How do I discern Maidenhead Locator from GPS lat long info.
Page 1 of 4 1234 LastLast
Results 1 to 40 of 126
    Dec 2011
    IO93ok
    Default How do I discern Maidenhead Locator from GPS lat long info.
    Hi all,
    I have some idea but maths is not my strong point. I have written what I considered to be the process but not a working code. Am I on the right lines ?(See end)
    This is the relevant information to achieve the locator.
    Longitude is always the first, followed by latitude, for each pair. For simplicity, let's assume that West and South are negative lat/long, as is a common convention. For example purposes, I'm going to use 32.123 W, 14.321 N. The key thing is to do the following.:
    Longitude
    1. Add 180 to the longitude, and take the integer value /20, and add one. Then figure out which letter of the alphabet that corresponds to, usually written in upper case. The example will be 147.877/20=7. Adding one will give the 8th letter of the alphabet, or G. Note 7.877 is remaining.
    2. Take the remainder of what is left, and divide by 2, rounding down. This is the number, no conversion required. The example will give a value of 3. Note 1.877 is remaining.
    3. Take the remainder that is left, and multiply by 12, and add one. Round down to the nearest integer.. This is the letter of the alphabet, usually written in lower case. The example gives a value of 22+1=23. This will be the letter w.
    Latitude
    1. Add 90 to the latitude, and take the integer value /10, and add one. Then figure out which letter of the alphabet that corresponds to, usually written in upper case. The example will be 104.321/10=10. Adding one will give the 8th letter of the alphabet, or J. Note 4.321 is remaining.
    2. Take the remainder of what is left, and round down. This is the number, no conversion required. The example will give a value of 4. Note 0.321 is remaining.
    3. Take the remainder that is left, and multiply by 24, and add one. Round down to the nearest integer.. This is the letter of the alphabet, usually written in lower case. The example gives a value of 7+1=8. This will be the letter g.
    Putting them together by pairs, and alternating first longitude then latitude, gives the grid square for 32.123 W, 14.321 N to be GJ34wg.
    I have the info from the RMC string as :-
    latdeg VAR BYTE 'degrees latitude
    latmin VAR BYTE 'minutes latitude
    NS VAR BYTE 'north or south
    londeg VAR BYTE 'degrees longitude
    lonmin VAR BYTE 'minutes longitude
    EO VAR BYTE 'east or west
    My idea of the process is something like this :-
    locator:
         lonloc1=londeg + lonmin + 180
         lonloc2=lonloc1/20
         lonloc3=lonloc1//20
         maid1=lonloc2+1
         lookup maid1    ; first main letter
         lonloc4=lonloc3//2
         maid3=lonloc3/2     ;first number
         maid5=lonloc4*12+1
         lookup maid5      ; 1st  2nd letter
         latloc1=latdeg + latmin + 90
         latloc2=latloc1/10+1
         latloc3=latloc1//10
         maid1=latloc2+1
         lookup maid2    ; second main letter
         maid4=latloc3     ; second number
         maid6=latloc3*24+1
         lookup maid6      ; 2nd 2nd letter
         maidenhead=maid1, maid2, maid3, maid4, maid5, maid6
    Jan 2012
    Grid EN19MV
    Default Re: How do I discern Maidenhead Locator from GPS lat long info.
    Weird - I've had this one on my list of things to make for about a year - I got a bit of a start, then other things took over.
    Don't know if this helps, but HERE is a BASIC program that I was going to try to convert.
    If I get going on this again, I'll keep you updated - and please let me know how you're doing with it too.
    Andy
    -Stephen Hawking
    Dec 2011
    IO93ok
    OK thanks for that I will look at it.
    Meanwhile here is the full code i have for getting the NMEA data I want to display. NOTE the code for maidenhead is the same as above, a work in progress. All untested as yet.
    I do have a fully working code in asm but wanted it in PBP for experimental purposes.
    ' Program to display returned value of a GPS on RB0
    ' LCD in 4-BIT mode PIC16F628 controller 4Mhz clock Fuse PWRT BODEN
    'GPS sentence: $GPRMC,192144.62,A,5041.6058,N,00412.6124,E,0.45,3 57.74,081205,,*0B
    Define LCD_DREG PORTA          ' Port for LCD Data
    Define LCD_DBIT 0                   ' Use upper 4 bits of Port
    Define LCD_RSREG PORTB         ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 4                 ' Port Pin for RS bit  (pin9)
    Define LCD_EREG PORTB          ' Port for Enable (E) bit
    Define LCD_EBIT 5                   ' Port Pin for E bit    (pin7)
    Define LCB_BITS 4                   ' Using 4-bit bus
    Define LCD_LINES 4                  ' Using 2 line Display
    Define LCD_COMMANDUS 2000      ' Command Delay (uS)
    define LCD_DATAUS 50              ' Data Delay (uS)
    CMCON = 7
    OPTION_REG.7=0                 ' Enable Pull-Up's
    GPSin VAR PORTB.0
    LED  VAR PortA.4               ' flash per second
    TRISA.0=0
    TRISA.1=0
    TRISA.2=0
    TRISA.3=0
    TRISA.4=0 ; LED
    PAUSE 500
    PORTA=0
    PORTB=0
    'Allocate Variables for GPS:
    TimeOut CON 3000
    baudGPS CON 24764 '16572 + 8192 (bit 13)
    hh VAR BYTE           'hours
    mm VAR BYTE          'minutes
    knots VAR WORD     'speed in knots (units)
    knotsten VAR BYTE   'speed in knots (tens)
    course VAR WORD    'heading
    j VAR BYTE             'day
    m VAR BYTE            'month
    a VAR BYTE            'year
    fix VAR WORD        'GPS fix
    LCDOut $FE, 1        'Clear Screen
    LCDOut $fe,$80," GPS Decoder "
    LCDOut $FE,$c0, " G8VLQ "
    Pause 2000
    LCDOut $FE, 1
    GPS:                 'read GPS
    SerIn2 GPSin,baudGPS,Timeout,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,wait(","),fix,wait(","),DEC2 latdeg,DEC2 latmin,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait(","),EO,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 j,DEC2 m,DEC2 a]
    flash:                       ;not accurate pps
    led high
    led low
    IF fix="V" Then                                            'if no GPS fix
    GOTO LCD1
    EndIF
    LCD:                  ; LATER put time and date on first line , remove names
                             ; callsign and QRA (maidenhead) on second line
    LCDOut $fe,$80,"DATE: ",DEC2 j,"-",DEC2 m,"-",DEC2 a                                     ; 80 1st line
    LCDOUT $fe,$c0,"TIME: ",DEC2 hh,":",DEC2 mm                                                 ; c0 2nd line
    LCDOut $fe,$94,"LAT:",DEC2 latdeg,",",DEC2 latmin," ",NS                                  ; 94 3rd line
    LCDOut $fe,$d4,"LON:",DEC2 londeg,",",DEC2 lonmin," ",EO                                ; d4 4th line
    GoTo GPS
    LCD1:                       ; If invalid data, just shows gps string is received
    LCDOut $fe,$80,"  Invalid data  "        ; 80 1st line
    LCDOUT $fe,$c0,"     No Fix     "        ; c0 2nd line
    GoTo GPS
    locator:
         lonloc2=lonloc1/20
         lonloc3=lonloc1//20
         maid1=lonloc2+1
         lonloc4=lonloc3//2
         maid5=lonloc4*12+1
         latloc3=latloc1//10
         maid1=latloc2+1
         maid6=latloc3*24+1
    speed:
    LCDOUT $fe,1
    LCDOut $fe,$80,"SPEED :",knots,".",DEC2 knotsten," KNT"
    LCDOut $fe,$c0,"HEADING:",DEC3 course," DEG"
    Jan 2012
    Grid EN19MV
    Thanks! I'll have a look at that.
