Pic 18f Usb - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 135
Thread: Pic 18f Usb
  1. #41
    Quote Originally Posted by Tissy
    Is the USB loader so you can bootload the PIC over USB with a new firmware?
    Quote Originally Posted by Bruce
    Yes. It's the same USB boot-loader provided with the Microchip full speed PIC USB demo board.
    I wasn't planning on using In Circuit Serial Programming at first, but if we can include a user-friendly firmware upgrade feature then that changes everything.
  2. #42
    Ok, this is strange. I've downloaded the files from Microchip:
    http://www.microchip.com/stellent/id...&part=DM163025
    And these 3 files all install the same thing; MICROCHIP USB FRAMEWORK SOFTWARE:
    - USB_Bootloader_Setup.EXE
    - MCHPFSUSB_Setup
    - HID_Setup.EXE
    Do I have some sort of cookie problem going on? I've had something similar once with an old unzip program and was wondering if I was seeing straight.
  3. #43
    Feb 2005
    Essex, UK
    OK. I haven't got the USB Demo board, i just use the 18F2550 and 18F4550.
    I will have to look at this, because the device i am designing is a USB device. So it would be good to be able to flash it for an upgrade using this facility over USB without worrying about other IcSP connections etc.
  4. #44
    Unhappy helpme please...
    Hi Everybody...
    there is a schematic for Bruce's example...?
    Sorry but my english is not good....!
    Regards...!
    GIO
    Greetings from ECUADOR...!!!
  5. #45
    Hi:
    Can anybody helpme whit a elemental example....? Im usin EasyHID, PIC 18F4550, VB and PBP... thanx.
    Lamento no poderme expresar bien en ingles, pero para alguien que me entienda, le estaria agradecido si me pudiera guiar con un ejemplo sencillo para un PIC 18F4550 con PBP VB y easyHID...
    Gracias...!
  6. #46
    Sep 2006
    Mexico
    Hello, i have a problem with usb. Here is the code:
    PBP code:
    DEFINE LOADER_USED 1 ' Using Mecanique 18f4550 loader
    DEFINE OSC 20
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_CLOCK 3 ' Set clock source /32
    BufferSize con 8
    DataBuffer Var Byte(BufferSize) ' data buffer
    DataBufferCount Var Byte ' buffer size
    Quanta con 1251
    ' Variables
    X VAR byte
    Adval VAR WORD
    TRISA.0 = 1 ' RA0 input
    ADCON1 = %00001110 ' A/D channel 0
    ADCON2 = %10000011 ' Left justify for 10-bit
    USBInit
    ADCIN 0,adval ' Read A/D channel 0 into ADval variable
    ADval = ADval */ Quanta ' Quanta result
    ' Load data buffer
    DataBuffer(0) = Adval dig 3 'Y.LowByte
    DataBuffer(1) = "."
    dATAbUFFER(2) = Adval DIG 2
    DataBuffer(3) = Adval DIG 1
    DataBuffer(4) = aDVAL DIG 0
    gosub DoUSBOut
    for X = 0 to 99 ' Short delay between updates
    pausEUS 1000
    USBSERVICE ' Maintain HID connection during delay period
    NEXT X
    goto Main
    ' USB in...
    DoUSBIn:
    DataBufferCount = BufferSize
    USBService
    USBIn 1, DataBuffer, DataBufferCount, DoUSBIn
    ' USB out...
    DoUSBOut:
    USBService
    USBOut 1, DataBuffer, DataBufferCount, DoUSBOut
    VB code:
    ' vendor and product IDs
    Private Const VendorID = 6017
    Private Const ProductID = 2000
    ' read and write buffers
    Private Const BufferInSize = 8
    Private Const BufferOutSize = 8
    Dim BufferIn(0 To BufferInSize)
    Dim BufferOut(0 To BufferOutSize)
    Dim voltaje As String
    ' when the form loads, connect to the HID controller - pass
    ' the form window handle so that you can receive notification
    ' events...
    Private Sub Form_Load()
    ' do not remove!
    ConnectToHID (Me.hwnd)
    End Sub
    ' disconnect from the HID controller...
    Private Sub Form_Unload(Cancel As Integer)
    DisconnectFromHID
    End Sub
    ' a HID device has been plugged in...
    Public Sub OnPlugged(ByVal pHandle As Long)
    If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then
    ' ** YOUR CODE HERE **
    estado.Caption = "Plugged in"
    End If
    End Sub
    ' a HID device has been unplugged...
