Help with GOSUB
Results 1 to 17 of 17
Thread: Help with GOSUB
Threaded View
    Jul 2015
    Default Help with GOSUB
    Hi. First time post here. I'm using PIC Basic Pro, MPLAB ASSEM and a PIC16F870.
    Need some help with the GOSUB in my code.
    I'm telling a Compact Flash card that I want to read 256 sectors and then pulse
    RD low 65535 times to get the 16Bit data out. I do this 4 times because the whole
    file is 4 x 256 sectors.
    If I put the little REPEAT...UNTIL code after each call up of 256 sectors, the program
    works fine. I can push the start button as many time as I need for the whole file
    to be read from the compact flash card.
    If I use a GOSUB dat to go to the little dat: REPEAT...UNTIL RETURN pulse RD low routine,
    the program
    will only work about 4-5 times and then vapour locks. The RD pin keeps running
    (pulsing low) and doesn't stop after 65535 pluses. The code doesn't recover.
    Any ideas?
  1. gosub - return
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 11th August 2010, 10:21
  2. On...gosub
    By circuitpro in forum PBP Wish List
    Last Post: - 7th December 2009, 21:40
  3. If ... Then Gosub <> If ... Then Goto?
    By oldtoddler in forum General
    Last Post: - 27th February 2006, 11:52
  4. gosub and if-then working together?
    By bartman in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2005, 13:54
  5. GoSub Problem
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 11th May 2004, 15:15