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    BTW, what are you building? Mine was an idea when I was driving around talking on Amateur Radio Satellites. We were in Grand Forks, North Dakota, and I was waiting for my wife to come out of a store. There happened to be an AO-51 pass happening right then, so I made a couple of contacts - only I had NO IDEA what my grid square was! I used my Winnipeg one, and thought "it would be nice to have a handheld, GPS-based unit that displays your current grid square to 6 digits". And the idea was born. I'll get to it, probably right after I finish the smoker controller I'm working on right now.
    Did you happen to notice how I list my location on the forum? I guess great minds really DO think alike!
    Andy
    -Stephen Hawking
    Dec 2011
    IO93ok
    Hi Andy,
    The project is already working, I just wanted more information displayed on LCD. The LCD board piggybacks the LCD display. It has a 16F818 which deals with the NMEA string and ADC functions.
    It's a GPS Disciplined Oscillator producing 10MHz to 10-12 signal. For accuracy of frequency and timing for MS and EME.
    It remains extremely stable but I am slightly improving it by logging the PLL control voltage and the TCXO temp swing.
    By logging I can get a mean control position for either start up purposes or short term 'dropout' from gps. Thus it will keep accuracy for short term outage. If the unit is turned off then on, I can apply the correct PLL control voltage until the gps locks again. Although watching the PLL voltage swing whilst trying to lock was fascinating.
    It also produces a very accurate 1PPS output. I later intend to use this to trigger the NMEA sentence display. You may be aware that the sentence suffers from lag or slight offset depending if the gps module decides to send another, other, information sentence. In my case at the moment it is 1.635 secs BEHIND actual time as my module occasionally sends out the powerID string which puts the timing RMC sentence out.
    I will be turning all off except the RMC sentence. At the moment it is testing phase.
    I get a very strong signal from the 60kHz time signal from Anthorn in the UK so I can actually compare the second epoch via SpecLab software visually.
    Rob.
    The moment after you press "Post" is the moment you actually see the typso
    Trying to work through the example in post #1.
    Quote Originally Posted by tasmod
    The best I can come up with is HK33xv at that location.
    Are you sure about the example in post #1?
    And it seems that Andy is in Winnipeg Manitoba Canada.
    And you are near Gainsborough, U.K.
    If those are close, I can't be that far off with the calculations.
    Jan 2012
    Grid EN19MV
    Absolutely correct
    And you're right - HK33xv is in the ocean off of Cape Verde
    And 14.321N 32.123W converts to HK34wh - darn near exactly what you calculated
    -Stephen Hawking
    Thanks Andy, I knew I couldn't be that far off.
    But apparently, I need to work on the math some more.
    Darned Floating-Point ...
    Woohoo!
    HK34wh it is!!
    And it's not even midnight yet.
    It's some really ugly code right now, will need to add some "Pretty" to it.
    Are you guy's using PBP3?
    If not, there's only so much "Pretty" I can add.
    Dec 2011
    IO93ok
    Just realised you discerned my physical location from my locator. So your code should be OK.
    I did the calc by hand and got it to the example Locator given. ODD. Also needed to reverse calc the 'leftovers'
    One thing not mentioned is W is a negative longtitude. I need put an IF THEN in my code to deal with the 180 for a negative W rather than E.
    If you have ugly code then that's ok with me. I'm using 2.50 Darrel. Long time coding but not enough to be good with PBP
    The routine could also decode the 8th place pair too, which is as close as Maidenhead gets.
    Rob.
    Dec 2011
    IO93ok
    Darn it.
    Scrap what I said about the example. I found my scratch pad and realised I used my own GPS co-ordinates to check the formula given to get my locator. I didn't use the example after all.
    Rob.
    Jan 2012
    Grid EN19MV
    Woohoo!
    HK34wh it is!!
    I am - I look forward to seeing your code because math and I do not get along well.....
    That's actually one of the reasons I have been delaying this project - the math was a bit above me right now.... I have just been using the AMSAT page to convert and see where a grid square takes me on the map.
    -Stephen Hawking
    An afterthought, before the fact.
    I went through this trying to make sure it didn't require PBP3 since Rob doesn't have it. But now that I've posted it, I realized it requires PBP 2.60 or later. DOH!
    At least you can download the free PBP3 trial version and compile it with that, or you can change the arrayread/arraywrite statements, so I'm not changing it.
    Ok, here goes ...
    It's not as ugly as it was, but without PBP3 there's only so much you can do.
    This code is based on the Perl script on the Wikipedia site for Maidenhead Locator System by Chris Ruvolo.
    Although I had to do things quite differently for the Microchip Floating-Point routines.
    The Microchip Floating-Point routines for PBP are available from http://melabs.com/resources/fp.htm
    Extract the .zip file to the same folder as your source code, or this code.
    To try to make things easy, the routines start out with a String in the same format as the Lat/Lon data of the $GPRMC sentence.
    For instance, an approximation of the IO93ok square is 0 degrees, 47.70 minutes West Longitude by 53 degrees, 26.20 minutes North latitude.
    $GPRMC will present the data as .... 5326.20,N and 00047.70,W.
    These can be parsed from the GPS data, or entered manually with the following two statements ... Note that they are null terminated.
    ARRAYWRITE LonStr,["00047.70,W",0]  ; -0° 47.70'
    ARRAYWRITE LatStr,["5326.20,N",0]   ; 53° 26.20
    I am entering them manually for this sample.
    I'm using the 24-bit Floating-Point routines, since it gave the same results as the 32-bit FP, but you can use either one by simply changing the include file.
    I imagine the 32-bit routines will be better around the edges of each square, but I haven't confirmed that.
    I'm using a 16F1937, so if you are using an 18F ... you'll need to use the 18F FP includes.
    Obviously, you need to initialize your hardware configs first.
