Pic 16f737 lcd
Results 1 to 4 of 4
Thread: Pic 16f737 lcd
    May 2014
    Default Pic 16f737 lcd
    Hi Everyone
    I just received my 16F737 from MELABS. I am using PICBASIC PRO 2.50C
    I have used an external 4MHZ Crystal and 2 10uf Capacitors tied to ground.
    I have also the PICBASIC PRO Book by Dougan Ibrahim and i used the LCD example which prints "Hello" Clear Screen and then "World" and it works perfectly fine.
    I have also made the connections as assumed by PBP without defining ports. The ports connected are as below:
    LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    ' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
    ' E PortB.3
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo 20K potentiometer (or ground)
    Now the issue i have is i used DEFINE statements to change the ports as below:
    PicBasic program to demonstrate operation of an LCD in 4-bit mode
    ' LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortB.0
    ' DB5 PortB.1
    ' DB6 PortB.2
    ' DB7 PortB.3
    ' RS PortB.5 (add 4.7K pullup resistor to 5 volts)
    ' E PortB.4
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' DB0-3 No connect
    And the code in picbasic pro as follows:
    include "bs1defs.bas"
    Define LCD_DREG    PORTB
    Define LCD_DBIT    0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 5
    Define LCD_EREG    PORTB
    Define LCD_EBIT    4
    TRISB   =   0
    pause   10
    loop:   Lcdout $fe, 1   ' Clear LCD screen
            pause 5
            Lcdout "Hello"  ' Display Hello
            Pause 5       ' Wait .5 second
            pause 5
            Lcdout "World"
            Goto loop       ' Do it forever
    Now the LCD pauses for a few seconds and there is a blinking cursor on Line 1, Column 1
    When i connect back to the old configuration it works fine on the same code.
    Also i am using a 4MHZ clock and a beginner in PBP and just switched from 89C51 Controller.
    When i give 'PAUSE 5' it will wait for close to 5 seconds. Is there something that i have to mention about the close during flashing ? Or in code?
    Also why will the LCD not function with this code. I rechecked and reconnected all the pins and all seems to be fine.
    Please help to me find out what i am doing wrong.
    Thanks to all in advance.
    Default Re: Pic 16f737 lcd
    Try adding DEFINE OSC 4 (by memory, doublecheck syntax).
    PAUSE 5 turning into 5000 is usually timing issue.
    Are you sure about your cap size? I thought I used about 20pF, what does PBP manual recommend?
    Edit: 5 milliseconds is extremely fast, try 1000, it is easier to check for 1 second visually.
    May 2014
    Thanks Demon
    I found out the same issue solved on this forum.
    Here is the thread.
    http://www.picbasic.co.uk/forum/showthread.php?t=3277
    I set the ADCON1 = %0011111 to set digital signal and it works perfectly fine now.
    I am using a 4MHZ crystal and when i program i select XT. Do we have to change something in the software to fix it ?
    If i use the value PAUSE 20 it is close to 20 Seconds
    May 2014
    Demon
    I need to use Channel 13 for ADC. Here is what is in the manual
    REGISTER 12-1: ADCON0: A/D CONTROL REGISTER 0 (ADDRESS 1Fh)
    R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0
    ADCS1 ADCS0 CHS2 CHS1 CHS0 GO/DONE CHS3 ADON
    bit 7 bit 0
    bit 7-6 ADCS1:ADCS0: A/D Conversion Clock Select bits
    If ADCS2 = 0:
    000 = FOSC/2
    001 = FOSC/8
    010 = FOSC/32
    011 = FRC (clock derived from an RC oscillation)
    If ADCS2 = 1:
    00 = FOSC/4
    01 = FOSC/16
    10 = FOSC/64
    bit 5-3 CHS<2:0>: Analog Channel Select bits
    0000 = Channel 00 (AN0)
    0001 = Channel 01 (AN1)
    0010 = Channel 02 (AN2)
    0011 = Channel 03 (AN3)
    0100 = Channel 04 (AN4)
    0101 = Channel 05 (AN5)(1)
    0110 = Channel 06 (AN6)(1)
    0111 = Channel 07 (AN7)(1)
    1000 = Channel 08 (AN8)
    1001 = Channel 09 (AN9)
    1010 = Channel 10 (AN10)
    1011 = Channel 11 (AN11)
    1100 = Channel 12 (AN12)
    1101 = Channel 13 (AN13)
    111x = Unused
    Note 1: Selecting AN5 through AN7 on the 28-pin product variant (PIC16F737 and
    PIC16F767) will result in a full-scale conversion as unimplemented channels are
    connected to VDD.
    bit 2 GO/DONE: A/D Conversion Status bit
    1 = A/D conversion cycle in progress. Setting this bit starts an A/D conversion cycle. This bit is
    automatically cleared by hardware when the A/D conversion has completed.
    0 = A/D conversion completed/not in progress
    bit 1 CHS<3>: Analog Channel Select bit (see bit 5-3 for bit settings)
    bit 0 ADON: A/D Conversion Status bit
    1 = A/D converter module is operating
    0 = A/D converter is shut-off and consumes no operating current
    Legend:
    R = Readable bit W = Writable bit U = Unimplemented bit, read as ‘0’
    -n = Value at POR ‘1’ = Bit is set ‘0’ = Bit is cleared x = Bit is unknown
    Can you tell me what is the ADCON0 Value if i use a 4MHZ and need to use CHANNEL 13 ?
  1. Problem with 16F737
    By rangerdoc in forum mel PIC BASIC Pro
    Last Post: - 7th November 2007, 03:09
  2. Configuration of 16F737
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 03:14
  3. readcode on 16F737
    By joeri in forum mel PIC BASIC Pro
    Last Post: - 30th July 2006, 16:01
  4. PID controller in 16F737
    Last Post: - 24th June 2006, 11:39
  5. 16F737 Microcode studio
    Last Post: - 9th February 2006, 17:45
