Help with configuring
Results 1 to 10 of 10
    Default Help with configuring
    Hello there. I have written a simple code but it seems not to work properly. I am not sure what I am missing here and any help will be appreciated.
    The code is as follows:
        ifdef PM_USED
            device  pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
            __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _CPD_ON & _BOD_ON & _IESO_ON & _FCMEN_ON
    DEFINE OSC 8       ' OSCCON defaults to 8MHz on reset
    DEFINE NO_CLRWDT 1
    Include   "modedefs.bas"
    ' declare the interrupt handler
    define INTHAND _ISR
    ISR:
    asm
    ; my asm code
    endasm
            PAUSE 50
    	OSCCON = %01110001 ' Internal Oscillator 8MHz
            TRISA = %000100
            TRISC = %000010
            CMCON0 = 7
            ANSEL = 0               ' NO ANALOGS
            OPTION_REG = %10000011  ' RAPU = off, PS 1:16 to TMR0
            PORTA=0
            PORTC=0
            ' setup iZCD to interrupt on change
    '        INTCON= %10110000
            '         |         Global interrupts enabled
            '           |       Timer0 interrupt enabled
            '            |      Zero Crossing interrupt enabled
            '             ----  Flags are cleared
     while 1
    	toggle PortA.4
    wend
    When I comment the INTCON, my led blinks fine @ 500mS. When I uncomment it, the timings go out.
    I want to run my PIC16F688 at internal 8MHz and not sure if I am missing any configuration register.
    ___________________
    WHY things get boring when they work just fine?
    Default Re: Help with configuring
    Anyone?????
    ___________________
    if you enable interrupts and provide no code to service the interrupt and worse still provide no code to reset the interrupt flag what do you expect to happen ?
    Here you are:
    ISR:
    asm
            movwf   wsave           ; Save WREG
            swapf   STATUS, W
            clrf    STATUS          ; Point to bank 0
            movwf   ssave           ; Save STATUS
            movf    FSR,w
            movwf   fsave          ; save FSR
            movf    PCLATH, W       ; Save PCLATH
            movwf   psave
            ; get ready to jump within the ISR page
            movlw   ((INTHAND) >> 8) ; Set PCLATH for jump
            movwf   PCLATH
            btfsc   INTCON, INTF
            goto    ZeroCrossingInt
    T0Overflow
            bcf     INTCON, T0IF    ; clear the timer overflow flag
            goto    EndInt
    ZeroCrossingInt
            bcf     INTCON, INTF    ; clear the interrupt
    EndInt  ; restore the machine state and return from interrupts
            movf    fsave,w
            movwf   FSR             ; restore FSR
            movf    psave,w
            movwf   PCLATH          ; restore PCH
            swapf   ssave,w
            movwf   STATUS          ; restore Status
            swapf   wsave,f
            swapf   wsave,w         ; restore WREG
            retfie
    endasm
    ___________________
    I cant see that you have declared wsave ,ssave and psave vars ?
    I missed that.
    wsave       var byte    $70     SYSTEM          ' safe for W in all banks
    ssave       var byte    BANK0   SYSTEM          ' save STATUS
    psave       var byte    BANK0   SYSTEM          ' save PCLATH
    fsave       var byte    BANK0   SYSTEM          ' save FSR
    ___________________
    dt ints is easier
    I know that. But latency causes problem.
    ___________________
    Quote Originally Posted by financecatalyst View Post
    What latency? I have never noticed any with DT's INTS.
    Suggestion: Simplify your job by switching to a 16F1823. Same pinout as your present PIC but with automatic context saving.
  1. configuring AD converter in a 12F615
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 1st June 2011, 04:38
  2. Configuring 16F616
    Last Post: - 16th February 2009, 17:28
  3. Configuring register problem
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2005, 21:03
  4. configuring the internal oscillator
    By bartman in forum General
    Last Post: - 30th November 2004, 01:41
  5. need help configuring 16F628
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 19:59