    ; Filename    : Maidenhead.pbp
    ; Compiler    : PICBASIC PRO Compiler
    ; Target PIC  : 16F1937, but will work with most any chip
    ; Oscillator  : ANY
    ; Keywords    : Maidenhead, Locator, GPS, Amateur Radio
    ; Description : PICBASIC PRO program to convert between
    ;             : GPS Sexagesimal to Maidenhead coordinate systems
                           ; use only one of the FP includes
    INCLUDE "FP20.bas"     ; 24-bit Floating Point for 14-bit cores with RAM at $20
    ;INCLUDE "FP2032.bas"   ; 32-bit Floating Point for 14-bit cores with RAM at $20
    DEFINE HSER_SPBRG 25  ' 19200 Baud @ 32MHz, 0.16%
    HSEROUT [27,"[2J","Maidenhead Locator",13,10]
    HSEROUT ["16F1937, 32Mhz, PBP3 not required",13,10,13,10]
    MH     VAR BYTE[6]
    LonStr    VAR BYTE[12]
    LatStr    VAR BYTE[12]
    LonDeg    VAR BYTE
    LonMin    VAR BYTE
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatDeg    VAR BYTE
    LatMin    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    ARRAYWRITE LonStr,["00047.70,W",0]  ; -0° 47.70'  <-- Enter location here
    ARRAYWRITE LatStr,["5326.20,N",0]   ; 53° 26.20'
    HSEROUT ["LonStr  = ", STR LonStr,13,10]          ; display manual input
    HSEROUT ["LatStr  = ", STR LatStr,13,10]
    ;----[parse strings as if they came from a GPS]---------------------------------
    ARRAYREAD LonStr,[DEC3 LonDeg, DEC2 LonMin, Dec LonMinDec, LonDir]
    ARRAYREAD LatStr,[DEC2 LatDeg, DEC2 LatMin, Dec LatMinDec, LatDir]
    ;----[convert Longitude Sexagesimal to Decimal Degrees]-------------------------
    Aint = LonMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    Bint = 100 : GOSUB ItoFB          ; divided by 100
    GOSUB fpdiv
    Bint = LonMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    Bint = 60 : GOSUB ItoFB           ; divide by 60
    GOSUB fpdiv
    Bint = LonDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LonDir = "W" THEN              ; if west of Prime Meridian
        GOSUB AtoB
        Aint = 0    : GOSUB ItoFA     ; subtract from 0 to negate
        GOSUB fpsub
    Bint = 180  : GOSUB ItoFB         ; add 180
    GOSUB fpadd
    ;----[Have Longitude in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Longitude for later
    Bint = 20   : GOSUB ItoFB         ; Lon / 20
    GOSUB fpdiv
    GOSUB SaveAARG                    ; save AARG for modulus
    GOSUB FtoIA                       ; get integer
    MH(0) = "A" + Aint                ; + "A" = First character
                                      ; -- do  Lon // 20 --- (modulus)
    Bint = Aint                       ; copy integer result to BARG
    GOSUB ItoFB                       ; convert it to float
    GOSUB RestoreAARG                 ; restore Lon / 20 to AARG
    GOSUB fpsub                       ; subtract integer
    Bint = 20                         ; multiply times original divisor (20)
    GOSUB ItoFB
    GOSUB fpmul                       ; AARG now contains the modulus
    Bint = 2    : GOSUB ItoFB         ; divide modulus by 2
    GOSUB fpdiv
    MH(2) = "0" + Aint                ; + "0" = Third character
    GOSUB RestoreLon                  ; restore Longitude
    GOSUB fpdiv                       ; divide by 2
    Bint = Aint * 2  : GOSUB ItoFB    ; put int * 2 in BARG, change back to float
    GOSUB RestoreLon                  ; restore original Longitude
    GOSUB fpsub                       ; subtract A - B
    Bint = 12 : GOSUB ItoFB           ; Multiply * 12
    GOSUB fpmul
    MH(4) = "a" + Aint                ; + "a" = Fifth Character
    ;----[convert Latitude Sexagesimal to Decimal Degrees]--------------------------
    Aint = LatMinDec : GOSUB ItoFA    ; decimal portion of Minutes
    GOSUB fpdiv
    Bint = LatMin : GOSUB ItoFB       ; add whole portion of Minutes
    GOSUB fpadd
    GOSUB fpdiv
    Bint = LatDeg : GOSUB ItoFB       ; add degrees
    GOSUB fpadd
    IF LatDir = "S" THEN              ; if south of equator
        GOSUB AtoB
        GOSUB fpsub
    Bint = 90  : GOSUB ItoFB          ; add 90
    GOSUB fpadd
    ;----[Have Latitude  in AARG as Float]------------------------------------------
    GOSUB SaveLon                     ; save Latitude for later
    Bint = 10   : GOSUB ItoFB         ; Lat / 10
    GOSUB fpdiv
    GOSUB FtoIA
    MH(1) = "A" + Aint                ; + "A" = Second character
                                      ; -- do  Lat // 10 --- (modulus)
    GOSUB RestoreAARG                 ; restore Lat / 10 to AARG
    Bint = 10                         ; multiply times original divisor (10)
    GOSUB ItoFB
    GOSUB FtoIA
    MH(3) = "0" + Aint                ; + "0" = Fourth character
    GOSUB RestoreLon                  ; restore original Latitude
    Bint = Aint : GOSUB ItoFB         ; put int in BARG, change back to float
    Bint = 24 : GOSUB ItoFB           ; Multiply * 24
    GOSUB fpmul
    MH(5) = "a" + Aint                ; + "a" = Sixth character
    ;----[Maidenhead conversion complete]-------------------------------------------
    HSEROUT ["LOC ",STR MH\6,13,10,13,10] ; show final result
    Main:                             ; blink an LED when done
        HIGH PORTA.0
        PAUSE 500
        LOW PORTA.0
        PAUSE 500
    GOTO Main
    Aexp_Copy    VAR BYTE
    AARGB0_Copy  VAR BYTE
    AARGB1_Copy  VAR BYTE
    AARGB2_Copy  VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
        AARGB0_Copy = AARGB0
        AARGB1_Copy = AARGB1
        AARGB2_Copy = AARGB2
    RestoreAARG:
        Aexp = Aexp_Copy
        AARGB0 = AARGB0_Copy
        AARGB1 = AARGB1_Copy
        AARGB2 = AARGB2_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    The output from the program in a terminal looks like this ...
    Maidenhead Locator
    LonStr  = 00047.70,W
    LatStr  = 5326.20,N
    LOC IO93ok
    If you are using an Enhanced 14-bit core like the 16F1937 that I'm using ... you'll need to add the processor to the DEV_FAM.INC file from the FP.zip
    For the 16F1937 add this towards the bottom of the file (before the if statement).
        IFDEF   __16F1937          ; Generic Processor Type
    P16CXX      SET    TRUE        ; If P16CXX, use INHX8M file format.
    P16_MAP2    SET    TRUE        ;
    References:
    Jan 2012
    Grid EN19MV
    Umm, WOW! Thanks Darrel! And my brain thanks you even more, since it gets uppity when it has to do complex math!
    -Stephen Hawking
    Dec 2011
    IO93ok
    And a WOW from me Darrel. Thanks for your help. Surprisingly I think I can follow and understand the code
    Sorry I'm late back to the thread. One of the winter bugs has had hold of me, not the type I can rewrite
    The project code I posted above doesn't work in the Serin2 GPS routine. Either the line is incorrect or the speed. I've tried every speed and state but no joy. Signal is at the pic pin every second.
    The code compiles but says 'error, expected [ ' but they are there?
    I will try out the code shortly, many thanks again.
    Rob.
    Quote Originally Posted by tasmod View Post
    The SERIN2 line has a value for the timeout, but there's no label for it to jump to.
    Dec 2011
    IO93ok
    Doh, sometimes you can't see the wood for the trees !
    Thanks again Darrel, you've no idea how many times I looked at that line.
    Code is working at base level now and info is on screen, next is to incorporate the Locator code of yours.
    Rob.
    Awesome!
    Can't wait to see an IO93ok on that LCD.
