A tft addin for pbp3 - Page 4
Page 4 of 4 FirstFirst 1234
Results 121 to 142 of 142
  1. #121
    Default Re: A tft addin for pbp3
    having an issue here with a usercmd macro overwriting an array boundary and I'm at a loss to understand what I'm doing wrong ,
    attached is a safer version of the touch screen addin.
    problem is , lets say I have defined number_of_buttons con 9
    vars are defined by button_Taddr VAR byte[number_of_buttons*3]
    by my count that's 27 bytes
    I usercmd a button the nineth button
    MAKEBUTTON 34,216,8,40
    in the macro k=Button*3 which should be 24
    so
    movlw 0
    movwf _button_Taddr +k
    movwf _button_Taddr +k+1
    movwf _button_Taddr +k+2
    should place 0 into button_Taddr[24-26]
    but something else gets clobbered instead , buttons 0-7 seem ok but I might be wrong
    MAKEBUTTON?CCCC  macro X0in ,Y0in ,Button ,Szin     ;sqr button no text
    k=Button*3   ;
    j=Button*2    ;1 WORD  PER BUTTON
    i=Button*6    ;3 WORDS PER BUTTON
        if Button <8
        bcf _button_action ,Button
        bcf _button_rpt ,Button
        bcf _button_set ,Button
        bcf _button_action+1 ,Button-8
        bcf _button_rpt+1 ,Button-8
        bcf _button_set+1 ,Button-8
        MOVE?CW  Szin ,_button_xsize+ j
        MOVE?CW  Szin ,_button_ysize+ j
        MOVE?CB  0  , _BUTTON_STATE + Button
    ;    movlw   0
    ;    movwf   _button_Taddr +k
    ;    movwf   _button_Taddr +k+1
    ;    movwf   _button_Taddr +k+2
        MOVE?CW  0  ,button_count +i
        MOVE?CW  X0in ,button_X  +i
        MOVE?CW  Y0in ,button_Y  +i
        MOVE?CW  0, _button_Tsize +  j
    CHK?RP , Banksel it gets me every time
  3. #123
    FIXED again
    Oct 2009
    Richard, Seems you've done some fantastic work on using TFT's with PBP.
    I have a 2.8" display of the same resolution, but I'm running PBP 2.60c which lacks the usercommand function. Is there any chance you could advise / produce a library that works with version 2.60 ?
  5. #125
    I won't speak for Richard but I'd take this as the opportunity you've been looking for to finally justify the upgrade PBP3 - you've now found a feature it has that you want/need ;-)
    I won't say its impossible but
    lets take one simple usercmd
    GLCDSTR 2,2,buff
    macro called is
    GLCDSTR?CCB macro Xin ,Yin ,Bin
    MOVE?CW Xin , _X
    MOVE?CW Yin ,_Y
    MOVE?CB high Bin, FSR1H ;load highbyte
    MOVE?CB low Bin, FSR1L ;load low byte
    L?CALL tft_str_out
    translation to pbp2.6
    X=2
    Y=2
    @ MOVE?CB high _buff, FSR1H ;load highbyte
    @ MOVE?CB low _buff, FSR1L ;load low byte
    call tft_str_out
    not too difficult but its messy and could get very ugly very quickly , as henrik says an upgrade looks good
  7. #127
    Oct 2009
    Would love to upgrade, but being a casual user, and between jobs, upgrading is simply not an option for me at the monemt
  8. #128
    Just found this thread! I like idea very much, and I'd like to contribute, but my programming skills aren't that good. However, I'm way better on graphics, so I can create better looking fonts with chars of different dimensions. Just point me to font file so I can have look how it is organized.