    Public Sub OnUnplugged(ByVal pHandle As Long)
    estado.Caption = "Unplugged"
    Label1.Caption = "Nothing"
    End If
    End Sub
    ' controller changed notification - called
    ' after ALL HID devices are plugged or unplugged
    Public Sub OnChanged()
    Dim DeviceHandle As Long
    ' get the handle of the device we are interested in, then set
    ' its read notify flag to true - this ensures you get a read
    ' notification message when there is some data to read...
    DeviceHandle = hidGetHandle(VendorID, ProductID)
    hidSetReadNotify DeviceHandle, True
    End Sub
    ' on read event...
    Public Sub OnRead(ByVal pHandle As Long)
    ' read the data (don't forget, pass the whole array)...
    If hidRead(pHandle, BufferIn(0)) Then
    ' first byte is the report ID, e.g. BufferIn(0)
    ' the other bytes are the data from the microcontroller...
    voltaje = (CStr(BufferIn(1)) + "." + CStr(BufferIn(3)) + CStr(BufferIn(4)) + "V")
    Label1.Caption = voltaje
    End If
    End Sub
    ' this is how you write some data...
    Public Sub WriteSomeData()
    BufferOut(0) = 0 ' first by is always the report ID
    BufferOut(1) = 10 ' first data item, etc etc
    ' write the data (don't forget, pass the whole array)...
    'hidWriteEx VendorID, ProductID, BufferOut(0)
    End Sub
    It doesnt work in visual basic, i only receive ".V" in the label, but i tested with the demo datalogger and it works. I dont know whats happened. Help me please
    Thanks in advance
  7. #47
    I'm no expert, but doesn't USB run at 48MHz?
    Check out Bruce's code at Rentron and see what he does.
  8. #48
    Sep 2006
    Mexico
    Unhappy
    Hi. I have tested the communication with bruce's software and it works fine whit 20Mhz xtal. But with my code doesnt work.
  9. #49
    Sep 2006
    Mexico
    Smile
    Got it!!! Take a look:
    VB code:
    Dim BufferIn(0 To BufferInSize) <---Mistake here, need to declare as byte !!!
    I need to write 1000 lines with the next message:
    "Dont forget declaration of variables" LOL
  10. #50
    Jul 2005
    Default Syntax error compiling code with ADCON1 & ADCON2
    Hi i've recently begun experimenting with the 18F4550 i've got a working example program that lets me flash an led connected to PORTB.7, I use VB6 on the PC side.
    Basically my project has been halted by an unexpected problem in compiling some code added to work the A/D. Both Bruce's USB_AD.zip example and my own code cannot compile this:
    I get a syntax error.... any ideas - full code posted below.
    I'm running version 2.2.1.1 of microcode studio. I'm using the new beta program for the EPIC parallel programmer (with the 40 pin adapter)
    DEFINE OSC 20
    'ADC defines
    Quanta con 1251
    Adval VAR WORD
    USBBufferSizeMax con 64 ' maximum buffer size
    USBBufferSizeTX con 64 ' input
    USBBufferSizeRX con 64 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    x VAR BYTE
    usbinit ' initialise USB...
    x = 0
    LOW PORTB
    BlinkLED:
    if x = 7 then ProgramStart
    x = x + 1
    HIGH PORTB.7
    PAUSE 1000
    LOW PORTB.7
    PAUSE 500
    goto blinkLED
    ProgramStart:
    x = 0
    gosub DoUSBIn
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    if usbbuffer[2] = 1 then
    high portb.7
    IF USBbuffer[2] = 0 THEN
    LOW portb.7
    goto DoAD
    DoAD:
    ' Load data buffer
    USBBuffer[0] = Adval dig 3 'Y.LowByte
    USBBuffer[1] = "."
    USBBuffer[2] = Adval DIG 2
    USBBuffer[3] = Adval DIG 1
    USBBuffer[4] = aDVAL DIG 0
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    Sep 2006
    Mexico
    Hello Rytech, your code is ok, i tried to compile it and it works. Probably you need a newer version of pbp or microcode studio.
  12. #52
    Jul 2005
    Default Version info
    I have PBP Compiler 2.46, Microcode studio 2.2.1.1 and version 4.21 beta of MeLabs Programmer software
  13. #53
    Jul 2005
    Hopefully someone can comment on why my compiler doesnt know what ADCON1 & ADCON2 is for the 18F series chip.