    Dec 2011
    IO93ok
    Hi Darrel,
    Hmm, I wanted to move on to final stages of the project adding the locator code but before I could I came up against something I've not had before.
    I was using a 16f628A and wanted to port across to a 16F818 for a single adc channel use. (Monitor a pll control voltage)
    I had errors of "Argument out of range" when I added my usual working ADC code. It works standalone on the 818 nicely.
    The code for gps alone works in the 818 as per lcd pic. So I'm lost now.
    In the working gps code alone, no adc code. I did have some very odd messages re 'out of range' with the code with END at the finish of the code. It seemed like something was hidden in the space in MCS. Deleting back to the final Goto GPS cleared the messages.
    This is the gps code with adc which errors. I daren't add the locator code yet
    ; 			        PIC16F818
    ;                          __________
    ;     D6-------------RAN2 |1       18| RAN1---------D5
    ;     D7-------------RAN3 |2       17| RAN0---------D4
    ;     LED------------RAN4 |3       16| OSC1--------XTAL
    ;     +5V-----------!MCLR |4       15| OSC2--------XTAL
    ;     Ground----------Vss |5       14| VDD---------+5 V
    ;     NMEA data-------RB0 |6       13| RB7---------Not used
    ;     Serial data out-RB1 |7       12| RB6---------Not used
    ;     Not used--------RB2 |8       11| RB5---------LCD Enable
    ;     Pushbutton------RB3 |9       10| RB4---------LCD Register select
    ' LCD in 4-BIT mode PIC16F818 controller 4Mhz clock Fuse PWRT BODEN
    Define LCD_COMMANDUS 1500      ' Command Delay (uS)
    GPSin VAR PORTB.0
    ' Initialise ADC
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01010001 ' Configure and turn on A/D Module channel 4 Fosc 8
    PAUSE 500
    'Declare variables
    val VAR WORD      ' final calculated adc valuesWORD' final calculated adc values
    volt VAR WORD     ' scaled value real part
    voltd1 VAR WORD   ' scaled value first decimal place
    voltd2 VAR WORD   ' scaled value second decimal place
    i var byte        ' counter
    TimeOut CON 2000
    hh VAR BYTE             'hours
    ss VAR BYTE             'seconds
    EW VAR BYTE             'east or west
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    LCDOut $FE,$c0, "    G8VLQ Mk1  "
    Pause 500
    GPS: 'read GPS
    SerIn2 GPSin,188,Timeout,LCD1,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(",")_
    ,fix,wait(","),DEC2 latdeg,DEC2 latmin,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,_
    wait(","),EW,wait(","),knots,wait("."),DEC2 knotsten,wait(","),DEC3 course,wait(","),DEC2 d,DEC2 m,DEC2 y]
    GOTO LCD1
    EndIF
    gosub PLL
    LCD:
    LCDOut $fe,$80,DEC2 d,"-",DEC2 m,"-",DEC2 y," ",#volt, ".", # voltd1,# voltd2, "Vdc"            ; 80 1st line
    LCDOUT $fe,$c0,"    ",DEC2 hh,":",DEC2 mm,":",DEC2 ss,"    "                                ; c0 2nd line
    LCDOut $fe,$90," LAT: ",DEC2 latdeg,",",DEC2 latmin," ",NS                                 ; 90 3rd line
    LCDOut $fe,$d0," LON: ",DEC2 londeg,",",DEC2 lonmin," ",EW                                 ; d0 4th line
    GoTo GPS
    LCDOut $fe,$80,#volt, ".", # voltd1,# voltd2, "Vdc"                                         ; 80 1st line
    goto GPS
    LCD2:      ; 20 character display. Put time and date on first line , removed names.
    LCDOut $fe,$80,DEC2 d,"-",DEC2 m,"-",DEC2 y,DEC2 hh,":",DEC2 mm                         ; 80 1st line
    LCDOut $fe,$80," G8VLQ   "                                                              ; c0 2nd line
    LCDOut $fe,$90,"LAT: ",DEC2 latdeg,",",DEC2 latmin," ",NS                                ; 90 3rd line
    LCDOut $fe,$d0,"LON: ",DEC2 londeg,",",DEC2 lonmin," ",EW                                ; d0 4th line
    GoTo GPS
    PLL:
    Val = 0                       ' Value returned is the average of 5 conversions
    For i = 0 TO 4
    ADCON0.4 = 1                  ' Start conversion
    NoteDone:
    pause 1
    IF ADCON0.4 = 1 Then NoteDone
    val = val + ((ADRESH * 256)+(ADRESL))
    nEXT I
    VAL = VAL/5
    ' Calculate Volatage to 2 decimal places
    volt = val * 5/1024
    voltd1 = ( val * 5//1024) * 10/1024
    Voltd2 = ((val *5 //1024) * 10//1024) * 10/1024
    Rob.
    The 16F628A has 2K words of program space.
    The 16F818 only has 1K words.
    You're going to need a bigger chip.
    The Maidenhead routine with Floating point libraries will take >1.5K by itself.
    You'll need at least 4K, but why not get one with 8K so you won't have the problem again later.
    I'm sure you'll want to add a Morse Code transmitter and receiver some day.
    Dec 2011
    IO93ok
    Now that was completely stupid of me, I apologise for such a silly mistake. I had never seen the message before and assumed it was a code error.
    I never gave it a thought to look at the chip spec. The reason to change over to 818 was just one adc input. The chip otherwise is pin compatible for what I've already done.
    I think I will remake a new display pcb and use the 16f876 28 pin chip that has 8k.
    The project uses the chip to accept the NMEA string from a Rockwell gps module and display it. This older gps module also produces accurate 1PPS and 10kHz signals when gps has a fix.
    I'm using these signals on a pll and divider board to lock a 10mhz tcxo.
    In its present application it would have worked fine but I wanted to monitor the gps pll control voltage on the board to check for frequency lock.
    If the voltage was 1.65v then the oscillator was in lock state.
    The display did show whether the satellites produced a fix but not whether the oscillator had locked against the 10khz frequency. Watching the pll control voltage hunt back and forth whilst the gps attempted a fix was facinating but impractical for 'normal' usage.
    Once I have the display running again I'll report back.
    Rob.
    Dec 2011
    IO93ok
    Just looked in my box o bits and found a 18f1330 which is pin compatible with 4k space.
    Not quite pin compatible unfortunately, ports mixed
    Rob.
    Dec 2011
    IO93ok
    Here you go Darrel -
    That display is huge at 4inch by 2 inch (See pic chip in background) Used a 16f876a in the end. That's your BigDigit code put to use as well.
    Display shows 1.65v which indicates to me that the oscillator control voltage is stable and in lock.