  9. #129
    the fonts are really 8x8 fronts but the alpha/numeric char only use 7x8 with the last bit always o (for chr spacing)
    there are two fonts in this thread the first is chr 32-90 and the second chr 32-127. I have a extended font (attached) that has
    a radio button arrows ,play,stop,pause,speaker on/off symbols ,these use the full 8x8
    this is the routine to display font chars
    g
    cga:
        g_fontoffset = (g_chr-font_begin)*8   +  fontaddr
        if   (x+textsize*7) > width  then return
        if   (y+textsize*8) > height  then return
        if      (g_chr <font_begin) ||  (g_chr >font_end )   then return
        for ROW=0 to 7    ;font height   this would need to be a var set to font height size
            readcode g_fontoffset +ROW,ctemp  ;this would need to be able to "unpack" different font with bits
            for PIXEL=0 to 7   ;font width ; font width var req here too
                X1= X+PIXEL
                X0=X1
                Y0=Y+7-ROW
                Y1=Y0
                IF   TEXTSIZE  ==1 THEN
                    GOSUB SETWINDOW
                    if ctemp.0[PIXEL]  then
                          ;SETPIXEL X+PIXEL,Y+7-ROW ,FG
                          TFT_CMD_IN= FG>>8
                          GOSUB TFT_DATA
                          TFT_CMD_IN= FG
                          GOSUB TFT_DATA
                          ;SETPIXEL X+PIXEL,Y+7-ROW ,BG
                          TFT_CMD_IN= BG>>8
                          GOSUB TFT_DATA
                          TFT_CMD_IN= BG
                          GOSUB TFT_DATA
                    X0=X+PIXEL*TEXTSIZE
                    Y0=Y+( 7-ROW )*TEXTSIZE
                    X1= TEXTSIZE
                    Y1= TEXTSIZE
                         FrG=fg
                         GOSUB frectc
                         FrG=BG
                         GOSUB frectc
            NEXT
        next
        x=x+textsize*7       ;auto increment x for str function ;  and font width here too
    the arduino utft code can handle variable width fonts by storing a second table along with the font . that table records the h/w of every chr in the font and ascii val of the first and last chr in the font too.
    its pretty straight forward but not trivial task to change the pgm to do that ; however all the text box code for buttons etc would need to be altered too
    Oct 2013
    I create a six buttons on LCD and one button must work like a push button.
    When I push the button, the LED which is connected to PORTD.0 must light all the time as the button is pressed.
    When I release the button LED must go off.
    Is it possible to create something like that?
  11. #131
    when a repeat enabled button is "held" it returns a BUTTON_STATE of 5
    this can be the led "on" cue
    when the button is "released" it returns a BUTTON_STATE of < 5 (1 or 2 )
    this can be the led "off" cue
    LOP:
        GOSUB  CK_BUTTON
        IF      BUTTON_STATE[0]   THEN
           IF      BUTTON_STATE[0] >4 then
               PORTD.0=1
               PORTD.0=0
               BUTTON_STATE[0]=0
    goto lop
  12. #132
    Oct 2013
    when I press a button and hold it the led diode is on.That is OK.when I release a button led is off.
    Is it possible to make that when the button is pressed and hold, led is on, and when I connect 5V to pin PORTD.7 then led is off.
    I dont now how to explain a problem.
    When I press a button window is opening and when it is full open then he must stop .Stop signal is connect to PORTD.7
    '-----------------------OPEN WINDOW ------------------------------------------------------
    IF BUTTON_STATE[2] THEN
    IF BUTTON_STATE[2] >4 then
    PORTD.0=1
    PORTD.0=0
    BUTTON_STATE[2]=0
    you could do this but ..............
    a big if
    is the portd.7 signal is a limit switch or an emergency stop switch ?... if it is then its best done in hardware a hung loop here could cause fire/smoke/damage or hurt
    if PORTD.7 ==0 then
    PORTD.0=1
    PORTD.0=0
    PORTD.0=0
    BUTTON_STATE[2]=0
    Oct 2013
    the portd.7 signal is a limit switch for max position of open window.He must disable opening,but if something goes wrong I will put a second hardware switch to disable motor.
    On test board this routine works good.
  15. #135
    Oct 2013
    I am stuck with serin2 and serout2 comands.
