Problems with DT interrupts (PT_INT interrupt)
Results 1 to 9 of 9
    Angry Problems with DT interrupts (PT_INT interrupt)
    Hello everyone
    I'm trying to use Instant Interrupts with the PT_INT interrupt (PWM time base) in my code.
    I'm using a 18F2431 with a 40MHz clock frequency. My PWM interrupt frequency is about 15kHz (PTPER=333).
    With a code like that (with no interrupt, just waiting the PIR3.4 flag in a loop), it works very well :
    DEFINE OSC 40
    ' PCPWM registers configuration
    PTCON0=%00000010
    PTCON1=%10000000
    PWMCON0=%01000000
    PWMCON1=%00000001
    DTCON=%00110110
    PTPERH=$1:PTPERL=$4d
    ' PWM ISR
    pwmint:
    ' Wait PIR3 interrupt
    while PIR3.4=%0
    wend
    PIR3.4=%0
    (there is my PWM code)
    GOTO pwmint
    However, this code below should give me the same results and execute my PWM ISR at each PWM pulse, but it doesn't work :
    DEFINE OSC 40
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    PTCON0=%00000010
    PTCON1=%10000000
    PWMCON0=%01000000
    PWMCON1=%00000001
    DTCON=%00110110
            INT_Handler   PT_INT,  _pwmint,   PBP,  yes
    @ INT_ENABLE PT_INT
    ' PWM ISR
    pwmint:
    PIR3.4=%0
    @ INT_RETURN
    I need help thanks
    Sep 2009
    Default Re: Problems with DT interrupts (PT_INT interrupt)
    Hey, you don't have any loop in you code.
    DEFINE OSC 40
    PTCON0=%00000010
    PTCON1=%10000000
    PWMCON0=%01000000
    PWMCON1=%00000001
    DTCON=%00110110
    @ INT_ENABLE PT_INT
    GOTO Main
    ' PWM ISR
    pwmint:
    PIR3.4=%0
    @ INT_RETURN
    With this code, you stay in main, and wait for interrupt. When interrupt fire PC will jump to to pwmint. And with INT_RETURN you return to main.
    Without Main loop, PIC execute every instruction, and when execute INT_RETURN processor reset PIC(reset on stack underflow).
    Thanks a lot Pedja!
    I didn't know that a main loop was mandatory in order to execute an interrupt
    However what's that "reset flag"?
    Do I need to clear myself the PIR3.4 flag?
    When you tell DT-INTS to clear the flag (by setting the reset flag option to YES) you don't need to clear it manually in the ISR. If you set the option to NO then DT-INTS will leave the flag alone and its up to you (or the hardware) to handle it the flag as needed.
    Thanks Henrik
    I will let the DT-INTS clear the flag, I think it's more "efficient" than clear the flag manually...
    Question Re: Problems with DT interrupts (PT_INT interrupt)
    Nevermind...
    Jan 2012
    Grid EN19MV
    Nevermind...
    I'm glad someone else feels the same way I do when I try to answer things!
    -Stephen Hawking
    I had quoted Pedja thinking I had selected the OP and saw nothing wrong with the Main routine.
  1. Replies: 5
    Last Post: - 3rd August 2014, 10:36
  2. Interrupt problems!
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2006, 14:55
  3. Replies: 1
    Last Post: - 1st November 2006, 03:11
  4. RB0 interrupt problems
    By amindzo in forum General
    Last Post: - 26th August 2006, 11:52
  5. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 14:38