    Code needs some polishing especially Month but that's a work in progress :-
    ; 			        PIC16F876a
    ;                          __________
    ;                   !MCLR |1        28| RB7------D7
    ;     PLL Volt--AN0---RA0 |2        27| RB6------D6
    ;         Temp--AN1---RA1 |3        26| RB5------D5
    ;               AN2---RA2 |4        25| RB4------D4
    ;               AN3---RA3 |5        24| RB3------LCD E
    ;         NMEA data---RA4 |6        23| RB2------LCD RS
    ;               AN4---RA5 |7        22| RB1------
    ;            Ground---Vss |8        21| RB0------
    ;             OSC1---XTAL |9        20| VDD------ +5 V
    ;             OSC2---XTAL |10       19| Vss------Ground
    ;                  ---RC0 |11       18| RC7------
    ;                  ---RC1 |12       17| RC6------
    ;                  ---RC2 |13       16| RC5------
    ;           pbutton---RC3 |14       15| RC4------
    ;   Serial data out               Not used    Not used
    ' Program to display returned value of a GPS on RA4
    ' LCD in 4-BIT mode PIC16F876a controller 4Mhz clock Fuse PWRT BODEN
    @__config_HS_OSC
    @__config_BOD_OFF
    @__config_PWRT_ON
    @__config_WDT_ON
    @__config_PROTECT_OFF
    @__config_LVP_OFF
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    Define LCD_DREG PORTB          ' Port for LCD Data
    Define LCD_DBIT 4              ' Set LCD starting data bit
    Define LCD_RSBIT 2             ' Port Pin for RS bit  (pin9)
    Define LCD_EBIT 3              ' Port Pin for E bit    (pin7)
    GPSin VAR PORTA.4
    Pbutton VAR PORTC.3
    ' Initialise ADC
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel 0 Fosc 8
    PAUSE 500
    'Declare variables
    TimeOut CON 2000
    hh VAR BYTE             'hours
    latsecs VAR BYTE        'seconds latitude
    lonsecs VAR BYTE        'seconds longtitude
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    MH     VAR BYTE[6]
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    nPos  var byte
    nDig  var byte
    'Set up the digits (http://www.darreltaylor.com/files/CustChar.htm)
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #0
    'LCDOUT  $FE,$40,$02,$02,$02,$02,$02,$02,$02,$02  ' Cust Char #0
    LCDOUT  $FE,$48,$1F,$1F,$1B,$1B,$1B,$1B,$1B,$1B  ' Cust Char #1
    LCDOUT  $FE,$50,$1F,$1F,$18,$18,$18,$18,$1F,$1F  ' Cust Char #2
    LCDOUT  $FE,$58,$03,$03,$03,$03,$03,$03,$1F,$1F  ' Cust Char #3
    LCDOUT  $FE,$60,$1F,$1F,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #4
    LCDOUT  $FE,$68,$1B,$1B,$1B,$1B,$1B,$1B,$1F,$1F  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$03,$03,$03,$03,$1F,$1F  ' Cust Char #6
    LCDOUT  $FE,$78,$1F,$1F,$03,$03,$03,$03,$03,$03  ' Cust Char #7
    LCDOUT  $FE,$40,$03,$03,$03,$03,$03,$03,$03,$03  ' Cust Char #8
    LCDOut $FE,$c0," G8VLQ  March 2014  "
    Pause 3000
    GPS: 'read GPS
    SerIn2 GPSin,188,Timeout,Clock,[wait("$GPRMC"),wait(","),DEC2 hh,DEC2 mm,DEC2 ss,wait(","),fix,wait(",")_
    ,DEC2 latdeg,DEC2 latmin,wait("."),DEC2 latsecs,wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),DEC2 lonsecs,_
    LonMinDec = lonmin
    LatMinDec = latmin
    LonDir = EW
    LatDir = NS
    gosub PLL         ;pll control voltage
    GOSUB Locator     ;maidenhead locator
    GOSUB Clock      ; Large digit clock
    goto GPS
    If m = 01 then gosub January          ; show month
    If m = 02 then gosub February
    If m = 03 then gosub March
    If m = 04 then gosub April
    If m = 05 then gosub May
    If m = 06 then gosub June
    If m = 07 then gosub July
    If m = 08 then gosub August
    If m = 09 then gosub September
    If m = 10 then gosub October
    If m = 11 then gosub November
    If m = 12 then gosub December
    PLL:
    For i = 0 TO 4
    ADCON0.2 = 1                  ' Start conversion
    NotDone:
    pause 1
    IF ADCON0.2 = 1 Then NotDone
    nEXT I
    VAL = VAL/5
    ' Calculate Voltage to 2 decimal places
    volt = val * 5/1024
    Locator:
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
        GOSUB AtoB
        GOSUB fpsub
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB ItoFB
    GOSUB fpdiv
    GOSUB fpmul
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
        GOSUB AtoB
        GOSUB fpsub
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB FtoIA
    GOSUB ItoFB
    GOSUB FtoIA
    GOSUB fpmul
    Aexp_Copy    VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
    RestoreAARG:
        Aexp = Aexp_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    January:
    LCDOut $fe,$80,DEC2 d," Jan ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    February:
    LCDOut $fe,$80,DEC2 d," Feb ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    March:
    LCDOut $fe,$80,DEC2 d," Mar ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    April:
    LCDOut $fe,$80,DEC2 d," Apr ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    May:
    LCDOut $fe,$80,DEC2 d," May ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    June:
    LCDOut $fe,$80,DEC2 d," Jun ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    July:
    LCDOut $fe,$80,DEC2 d," Jul ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    August:
    LCDOut $fe,$80,DEC2 d," Aug ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    September:
    LCDOut $fe,$80,DEC2 d," Sep ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    October:
    LCDOut $fe,$80,DEC2 d," Oct ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    November:
    LCDOut $fe,$80,DEC2 d," Nov ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    December:
    LCDOut $fe,$80,DEC2 d," Dec ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    Clock:                     ;Display time
        nDig=hh dig 1 : nPos=1 : gosub displaydigit
        nDig=hh dig 0 : nPos=2 : gosub displaydigit
          npos=3 : gosub colon
        ndig=mm dig 1 : npos=4 : gosub displaydigit
        ndig=mm dig 0 : npos=5 : gosub displaydigit
          npos=6 : gosub colon
        ndig=ss dig 1 : npos=7 : gosub displaydigit
        ndig=ss dig 0 : npos=8 : gosub displaydigit
    LCDOut $fe,$80+9,"  ",DEC2 d,"-",DEC2 m,"-",DEC2 y
    LCDOut $fe,$c0+9,"    ",#volt, ".", # voltd1,# voltd2,"v"
    LCDOUT $fe,$94,"   G8VLQ    ",STR MH\6
    LCDOut $fe,$d4,DEC2 latdeg,$DF,DEC2 latmin,"'",DEC2 latsecs,NS," ",DEC2 londeg,$DF,DEC2 lonmin,"'",DEC2 lonsecs,EW                           ; ,#volt, ".", # voltd1,# voltd2,"v"   ; d4 4th line
    displaydigit:
    if ndig=0 then gosub zero
    if ndig=1 then gosub one
    if ndig=2 then gosub two
    if ndig=3 then gosub three
    if ndig=4 then gosub four
    if ndig=5 then gosub five
    if ndig=6 then gosub six
    if ndig=7 then gosub seven
    if ndig=8 then gosub eight
    if ndig=9 then gosub nine
    Zero:
    	LCDOUT $FE,$80+nPos,1
    	LCDOUT $FE,$C0+nPos,5
    One:
    	LCDOUT $FE,$80+nPos,0
    	LCDOUT $FE,$C0+nPos,0
    Two:
    	LCDOUT $FE,$80+nPos,7
    	LCDOUT $FE,$C0+nPos,2
    Three:
    	LCDOUT $FE,$80+nPos,6
    	LCDOUT $FE,$C0+nPos,3
    Four:
    	LCDOUT $FE,$80+nPos,5
    Five:
    	LCDOUT $FE,$80+nPos,2
    Six:
    Seven:
    Eight:
    	LCDOUT $FE,$80+nPos,4
    Nine:
    colon:
        lcdout $fe,$80+nPos,$A5
        lcdout $FE,$C0+nPos,$2E
    Rob.