    I use PIC18F252 for reading sensor.
    BMP085 for temperature and pressure
    DS3231 for time and date
    BH1750 for light intensity
    DHT11 for humidity
    All this values I have on 2x16 LCD and it work perfect.
    pressure and temperature showing on lcd like this
    'DISPLAY true temperature in C
    lCTemp = (B5 + 8) / 16 'Hey presto, lCTemp appears...
    INTEMP = lCTemp / 10 'find value above decimal point
    INTEMPOSTATAK = lCTemp // 10 'Find decimal value
    LCDOut $fe,$c0+12, DEC2 INTEMP, ".", DEC2 INTEMPOSTATAK
    'DISPLAY true pressure in hPa
    lPres = lPres + (X1 + X2 + 3791) / 16 'lPres is the true pressure in Pa
    X1 = lPres / 100+16
    PRITISAK = X1 'find value above decimal point
    PRITISAKOSTATAK = lPres // 100 'find value below decimal point
    LCDOut $fe,$80+9 , DEC PRITISAK, "." ,DEC2 PRITISAKOSTATAK
    Now I want to send all this values to TFT lcd with SEROUT2/SERIN2 commands
    Transminter:
    B2400 Con 16780
    lPres var long
    lCTemp var long
    Sec VAR word
    Mins VAR word
    hr VAR word
    date VAR WORD
    mon VAR WORD
    yr VAR WORD
    PRITISAK VAR WORD
    INTEMP VAR WORD
    DHT_Humidity var word
    lux var word
    Serout2 PortC.7,B2400,["#OK",HR,MINS,SEC,DATE,MON,YR,INTEMP, PRITISAK,DHT_HUMIDITY,LUX]
    On receiver side i have this:
    create two buttons and write receive info on screen
    B240 Con 16780
    cnt var WORD
    HR var WORD
    MINS var WORD
    SEC var WORD
    DATE var WORD
    MON var WORD
    YR var WORD
    LCTEMP var WORD
    LPRES var WORD
    DHT_HUMIDITY var WORD
    LUX var WORD
    buff var byte[32]
    LOP2:
    GOSUB CK_BUTTON
    '*******SET BUTTON FOR ADJUST TIME AND DATE******************************
    IF BUTTON_STATE[0]=1 THEN
    PAUSE 1000
    BUTTON_STATE[0]=0
    '************NEXT BUTTON GO TO NEXT SCREEN *****************************
    if BUTTON_STATE[1]=1 then
    GOTO SCREEN_1
    BUTTON_STATE[1]=0
    Serin2 PORTC.0,B2400,10,LOP2,[wait ("#OK"),HR,MINS,SEC,DATE,MON,YR,LCTEMP, LPRES,DHT_HUMIDITY,LUX]
    TEXTSIZE=2
    bg=0
    fg=$7FF
    ' LR UD
    GLCDC 10,200
    GLCDC "Time : "
    ARRAYWRITE buff,[dec2 HR,0]
    GLCDSTR 70,200,buff
    ARRAYWRITE buff,[dec2 MINS,0]
    GLCDSTR 100,200 ,buff
    ARRAYWRITE buff,[dec2 SEC,0]
    GLCDSTR 130,200 ,buff
    GLCDC 10,170
    GLCDC "Date : "
    ARRAYWRITE buff,[dec2 DATE,0]
    GLCDSTR 70,170 ,buff
    ARRAYWRITE buff,[dec2 MON,0]
    GLCDSTR 100,170 ,buff
    ARRAYWRITE buff,[dec2 YR,0]
    GLCDSTR 130,170 ,buff
    ARRAYWRITE buff,[DEC4 LCTEMP,0]
    GLCDSTR 10,100 ,BUFF
    ARRAYWRITE buff,[ DEC4 LPRES,0]
    GLCDSTR 100,100 ,BUFF
    ARRAYWRITE buff,[dec3 DHT_HUMIDITY,0]
    GLCDSTR 200,100,buff
    ARRAYWRITE buff,[dec4 LUX,0]
    GLCDSTR 270,100 ,buff
    GOTO LOP2
    Hr,mins,sec,date,mon,yr and temp are OK
    Pressure are not OK, I have on screen 0235
    Lux and humidity still not connected on transmiter side I have 0 readings
  16. #136
    Oct 2013
    I just tested a humidity sensor and his value are correct on lcd and TFT but value of lux are ok if are they below 255.
