Hi Guys , was wondering how PBP handles bits var defines , relative to byte defines. for use of memory code space use.
when i have a need of many flags i have generally defined a byte , and then allocated each bit of that byte to the var flag names as required ,
bit_byte1 var byte
bit0 var bit_byte1.0
bit1 var bit_byte1.1
bit2 var bit_byte1.2
bit3 var bit_byte1.3
bit4 var bit_byte1.4
bit5 var bit_byte1.5
bit6 var bit_byte1.6
bit7 var bit_byte1.7
' need only 1 bit then
mybit var Bit
where when i need only 1 bit i define as a bit only
this is done in the assumption that when is compiled the memeory use will be less than if i had defined a byte
does this hold true ?