    WooHoo!! That's Beeeeauuuutiful Rob!
    I'm so glad to see it working.
    I do have some suggestions for you about the configs, Months, volts ...
    When your ready to work on it some more.
    P.S. Nice picture of yourself too.
    Dec 2011
    IO93ok
    Glad you like it Darrel. I'm very pleased with it. Any ideas very welcome.
    I have also coded a full digit clock over the four lines. At the moment it's a standalone code due to the character loading. Is it possible to load the second set of characters, replacing the original, on a button push ? Maybe using EXT ?
    The idea was to have dual display, button push changes from that shown in pic to a full clock and back again on another push.
    Rob.
    Yes, you can have as many custom character sets as you want.
    But only one set can be loaded at a time.
    In your last code, the configs you have aren't doing anything.
    They should look like this ... make sure the defaults are commented out in the 16F876A.inc file in your PBP folder.
    @  __config  _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    And how's this look for the Months ...
    DateTime:
        LCDOut $fe,$80,DEC2 d," "
        GOSUB ShowMonth
        LCDOut " ",DEC2 y,"  ",DEC2 hh,":",DEC2 mm,":",DEC2 ss
    ShowMonth:
        Idx = (m - 1) * 3
        FOR X = Idx TO Idx + 2
            LOOKUP X,["JANFEBMARAPRMAYJUNJULAUGSEPOCTNOVDEC"],Char
            LCDOUT Char
        NEXT X
    Dec 2011
    IO93ok
    Hmm, I've always had problems with configs.
    A single line config errors out. Multiple lines actually works and sets my programmer fuses OK.
    I also have severe problems with Mpasmwin 5.20 giving hundreds of errors with PBP which I now just ignore.
    I like the Months code. That's one of the things I just couldn't get right but I was thinking that way.
    How would I go about loading the character set ? I just don't get it.
    The brain is full of different ideas for the project, so many options. Even thought of two lcds.
    Rob.
    @__config_HS_OSC
    @__config_BOD_OFF
    @__config_PWRT_ON
    @__config_WDT_ON
    @__config_LVP_OFF
    Those lines are not configuration statements.
    They are actually assembly language labels. You could use an asm GOTO to jump to any one of them.
    They will not set the configuration bits in your programmer.
    If the one line __config I gave you gives an error, it's probably the "Overwriting address 2007" error that means you didn't comment the default configs in the .inc file.
    Very bad idea.
    You should track down every error and fix it.
    How would you know if there are real errors if you always just ignore them.
    If you don't know what they mean ... get help.
    These lines from your code load the custom characters
    You'll have another set of similar lines for your 4-line big digits.
    Executing those lines will overwrite the customs characters you previously loaded.
    However, you can only have 8 custom characters at a time, and you have 9 listed above.
    The one commented as Cust Char #8, is actually Cust Char #0 and will overwrite the first Cust Char #0. Good thing they're the same.
    Dec 2011
    IO93ok
    Hi Darrel,
    Many thanks for your help.
    The code I posted was the last working example on this PC connected to the net. The actual programming pc is in another room and not net connected (deliberately). There were a couple of errors, the second $40 character set was one and a missing RETURN was another.
    The Month routine was deliberately moved down from the GPS loop. Since the post I moved it into the loop and reformatted the display lines to suit the new layout. I will however look at the array solution now.
    I've always had problems with Mpasmwin and errors. For instance the code posted has 891 errors at assembly, all of which relate to standard PBP instructions. e.g. LCDOUT alone is an error, FOR is an error etc. etc.
    This is a sample around your Locator code :-
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1049 : Illegal opcode (_LatDir)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1052 : Illegal opcode (_AtoB)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1058 : Illegal opcode (_itofa)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1061 : Illegal opcode (_fpsub)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Found label after column 1. (LABEL?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1064 : Illegal opcode (L00042)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1070 : Illegal opcode (_itofb)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1073 : Illegal opcode (_fpadd)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1076 : Illegal opcode (_SaveLon)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1082 : Illegal opcode (_itofb)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1085 : Illegal opcode (_fpdiv)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1088 : Illegal opcode (_SaveAARG)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Found label after column 1. (GOSUB?L)
    Error[122] C:\FPOINT\NMEA16F876ABIG.ASM 1091 : Illegal opcode (_ftoia)
    Warning[207] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Found label after column 1. (ADD?CWB)
    Error[108] C:\FPOINT\NMEA16F876ABIG.ASM 1094 : Illegal character (0)
    I will re-install 5.20 and see if it cures it. I'm sure years back I didn't have the problem.
    Rob.
    Dec 2011
    IO93ok
    SOLVED. Wrong MPASM Suite.
    I'm using PBP2.50 and at some point I must have upgraded the MPASM Suite to 8.90.
    I needed to delete and re-install 8.15 instead.
    I now get a complete compile and assemble without any errors.
    Just needed to think quietly about the problem.
    Rob.
    Dec 2011
    IO93ok
    Darrel,
    I tried incorporating your Month code but it causes odd errors in the ShowMonth, based on the FOR/NEXT loop and especially the idx. This is maybe where I placed it in the code but I will continue to try it.
    Right now I have completed the code using the long Month code and I'm able to toggle back and forth between all info onscreen and the fullscreen big digit clock.