    How to send variable word size over serout2 commands,I think this is my problem.
  17. #137
    Oct 2013
    Solved,
    receive:
    Serin2 PORTC.0,B2400,10,LOP2,[wait ("#OK"),HR,MINS,SEC,DATE,MON,YR , LCTEMP.highbyte,lctemp.lowbyte , LPRES.highbyte,lpres.lowbyte ,_
    vlaga ,vlagaostatak,lux.highbyte,lux.lowbyte ]
    transmit
    Serout2 PortC.7,B2400,["#OK",HR,MINS,SEC,DATE,MON,YR,lCTemp.highbyte,lCTe mp.lowbyte, pritisak.HighByte, pritisak.LowByte,vlaga,_
    vlagaostatak,LUX.HighByte,lux.LowByte]
  18. #138
    Jun 2005
    West Australia
    Hi All,
    I'm toying with two different GLCD's, one a 1.8" 160x128 (actually 2 of these but slightly different in overall size and connector with ST7735) and a 2.4" 320x240 with ILI9341, all TFT and 3v3 supply. Using an 18f2520 for testing.
    The larger display works fine however something is awry with the smaller units when I reconfigure Richard's code for the different size and driver. Both exhibit a smaller section of the expected display and some corruption instead of crystal clear and a full screen of scaled icons. The attached photo's show the problem.
    I'm using the last versions of Richard's updates seen on this thread. I went back to the beginning but I don't have a 45k20 on hand to test if the bare bones version works.
    Any suggestions?
    Bill
  19. #139
    I am sorry that cannot help but I am amazed that your did drive the TFT displays through PIC and PicBasic! Congrats on that. Is it possible to show the code please?
    I am using Nextion to do similar things but it would be nice if an alternative could be used.
    without seeing your code it looks very much like you are writing outside the screen boundaries
    Jun 2005
    West Australia
    Hi Richard,
    Thanks for being there . Yes I think so too but don't know how to enforce the borders. I'm really interested in using Portrait mode too to make text legible in a skinny rail mounted enclosure.
    @Ioannis
    It's Richard's hard work not mine, he deserves the congrats. Below is the code configured for the ST7735 and the Includes/files are the latest I could find in the thread.
    Any help or suggestions appreciated.
    Kind regards,
    Bill
    '*  Name    : pic18f2520_tft_demo.pbp              #### semi-Working Code #### *  but not pretty, needs lots of work.
    '*  Author  : RICHAED                                                       *
    '*  Notice  : Copyright (c) 2015                                            *
    '*          : All Rights Reserved                                           *
    '*  Date    : 12/09/2015                                                    *
    '*  Device  : 18F2520 (32k)                                                 *
    '*  Version : ?     25295  bytes (PBP 3.1.4.4)                              *
    '*  Notes   : sleep, pwm brightness (10 bit pwm)                            *
    '*          : new way to define tft pins                                    *
    '*          :  24 BIT ADDRESS FOR STRINGS AND BUTTON TEXT                   *
    '*          : See: www.picbasic.co.uk/forum/showthread.php?t=20115          *
    '*  ======> : 3v3 screen! Draws ~ 80mA.                                     *
    '*          : TFT ILI9431 works okay but not pretty, needs lots of work.    *
    '*          : ST7735 (KMR-1.8" and Touch version each 128x160) work but the *
    '*          : code needs fix - only 1/4 of TFT size screen shown instead of *
    '*          : a reduced scale version to fit into 128x160 frame.            *
    '*          : #### How to put into Portrait mode? ####                      *
    ; 07Feb22 Huge trawling exercise to sort the many variations of this evolution on the Forum.
