADCON1 = %10001111 ' Set PORTA analog and right justify result ?????????????
    sets all analogue pins digital
    you need
    ADCON1 = %00001010 'Set PORTA analog
    ADCON2.7=1 ' right justify result
    ps
    where does this bogus line come from
    it comes up repeatedly
    Feb 2004
    Michigan, USA
    Yes you're right. I hadnt changed the comment but the setting is correct for what I need. Still, It is not running. I've noticed that the code is being loaded into the end of the program space and not the beginning. Is this an issue and how do I resolve it if it is?
    I'm using PBP 2.60A, MCS 3.0.0.5 and MPLAB 8.20A
    Jul 2009
    Ohio, USA
    Is MCLR tied high?
    Oct 2009
    Not sure if this helps, but this is a section of code that uses an 18f4580, with four pots on port A
    ; config settings 18F2550/4550/18F4580, 20mhz crystal
      __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 48
    ADCON1 = $0F
    clear
    DEFINE ADC_BITS 10                              ' Set-up ADC for fastest 10-bit results
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 5
    INCLUDE "DT_Analog.pbp"
    MaxSetPoint  CON 500                            ' Pot fully clockwise - gives max setting 50 degrees
    MinSetPoint  CON 100                            ' Pot fully counter clockwise - sets min setting 10 degrees
    ADbits = 14                                     ' set A/D resolution to 14-bits
    CMCON = 7                                       ' disable Comparators
    ADCON1 = %00001011                              ' sets up Analogue pins
    ADCON2.7 = 1                                    ' ADFM bit isn't in ADCON1 anymore
    ;----[Port settings]----------------------------------------------------
    TRISA = %11001111
    It uses DT's analogue include file, which might be worth downloading and including in your own code
    Feb 2004
    Michigan, USA
    Quote Originally Posted by Mike2545 View Post
    Is MCLR tied high?
    No. Does the PicKit 3 programmer hold it high or low when powering the target board?
    I do have it disabled in the config bits.
    Jul 2009
    Ohio, USA
    Not sure what the Pickit3 does, I know the MCLR pin needs to be held high (~10K resistor) to run the processor...give that a try
    Feb 2004
    Michigan, USA
    Turns out this was a MPASM issue. Once I had that resolved the program worked.
    Feb 2004
    Michigan, USA
    I cant seem to get some of the ADC readings to write to EEPROM. Channels 0 and 1 work perfectly the others write anything. Any idea whats going on? I think all the ports are set correctly.
    Define OSC 48
    adval1 var word
    adval2 var word ' Create adval to store result
    adval3 var word
    adval4 var word ' Create adval to store result
    adval5 var word
    ADCON1 = %00000000 ' Set PORTA analog and right justify result
    ADCON2.7=1
    TRISB = %00011111
    TRISC = %00000000
    TRISE = %00001111
    RCSTA.7 = 0
    loop1:
    ADCIN 0, adval
    pause 1
    write 0, adval
    adcin 1, adval1
    pause 1
    write 1, adval1
    adcin 2, adval2
    pause 1
    write 2, adval2
    adcin 3, adval3
    pause 1
    write 3, adval3
    adcin 4, adval4
    pause 1
    write 4, adval4
    adcin 5, adval5
    pause 1
    write 5, adval5
    SEROUT PortC.6,2,[adval, adval1, adval2, 10]
    portc.6 = 0
    portc.7 = 0
    pause 200
    goto loop1
    adval1 var word
    adval3 var word
    adval5 var word
    pause 1
    write 0, adval
    adcin 1, adval1
    pause 1
    write 1, adval1
    how many bytes in a word ?
    Jmgelba, you need to index the memory pointer by 2 for it to store a word or, something like this:
    write 1, adval1.lowbyte
    write 2, adval1.highbyte
    then you can read them back by using:
    READ 1,value to read the entire word.
    EN82fn
  1. USB issue - 18F4550
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 20th February 2013, 20:49
  2. 18F4550 issue
    Last Post: - 4th February 2013, 06:27
  3. Simple LED driving issue - setup?
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th March 2011, 01:54
  4. Code issue with a flashing light(simple question)
    By IAmTheAnswer in forum mel PIC BASIC Pro
    Last Post: - 8th May 2010, 11:46
  5. Simple 4 line LCD display with 18F4550
    By pic-ker in forum Code Examples
    Last Post: - 9th April 2007, 02:58