    ; 			        PIC16F876a
    ;                          __________
    'wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    GPSin VAR PORTA.4
    Pbutton VAR PORTC.3
    ' Initialise ADC
    PAUSE 500
    'Declare variables
    TimeOut CON 2000
    hh VAR BYTE             'hours
    d VAR BYTE              'day
    m VAR BYTE              'month
    y VAR BYTE              'year
    butt VAR BYTE           'pushbutton variable
    marker VAR BYTE         'toggle marker
    MH     VAR BYTE[6]
    LonMinDec VAR BYTE
    LonDir    VAR BYTE
    LatMinDec VAR BYTE
    LatDir    VAR BYTE
    nPos  var byte
    nDig  var byte
    Pause 3000
    butt = 0
    marker = 0
    GPS: 'read GPS  #############################################################################################
    IF marker = 1 THEN BigClock
    LonMinDec = lonmin
    LatMinDec = latmin
    LonDir = EW
    LatDir = NS
    BUTTON Pbutton,0,100,0,butt,1,BigClockClear
    GOSUB Clock       ;Large digit clock
    goto GPS          ; ##########################################################################################
    PLL:
    For i = 0 TO 4
    NotDone:
    pause 1
    nEXT I
    VAL = VAL/5
    volt = val * 5/1024
    Locator:
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
        GOSUB AtoB
        GOSUB fpsub
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB ItoFB
    GOSUB fpdiv
    GOSUB fpmul
    GOSUB fpdiv
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB fpadd
        GOSUB AtoB
        GOSUB fpsub
    GOSUB fpadd
    GOSUB fpdiv
    GOSUB FtoIA
    GOSUB ItoFB
    GOSUB FtoIA
    GOSUB fpmul
    Aexp_Copy    VAR BYTE
    Aexp_Lon     VAR BYTE
    AARGB0_Lon   VAR BYTE
    AARGB1_Lon   VAR BYTE
    AARGB2_Lon   VAR BYTE
    SaveAARG:
        Aexp_Copy = Aexp
    RestoreAARG:
        Aexp = Aexp_Copy
    AtoB:
        Bexp = Aexp
        BARGB0 = AARGB0
        BARGB1 = AARGB1
        BARGB2 = AARGB2
    SaveLon:
        Aexp_Lon = Aexp
        AARGB0_Lon = AARGB0
        AARGB1_Lon = AARGB1
        AARGB2_Lon = AARGB2
    RestoreLon:
        Aexp = Aexp_Lon
        AARGB0 = AARGB0_Lon
        AARGB1 = AARGB1_Lon
        AARGB2 = AARGB2_Lon
    January:
    LCDOut $fe,$80+9,DEC2 d," Jan ","20",DEC2 y
    February:
    LCDOut $fe,$80+9,DEC2 d," Feb ","20",DEC2 y
    March:
    LCDOut $fe,$80+9,DEC2 d," Mar ","20",DEC2 y
    April:
    LCDOut $fe,$80+9,DEC2 d," Apr ","20",DEC2 y
    May:
    LCDOut $fe,$80+9,DEC2 d," May ","20",DEC2 y
    June:
    LCDOut $fe,$80+9,DEC2 d," Jun ","20",DEC2 y
    July:
    LCDOut $fe,$80+9,DEC2 d," Jul ","20",DEC2 y
    August:
    LCDOut $fe,$80+9,DEC2 d," Aug ","20",DEC2 y
    September:
    LCDOut $fe,$80+9,DEC2 d," Sep ","20",DEC2 y
    October:
    LCDOut $fe,$80+9,DEC2 d," Oct ","20",DEC2 y
    November:
    LCDOut $fe,$80+9,DEC2 d," Nov ","20",DEC2 y
    December:
    LCDOut $fe,$80+9,DEC2 d," Dec ","20",DEC2 y
    ClockClear:
    marker = 0
    GOTO GPS
    Clock:
                         ;Display time
        nDig=hh dig 1 : nPos=0 : gosub displaydigit
        nDig=hh dig 0 : nPos=1 : gosub displaydigit
          npos=2 : gosub colon
        ndig=mm dig 1 : npos=3 : gosub displaydigit
        ndig=mm dig 0 : npos=4 : gosub displaydigit
          npos=5 : gosub colon
        ndig=ss dig 1 : npos=6 : gosub displaydigit
        ndig=ss dig 0 : npos=7 : gosub displaydigit
    displaydigit:
    Zero:
    One:
    Two:
    Three:
    Four:
    Five:
    Six:
    Seven:
    Eight:
    Nine:
    colon:
        lcdout $FE,$C0+nPos,$A5
    BigClockClear:
    marker = 1
    BigClock:
    LCDOUT  $FE,$40,$07,$07,$07,$07,$07,$07,$07,$07  ' Cust Char #0
    LCDOUT  $FE,$48,$1C,$1C,$1C,$1C,$1C,$1C,$1C,$1C  ' Cust Char #1
    LCDOUT  $FE,$50,$03,$07,$0F,$1E,$1C,$1C,$1C,$1C  ' Cust Char #2
    LCDOUT  $FE,$58,$18,$1C,$1E,$0F,$07,$07,$07,$07  ' Cust Char #3
    LCDOUT  $FE,$60,$1C,$1C,$1C,$1C,$1E,$0F,$07,$03  ' Cust Char #4
    LCDOUT  $FE,$68,$07,$07,$07,$07,$0F,$1E,$1C,$18  ' Cust Char #5
    LCDOUT  $FE,$70,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #6
    LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #7
    BUTTON Pbutton,0,100,0,butt,1,ClockClear
                         ;Display time
        nDig=hh dig 1 : nPos=0 : gosub displaydigit1
        nDig=hh dig 0 : nPos=3 : gosub displaydigit1
          npos=6 : gosub colon1
        ndig=mm dig 1 : npos=7 : gosub displaydigit1
        ndig=mm dig 0 : npos=10 : gosub displaydigit1
          npos=13 : gosub colon1
        ndig=ss dig 1 : npos=14 : gosub displaydigit1
        ndig=ss dig 0 : npos=17 : gosub displaydigit1
    GOTO GPS
    displaydigit1:
    if ndig=0 then gosub Zero1
    if ndig=1 then gosub One1
    if ndig=2 then gosub Two1
    if ndig=3 then gosub Three1
    if ndig=4 then gosub Four1
    if ndig=5 then gosub Five1
    if ndig=6 then gosub Six1
    if ndig=7 then gosub Seven1
    if ndig=8 then gosub Eight1
    if ndig=9 then gosub Nine1
    Zero1:
        LCDOUT $FE,$81+nPos,3
    	LCDOUT $FE,$C0+nPos,1
        LCDOUT $FE,$C1+nPos,0
    	LCDOUT $FE,$94+nPos,1
        LCDOUT $FE,$95+nPos,0
    	LCDOUT $FE,$D4+nPos,4
        LCDOUT $FE,$D5+nPos,5
    One1:
        LCDOUT $FE,$80+nPos," "
    	LCDOUT $FE,$81+nPos,0
    	LCDOUT $FE,$C0+nPos," "
    	LCDOUT $FE,$94+nPos," "
    	LCDOUT $FE,$D4+nPos," "
    	LCDOUT $FE,$D5+nPos,0
    Two1:
    	LCDOUT $FE,$C0+nPos,7
    	LCDOUT $FE,$C1+nPos,5
    	LCDOUT $FE,$95+nPos," "
    	LCDOUT $FE,$D5+nPos,7
    Three1:
    	LCDOUT $FE,$95+nPos,3
    	LCDOUT $FE,$D4+nPos,7
    Four1:
    	LCDOUT $FE,$81+nPos," "
    	LCDOUT $FE,$C0+nPos,4
    	LCDOUT $FE,$C1+nPos,7
    	LCDOUT $FE,$95+nPos,1
    	LCDOUT $FE,$D5+nPos,1
    Five1:
    	LCDOUT $FE,$81+nPos,6
    	LCDOUT $FE,$C1+nPos," "
    	LCDOUT $FE,$94+nPos,6
    Six1:
    	LCDOUT $FE,$94+nPos,2
    Seven1:
    Eight1:
    Nine1:
    colon1:
        LCDOUT $FE,$C0+nPos,$A5
        LCDOUT $FE,$94+nPos,$A5
    Rob.
    Dec 2011
    IO93ok
    Forgive me oh codemaster Darrel.
    The idiot has been programming again. I am but a lowly code serf with an aged addled brain.......................................I forgot to declare the variables in your Month routine.
    Rob.
    Dec 2011
    IO93ok
    Complete working prototype system
    Rockwell GPS Module on right. PLL and TCXO board on left. TCXO is small vertical board top left. Small board at top with all wires is 7805 5v reg board.
    Rear of LCD showing piggyback decoder.
    Rob.
    Dec 2011
    IO93ok
    Darrel,
    Don't know if you are still reading this thread.