    ;         Includes are the last/latest versions found in the thread (could this be the problem?).
    ;         Testing with 2.4" 240x320 TFT is functional using ILI9431 and also ST7735 (1.8" 128x160).
    ;         Had some frustrating moments programming this, MeLabs usb changed for PicKit3 confirmed it
    ;         was the problem, using Test 18f2520.pbp code also proved it.
      CONFIG  OSC = INTIO67
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRT = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 3
      CONFIG  WDT = OFF
      CONFIG  WDTPS = 512
      CONFIG  CCP2MX = PORTC
      CONFIG  PBADEN = OFF
      CONFIG  LPT1OSC = OFF
      CONFIG  MCLRE = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    ; TFT in landscape has conn LHS, KMR RHS, 1.8 Touch RHS
    ; TFT in portrait has conn ?, KMR ?, 1.8 Touch ?
    ;                                               Led- Gnd    2x8 pin hdr
    '    PIC(18F2520)           OTHER               KMR-1.8"    1.8" Touch
    ' MCLR PortE.3 (pin 1)      Pull High 10k.
    ' C1-  PortA.0 (pin 2)
    '      PortA.1 (pin 3)
    ' C1+  PortA.2 (pin 4)
    '      PortA.3 (pin 5)
    ' C1OP PortA.4 (pin 6)      T_DIN Pin TFT.      nc
    '      PortA.5 (pin 7)
    '      Ground  (pin 8)
    '      PortA.7 (pin 9)      T_CLK Pin TFT.
    '      PortA.6 (pin 10)     T_DO Pin TFT.                   not tested XPT2046 chip
    '      PortC.0 (pin 11)
    ' CCP2 PortC.1 (pin 12)     9600 True via 1k.
    ' CCP1 PortC.2 (pin 13)     BL drive-1k-PNP.    Led+        BLK(7) Led A already to +, rejig PNP to switch ground.
    '  SCL PortC.3 (pin 14)     SCK Pin TFT.        SCL         CLK(3)
    '  SDA PortC.4 (pin 15)
    '  SDO PortC.5 (pin 16)     SDI(MOSI)Pin TFT.   SDA         MOS(4)
    '  Tx  PortC.6 (pin 17)
    '  Rx  PortC.7 (pin 18)
    '      Ground  (pin 19)     Gnd                 Gnd         Gnd(1)
    '      +Supply (pin 20)     +3v3                +3v3        +3v3(2)
    ' INT0 PortB.0 (pin 21)     T_IRQ Pin TFT.
    '      PortB.1 (pin 22)
    '      PortB.2 (pin 23)     T_CS Pin TFT.
    '      PortB.3 (pin 24)     DC Pin TFT.         A0          DC(6)
    '      PortB.4 (pin 25)     RESET Pin TFT.      RESET       RES(5)
    ' T1G  PortB.5 (pin 26)     CS Pin TFT.         CS          CS1(9), CS2(10) works w/o either????
    ' PGD  PortB.6 (pin 27)
    ' PGC  PortB.7 (pin 28)
    DEFINE NO_CLRWDT 1
    #DEFINE TOUCH_SCREEN 1
    #DEFine  dbug 1             ; Comment if not req'd.
