LCD's and Sleeping Pics
Results 1 to 2 of 2
    May 2012
    Merseyside, UK
    Thumbs down LCD's and Sleeping Pics
    Hello
    Thank you for the quick read…. Posted this elsewhere by mistake :-)
    Is it deemed correct to drive a 16x20 LCD and back light direct from a single output Pin.
    Don't worry, when I say direct I "DO" mean via a Transistor or Darlington buffer….
    I am using an interrupt routine which will put the PIC to sleep…but the LCD is hung on the supply rails, The LCD will stay on, so was thinking if I hang it on a spare output port it can be shutdown before the PIC goes to sleep.
    Or is there a more elegant way of doing it??
    Thank you again
    Andy
    Sep 2008
    Maine, USA
    Default Re: LCD's and Sleeping Pics
    Andy,
    I *almost* always drive the back light with a separate pin via a MOSFET to have the option of PWM dimming of the light. If you have 2 pins to spare - 1 for LCD and 1 for BL. Many LCDs draw so little power that you can direct drive the LCD from an I/O pin. Check the power specs of your particular LCD or just use a MOSFET. My preferred MOSFET is the 2N7000 for up to 200mA or the BS170 for up to 500mA.
    "Do or do not, there is no try" Yoda
  1. Testing LCD's
    By david miles in forum General
    Last Post: - 29th January 2008, 21:35
  2. Getting started with Graphic LCD's
    By T_J_W in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2007, 15:34
  3. multiple lcd's
    By schu4647 in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2006, 05:02
  4. Waking a sleeping PIC
    By anj in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 01:51
  5. Serial LCD's
    By EShatara in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 07:56