    If i take out ADCON2 and the usb stuff and compile for 16F877A it has no problems with ADCON1 - which to me suggest my support for a 18F4550 is buggered.
    this compiles fine for the 16F877A:
    DEFINE OSC 20
    'ADC defines
    Quanta con 1251
    Adval VAR WORD
    ' the USB buffer...
    x VAR BYTE
    'ADCON2 = %10000011 ' Left justify for 10-bit
    'usbinit ' initialise USB...
    x = 0
    LOW PORTB
    BlinkLED:
    x = x + 1
    HIGH PORTB.7
    PAUSE 1000
    LOW PORTB.7
    PAUSE 500
    goto blinkLED
    ProgramStart:
    x = 0
    gosub DoUSBIn
    gosub DoUSBOut
    goto ProgramStart
    DoUSBIn:
    ' USBService ' keep connection alive
    ' USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    high portb.7
    LOW portb.7
    goto DoAD
    DoAD:
    ' Load data buffer
    USBBuffer[1] = "."
    DoUSBOut:
    'USBService ' keep connection alive
    'USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    Jul 2005
    I just applied the update for version 2.46 - no effect.
  15. #55
    Jul 2005
    Updated MPLAB & MPASM to latest version - no effect.
  16. #56
    Try this:
    Poke $fc0, $83 'which is the same thing as the line above.
  17. #57
    Jul 2005
    Ok that compiled... with warnings...
    Warning c:\progra~1\picbas~1\18F4550.inc 20: _CONFIG has been depreciated for PIC18 devices. Use CONFIG (repeated about 8 ti
    does the fact that the "POKE" command compiled tell us why ADCON1 & ADCON2 would not?
  18. #58
    Quote Originally Posted by RYTECH View Post
    PBP 2.47 shows fixes for miscellaneous items and a few other things.
    Maybe that's one of the fixes...who knows. And, heck, if Poke works, who cares
  19. #59
    Jul 2005
    Ok, so poke just manually writes values to the given registers?
    I'd still like to figure out why ADCON1 & ADCON2 is not working.
    Last edited by RYTECH; - 11th June 2007 at 00:19. Reason: I asked for the answer to a simple problem
  20. #60
    Sep 2006
    Mexico
    Download Microcode Studio 3.0
    http://www.mecanique.co.uk/code-studio/
  21. #61
    Jul 2005
    Post info
    This is now what I have installed
    Version:
    PBP 2.46 (w/patched 2.46 from support page)
    MPASM v5.11
    melabs Programmer Version 4.21 beta
    PIC18F4550
  22. #62
    Jul 2005
    Exclamation update
    no change to my situation.
    'Poke $fc0, $83 'which is the same thing as the line above.
    compiling my code posted previously (no other changes) using the code above still causes a Syntax error.
    'ADCON1 = %00001110 ' A/D channel 0
    using the code above it compiles.
    i'm new to poking ... I guess i've never had to directly write to any registers. I think i've peeked once.
    Ok so I can deal with using POKE commands if they end up working to get my project moving along again.
  23. #63
    Jul 2005
    Yeah if the peek and poke work thats fine for me, I had used ADCON commands before and am a little stumped about why it would work in once case for a certain PIC and not for another (the 18F4550). I knew it might be a matter of having support for the specific chip. i'm hoping other commands don't have syntax errors as i go...
    I wonder if 2.47 resolves the Syntax error as I intend to start using the USB type 18Fxxxx type PICs
    How do i find the microcontroller register address for ADCON0 - ADCON1 - ADCON2, is it in the datasheet? ( the sections describing A/D operation dont seem to list the address locations)
  24. #64
    Jul 2005
    Exclamation Version 2.47
    Is there no downloadable version of Pic Basic Pro Upgrade 2.47. The shipping is like 3 times the cost of the cdrom!!
  25. #65
    Probably the person who sell you the upgrade may do it for you?
  26. #66
    Jul 2005
    Yeah I suppose I should ask about a downloadable version. I guess 50 bucks isn't all that much to pay for the upgrade in total.
  27. #67
    Jul 2007
    I am trying to link my PC to my experimental board with PIC18F4550.
    I am using EasyHID (mcHID.dll in delphi - for PC, and PROTON IDE for firmware from PIC) but the speed transfer of data from PC to PIC is very slow - about 64KB/sec.
    I need more speed - I need over 240KB / sec. How can I make this data transfer to be fasterthan now?
    Thank you
  28. #68
    This forum is for PBP not PROTON.
    The PROTON forum can be found here http://www.picbasic.org/forum/
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  29. #69
    aman_b's Avatar
    aman_b Guest
    Default links missing
    Hi
    I tried to access the link for zip file and the easy hid, but seems like they dont exist anymore. could you please attach them in the forum. That would very helpful
    Aman
    I've used it, and if you're looking to get started with USB, then Dave's new
    EasyHID & the PIC18F4550 are definitely the way to go.