     ;-----------connection----------
    ;        pic                     tft
    ; <tft_port.tft_dc_bit >-------< dc   >
    ; <tft_port.tft_cs_bit >-------< cs   >
    ; <tft_port.tft_rst_bit>-------< rst  >
    ; <msspx.sdo >-----------------< mosi >
    ; <msspx.sck >-----------------< sck  >
    ; <back_light>-----------------< led  >   via pnp cct
    ;*****************NEW EASY PIN DEFINES*********************************
        tft_dc_bit  con 3       ;ie bit 3
        tft_cs_bit  con 5       ;ie bit 5
        tft_rst_bit con 4       ;ie bit 4
        tft_port   var latb
        back_light var latc.2   ; portc.2
        cont       var word     ; backlight level
    ;    WIDTH    con  320   ; X   MUST MATCH TFT MODULE
    ;    HEIGHT   con  240   ; Y
        WIDTH    con  160  ; X
        HEIGHT   con  128  ; Y
    ' my TOUCH_SCREEN connection definitions
     T_CLK    VAR   PORTa.7
     T_INPin  VAR   PORTa.4
     T_OUTPin VAR   PORTa.6
     T_INT    VAR   PORTb.0
     T_CS     VAR   LATb.2
     number_of_buttons con 6
     number_of_sliders con 1
            INCLUDE "TFT_SPI.pbpmod"        ;glcdc
    ;        include "tft-ILI9431.bas"
            include "tft-ST7735.bas"
            INCLUDE "DT_INTS-18.bas"
            INCLUDE "ReEnterPBP-18.bas"
            INCLUDE "my_Elapsed_INT-18.bas"
            include "TOUCH_TFT.PBPMOD"      ;uncomment  to use TOUCH_TFT
            INCLUDE "font7x8.bas"
     goto demostart
     upbutton:
     @ db 131,0              ; chr 131 is AN up arrow in this font THAT I'M USING
    demostart:
    INT_LIST  macro    ; IntSource,        Label,           Type,   ResetFlag?
            INT_Handler   TMR1_INT,   _ClockCount,      PBP,  yes
        INT_CREATE
    @ INT_ENABLE  TMR1_INT
        led_on var bit
        led_on_time var word
        time_now var word
        BOXX VAR  BYTE
        BOXY VAR  BYTE
        BOXZ VAR  BYTE
        cnt var byte
        clear
    '    latb=255   ;  make sure tft etc are not selected ie all cs high *************NOW IN TFT INIT********************
        TRISA=%00111111
        TRISB=%11000011
        TRISC=%11010011
        ADCON0 = 0              ' Disable A/D.
        ADCON1 = %00000110      ' All digital.
        OSCCON = %01110000 		' Internal 8 Mhz Osc
        OSCTUNE=%01000000		' PLL ON
        cont=500                ; half brightness
        DEFINE OSC 32
        buff var byte[32]
        t2con=5
        PR2 = 255;
        CCPR1L = cont>>2;             ;set pwm
        ccp1con=12|((cont&3)<<4);
        SSPCON1=$20  ;$20-21-22 works 20 IS FASTEST
        SSPSTAT=$40
        TEXTSIZE=2
        gosub tft_init
        gosub TOUCH_INIT
        GOSUB ResetTime
        GOSUB StartTimer
    '    #ifdef dbug
    '    trisb.7=0    ;DEBUG OUT
    '    latb.7=1
    '    pause 4000
    '    Serout2 PORTb.7,84,["ready ", 13,10]
    '    #ENDIF
        #ifdef dbug
        trisc.1=0    ; DEBUG OUT
    ;    latc.1=1     ; Float high for True.
        latc.1=0     ; Float low for Inverted. The Nortek white usb serial adapter used here.