    I wondered how difficult it would be to add the final two numerical digits of the locator so that it is the full 8 digit string.
    I nearly destroyed the prototype when I took it out in the car to test the locator code. The car voltage meant the regulator board became really hot, I was afraid it would fail.
    Rob.
    The code was based on the pearl script on the Wikipedia page, which only shows how to get 6 digits.
    Do you know of somewhere that shows how to get the last two digits?
    Dec 2011
    IO93ok
    Surprisingly I do have it in asm if that helps. I think this is the applicable code after GPS string is parsed. Loc 1 to 8 are the Maidenhead.
    I wanted it all in PBP so I could do what I wanted to achieve. The final two are numeric digits. Mine is 03 if that helps re the original code.
    ;'''''''''''''''  Process LONG term '''''''''''''''''''''''''''''''''
        bcf     STATUS, C
        rrf     LongD           ;Easiest to work with LongD/2 everywhere
        btfss   STATUS, C       ;  as Loc works on 2 deg intervals
        goto    NoLongMinsUpdate
        movlw   LOW(d'6000')    ;Add 1 degree's worth of carry into the
        addwf   LongMLo         ;   minutes registers if LongD/2 has a carry
        btfsc   STATUS, C
        incf    LongMHi
        movlw   HIGH(d'6000')   ;LongM in range 0 -  12000
        addwf   LongMHi
    NoLongMinsUpdate            ;LongD' now in range 0 - 90
        btfss   NEGLONG
        goto    PosLong
        comf    LongD
        incf    LongD           ;LongD' now in 2's complement +/-90
        movf    LongMLo, w      ;Normalise LongM = 12000 - LongM
        sublw   LOW(d'12000')
        movwf   LongMLo         ;if borrow, C = 0, so increment the subtrahend
        btfss   STATUS, C
        incf    LongMHi
        movf    LongMHi, w
        sublw   HIGH(d'12000')
        movwf   LongMHi
        decf    LongD           ;Correct Degrees
    PosLong
        movlw   d'90'
        addwf   LongD           ;Normalise D' to 0-180
        movf    LongD, w
        movwf   ALo
        clrf    AHi
        movlw   d'10'
        call    DivMod          ;Mod out in A, Div out in B
        movf    BLo, W
        addlw   "A"
        movwf   Loc1
        movf    ALo, w
        addlw   "0"
        movwf   Loc3
        rrf     LongMHi         ;Divide by 4 to give range 0 - 2999
        rrf     LongMLo
        rrf     LongMHi
        rrf     LongMLo
        movlw   0x3F
        andwf   LongMHi
        movf    LongMLo, w      ;Mins * 100 / 4  DIV 125
        movwf   ALo
        movf    LongMHi, w
        movwf   AHi
        movlw   d'125'
        movf    BLo, w
        addlw   "A"
        movwf   Loc5
              ;Recover  MOD term (scaled 0 - 124) which stays in ALo
        clrf    AHi
        bcf     STATUS, C
        rlf     ALo             ;Scale to 0 - 248
        movlw   d'25'
        movf    BLo, w
        addlw   "0"
        movwf   Loc7	;Result in LongD, LongMHi, LongMLo , NEGLONG
                ;'''''''''''''''''''Now DO LAT term , LatD is already in range 0 - 90''''''''''''''''''
        btfss   NEGLAT
        goto    PosLat
        comf    LatD
        incf    LatD            ;LatD now in 2's complement +/-90
        movf    LatMLo, w       ;Normalise LatM = 6000 - LatM
        sublw   LOW(d'6000')
        movwf   LatMLo
        btfss   STATUS, C       ;if borrow, C = 0, so increment the subtrahend
        incf    LatMHi
        movf    LatMHi, w
        sublw   HIGH(d'6000')
        movwf   LatMHi
        decf    LatD            ;Correct the degrees
    PosLat
        movlw   d'90'
        addwf   LatD            ;Normalise to 0-180
        movf    LatD, w
        movwf   ALo
        clrf    AHi
        movlw   d'10'
        movf    BLo, W
        addlw   "A"
        movwf   Loc2
        movf    ALo, w
        addlw   "0"
        movwf   Loc4
        bcf     STATUS, C
        rrf     LatMHi          ;Divide by 2 to give range 0 - 2999
        rrf     LatMLo
        movf    LatMLo, w       ;Mins * 100 / 2  DIV 125
        movwf   ALo
        movf    LatMHi, w
        movwf   AHi
        movlw   d'125'
        movf    BLo, w
        addlw   "A"
        movwf   Loc6
        clrf    AHi
        bcf     STATUS, C
        movlw   d'25'
        call    DivMod
        movf    BLo, w
        addlw   "0"
        movwf   Loc8	;Result in LatD, LatMHi, LatMLo , NEGLAT
    ShowLoc
        movf    Loc1, W
        call    LcdData
        movf    Loc2, W
        call    LcdData
        movf    Loc3, W
        call    LcdData
        movf    Loc4, W
        call    LcdData
        movf    Loc5, W
        call    LcdData
        movf    Loc6, W
        call    LcdData
        movf    Loc7, W
        call    LcdData
        movf    Loc8, W
        call    LcdData
    Rob.
    Dec 2011
    IO93ok
    I have made a separate switchable sub for the Big Digit clock which just uses the h, m, s, part of the gps string called alone.
    Pic of result. As near accurate to second as code allows.
    Rob.
    Dec 2011
    IO93ok
    Darrel,
    I found this regarding the 4th pair.
    THIRD PAIR (aa-xx)
    Each field can be further divided into (24) 5 minutes (0.083333 degrees) longitudinal
    by (24) 2.5 minute (0.0416665 degrees) latitudinal zones.
    The first character encodes the longitude and the second encodes the latitude with
    letters “a” thru “x” (refer to example 3 below).
    Example 3:
    Longitude = 0.338038 {Refer to example 2}
    = 0.338038 / 0.083333
    = 4 remainder 0.004706
    = e
    (location in 5th zone)
    Latitude = 0.664048
    = 0.664048 / 0.0416665
    = 15 remainder 0.0390505
    = p
    (location in 16th zone)
    FOURTH PAIR (00-99)
    Each field can be further subdivided into (10) 30 seconds (0.008333 degrees) longitudinal
    by (10) 15 seconds (0.004166) latitudinal zones. The first character encodes the longitude
    and the second encodes the latitude with numbers “0” thru “9” (refer to example 4 below).
    Example 4:
    Longitude = 0.004706 {Refer to example 3}
    = 0.004706 / 0.008333
    = 0 remainder 0.004706
    = 0
    (location in 1st zone)
    Latitude = 0.0390505 {Refer to example 3}
    = 0.0390505 / 0.004166
    = 9 remainder 0.001556
    = 9
    (location in 10th zone)
    Rob.
    Thanks Rob, that is helpful.
    But the routines from the pearl script don't leave the variables in the right state to do the last part.
    I'm trying to recreate it in a spreadsheet to see what values the variables should have at that point.
    But finding time to look at it is difficult right now.
    Just wanted to let you know I'm still working on it.
  1. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 16:37
  2. Need Info for PBP?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 07:44
  3. Replies: 1
    Last Post: - 27th July 2008, 06:14
  4. dmx info.
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 8th May 2005, 11:54