    Download & install EasyHID.
    http://www.mecanique.co.uk/products/usb/easyhid.html
    I have several projects for USB coming shortly, but in the mean time, I've
    loaded the files for a complete USB project on our website.
    The zip file contains PBP source code for a PIC18F4550, and VB source for a
    USB analog data-logger. Should be fun for anyone interested in tinkering with
    EasyHID and the new full-speed 18F USB parts.
    Here are the files: http://www.rentron.com/mcstudio/EasyHIDPrj.zip
    You'll need VB6 & SoftWire. You can download SoftWire from here. It's free.
    http://www.softwire.com/swdownload/softwiredownload.htm
    I used the activx controls in SoftWire for the analog meter interface. Really
    nice stuff.
    You'll also need PBP version 2.46 since this is the version offering support for
    the newer 18F USB parts.
    If anyone's looking for an excellent book on USB, then grab a copy of Jan
    Axelson's new 3rd edition of USB Complete. We just got them in. I spent the
    last few days reading mine, and it's awesome.
    Jan has done an outstanding job on her 3rd edition of this book. Even "I" can
    understand it now...;o]
  30. #70
    Sorry. These files are no longer available since the support applications you would need to install to use them have been discontinued.
    Mecanique dropped the free version of EasyHID, and the VB6 version of Softwire is no longer available. Without these two applications, the .zip file would be useless.
    See Mr E's USB example here: http://www.picbasic.co.uk/forum/showthread.php?t=5418
    -Bruce
    tech at rentron.com
  31. #71
    problem now will be the .dll. Not sure if we are allowed to distribute it
  32. #72
    Jul 2005
    So basically now it's part of microcode studio right?
    This confused me too for a bit till i saw it in Microcode studio's "view" menu.
  33. #73
    And those having the old black installation CD... don't have this chance 'till now (december 18/2007)
    Or once again, i still miss something... that's what happen when you're coming old.
  34. #74
    It's an ODD one.
    Can't remember anyone UN-Releasing software that was once Free in the Public Domain.
    Till now.
    That's it, from now on, everyone must BUY Instant Interrupts. (NOT!)
    Pffft!
    T.Jackson's Avatar
    T.Jackson Guest
    I was actually considerably shocked that it was free.
  36. #76
    Would you also be shocked to find out that 10 million people got it for free ...
    But now you have to pay for it? (cuz it turned out to be good)
    T.Jackson's Avatar
    T.Jackson Guest
    Nope. People are in business to make money, not friends.
  38. #78
    Yes, but businesses are also responsible for their decisions.
    Once you make them, you can't just go, Oh I didn't mean that.
    And, as far as the law goes ... once you put something in the Public Domain,
    It's there to stay.
    No court in the world would convict you for passing on the previously downloaded EasyHID.
    I should mention, that I think it would be OK to do this if there were major improvements that warranted additional costs. But it's still the same program. No upgrades, no new features. Just, you don't get it, lest you pay now.
    T.Jackson's Avatar
    T.Jackson Guest
    Can't say that I particularly like or even agree with their method. You'll probably find that they had plans to sell it right from the time of its conception. By initially offering it for free -- it attracts a larger audience, some people find a "niche" for it in their toolbox, some may even become entirely dependent on it. For most people it's a "gotcha" -- they now must simply pay for it in order to continue using it. The vendor would make a tonne more money doing this than initially trying to sell it. Mainly because most people don't fall in love with a piece of software until they've come to grips with it. Even a $30 purchase for many people is enough to make them procrastinate about;
    1. Will I learn this easily enough?
    2. Will I ever really use this thing?
    3. Does it really work a good as they say?
    4. Will it do exactly what I want it to?
    5. Maybe I can find something cheaper?
    When something is for free, none of those things enter our minds -- instead we just give it ago because we have nothing to lose. So all told, they'll reap in a tonne of cash from basically all dependent users. That's life ...
    Feel free to disagree with my marketing theory
  40. #80
    Marketing Schmarketing.
    You put software on the internet for free.
    You allow all kinds of people to create programs that actually make that software useable.
    Those people have invested MANY hours in developing your free product. (about 100 or so from me).
    Once that product becomes popular, you go, ... Hey there's a lot of people that want this. I shouldn't be giving it away.
    Hogwash!
    Maybe it's time for DT_HID, or even TJ_HID.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 23:43
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