        pause 4000
    ;    Serout2 PORTc.1,84,["ready True ", 13,10]
        Serout2 PORTc.1,16468,["ready Inverted ", 13,10]
        #ENDIF
        glcdc  font7x8       ;SET FONT
        bg=$ffff
        fg=0
        fillrect 0,0,WIDTH,height    ;cls
        TEXTSIZE=4
        GLCDc 50,103
        GLCDC   "READY"
        pause 400
        bg=$ffff
        fg=0
        MAKEBUTTON 53,170,0,92 ,40,"Clear" ;
        MAKEBUTTON  276,220,1,56,30,"Sleep"
        MAKEBUTTON  280,150,2,60,"Led"
        MAKEBUTTON  242,52,3,40  ; no  text  SEE BELOW   FOR Another way to attach text
        MAKEBUTTON  140,150,4,50,30," +"
        MAKEBUTTON  205,150,5,50,30," -"
        button_action.0[1]=1  ; flash text for this button
        button_action.0[2]=1  ; flash text for this button
        button_rpt.0[4]=1    ;   auto rpt on button 4
        button_rpt.0[5]=1    ;   auto rpt on button 5
        ;another way to attach text to a button   [HANDY FOR CHRS NOT IN ASCII 7 BIT PRINTABLE RANGE] EG THERE IS NO OTHER WAY TO GET CHR 131 IN A PBP STRING
    @ GetAddress21 _upbutton ,_tft_bigaddress  ;macro in dt_ints-18
        button_Taddr[3*3]  = tft_bigaddress[2]
        button_Taddr[3*3+1]= tft_bigaddress[1]  ;assign a new text to button 3
        button_Taddr[3*3+2]= tft_bigaddress[0]
        button_Tsize[3] =1  ;UPDATE  NUMBER OF text CHRS for this button
        MAKESLIDER 100,80,0
        slider_index  =0
        the_slider = slider_index *SL_SZ  ; set slider indexing properly
        slider_FG[the_slider ]=$ffe0    ;set slider bar colour if default not desired
        slider_count[the_slider]=cont/10
        bg=0
        INTCON2.6=0
        led_on=0
        fg=$7FF
        DRAWBUTTON  0
        DRAWBUTTON  1
        DRAWBUTTON  2
        DRAWBUTTON  3
        DRAWBUTTON  4
        DRAWBUTTON  5
        slider_index  =0
        slider_MODE[the_slider]=0    ;FORCE DRAW OF SLIDER
        DRAWSLIDER  0
        fg=$ffFF
         DRAWcircle  60 , 60 , 20
         fillcircle  60 , 60 , 20
    LOP:
        GOSUB  CK_BUTTON
        IF      BUTTON_STATE[0]==2   THEN
            BUTTON_STATE[0]=0
            fg=0
        elseIF      BUTTON_STATE[1]    THEN
            if BUTTON_STATE[1]==2 then     ; shut it all down
                gosub tft_sleep
                 ccp1con=0
                 back_light=1
                 intcon=$10
                 @ sleep
                 @ nop
                 intcon=$c0
                 gosub tft_wake
                 CCPR1L = cont>>2;
              BUTTON_STATE[1]=0
        elseIF  BUTTON_STATE[2]     THEN   ;short or long press
                drawimage 220,30,45,45,led
                led_on=1
                gosub get_now
                led_on_time=time_now
                BUTTON_STATE[2]=0
        elseIF  BUTTON_STATE[3]     THEN
                if BUTTON_STATE[3]==2 then
                    DRAWBUTTON  3
                 fg=0
                fillrect 220,30,45,45
               drawimage 220,30,45,45,led2
                BUTTON_STATE[3]=0
        elseIF  BUTTON_STATE[4]    THEN   ; short , long press  or RPT
                CNT=CNT+1
                 BUTTON_STATE[4]=0
                 gosub s_cont
        elseIF  BUTTON_STATE[5]     THEN   ; short , long press or RPT
                 CNT=CNT-1
                  BUTTON_STATE[5]=0
                  gosub s_cont
        slider_index  =0
        IF   slider_MODE[the_slider]&1 THEN         ; adjust brightness
            gosub set_cont
        if led_on then
            gosub get_now
            if abs(time_now-led_on_time) > 100 then
             DRAWBUTTON  3
            fg=0
    '        fillrect 220,30,45,45
    '       drawimage 220,30,45,45,led2
             led_on=0
        if    SecondsChanged  then
            fg=$F800
            bg=$ffff
            SecondsChanged=0
            TEXTSIZE=2
            BOXX=6*7*TEXTSIZE
            BOXY=HEIGHT-(TEXTSIZE*8+1)
            ARRAYWRITE buff,[dec2 seconds,0]
            GLCDSTR BOXX,BOXY ,buff
        if    hoursChanged  then
            hoursChanged=0
            TEXTSIZE=2
            ARRAYWRITE buff,[dec2 hours,0]
            GLCDSTR 1,BOXY ,buff
        if    minutesChanged  then
            TEXTSIZE=2
            minutesChanged=0
            BOXX=3*7*TEXTSIZE
            ARRAYWRITE buff,[dec2 minutes,0]
            GLCDSTR BOXX,BOXY,buff
     goto LOP
     set_cont:
            cont = 1000 - slider_COUNT[0]*10
            CCPR1L = cont>>2;
            slider_MODE[the_slider]=slider_MODE[the_slider]&$FE
            cnt=  slider_COUNT[the_slider]
       s_cont:
            TEXTSIZE=3
            bg=0
            fg=$7FF
            ARRAYWRITE buff,[dec3 cnt,0]
            GLCDSTR 50,10 ,buff
     get_now :
    @ INT_DISABLE  TMR1_INT    ;disable int to get  value of ticks WITHOUT ROLLOVER ISSUES   [TICKS IS NOT ATOMIC]
     time_now=ticks           ; 1 tick==10mS
       #ifdef dbug
    db_prn:
    intcon.7=0
        Serout2 PORTb.7,84,["t ",#TU_TMP3 , 13,10]
    intcon.7=1
        #ENDIF
    INCLUDE "led2.bas"
    INCLUDE "led.bas"
  22. #142
    most of the addin's have user-commands. in the include file where the commands are declared there are comments on how to use them
    eg in touch_tft
    ;work around fact that  usercommand won't accept a 1 chr string (thinks its a const)  so leading space is ignored  in button title
        USERCOMMAND "DRAWBUTTON"    ; BTN    { BUTTON NUMBER }
        USERCOMMAND "MAKEBUTTON"    ; X,Y ,BTN,{w},{h} ,"title" [(XY IS button centre)  BUTTON  number  ,   BUTTON size  WILL BE default_button_size IF SIZE OMITTED h=w if h omitted]
        USERCOMMAND "DRAWSLIDER"    ; SLIDER    { SLIDER NUMBER  }
        USERCOMMAND "MAKESLIDER"    ; X,Y {W,H},SLIDER   [(XY IS LHBottom CNR ) SLIDER number    size  WILL BE default  IF W,H OMITTED
    x, y are cartesian coordinates for the screen position of the desired object , it goes without saying that x is horizontal axis [width] y vertical axis [height] when facing screen. both x and y need to be on the screen, objects can also have a width [w] and a height [h] and it follows that
    x+w should still be on the screen as well as with y+h
    if your objects don't fit on the screen then things won't play nice
    start here
    which of these fit on a screen 160x128 ?
    answer none
    and so on
    in chipset driver file you will find this
         ;SCREEN ORIENTATION
        TFTDATA $18       ;bit3 controls rgb/bgr  0=bgr , 1 =rgb
                          ;bit2 controls  refresh direction  long  axis
                          ;bit4 controls  refresh direction   short  axis
                          ;bit5 controls portrait/landscape   1=portrait , 0 =landscape  / adjust height width to suit
                          ;bit6 controls  write direction short axis
                          ;bit7 controls  write direction long  axis
    it needs to be setup to match your screen re-orientation and mirror imaging, its no big deal
    you need to set height/width declares to match
  1. Replies: 0
    Last Post: - 25th September 2013, 18:33
  2. code examples / libraries for ILI9320 2.8" TFT LCD Module
    Last Post: - 6th June 2013, 08:50
  3. I really need some help with PBP3
    Last Post: - 26th February 2012, 16:05
  4. What's with PBP3?
    Last Post: - 10th August 2011, 17:09
  5. Experience of driving TFT screens?
    By isaac in forum General
    Last Post: - 26th September 2008, 00:15
Members who have read this thread : 7
