serin trouble with PIC16F877A
Results 1 to 20 of 20
    Default serin trouble with PIC16F877A
    I am trying to build a two part system where I will have a MC on a self-acquire satellite dish, and another MC in a handheld unit joined by BT. (This also allows for BT control from a phone or other SPP device) I fried my LCD, so I changed my attack plan to work from a terminal for now. I am having trouble getting the menu system to react properly so I hooked up another BT module TX/RX reversed and opened another terminal. I can see the terminal sending out "1" or "2" but the chip is registering it as [00]. I figured this out by putting in a debug line to echo it back before continuing the loop. I'm sure it's probly some formatting issue, but I sure don't see my error......
    __config _FOSC_HS & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CPD_OFF & _WRT_OFF & _DEBUG_OFF & _CP_OFF
    DEFINE OSC 12
    TX var PORTC.6
    RX var PORTC.7
    CNT var word
    cereal var word
    i var byte
    goto MainMenu
    CLR:
    For i = 0 to 30
    serout TX, 2, [10]
    next i
    MainMenu:
    gosub CLR
    serout Tx, 2, ["******** MAIN MENU ********", 13, 10, 10]
    serout Tx, 2, [" 1. Start Homing Sequence", 13, 10]
    serout Tx, 2, [" 2. Manual JOG Mode", 13, 10]
    serout Tx, 2, [" 3. Auto-Acquire Satellite", 13, 10]
    serout Tx, 2, [" 4. Stow Dish for Travel", 13, 10, 10]
    serout Tx, 2, ["Enter Your Selection:", 13, 10]
    Serin RX, 2, cereal
    If cereal = "1" then goto HomeDish
    If cereal = "2" then goto JogMode
    If cereal = "3" then goto AutoAcquire
    If cereal = "4" then goto StowDish
    serout TX, 2, [cereal] 'For debugging only
    goto MainMenu
    HomeDish:
    gosub CLR
    serout Tx, 2, ["******** HOME DISH ********", 13, 10, 10]
    serout Tx, 2, [" 1. Start Homing Sequence", 13, 10, 10]
    serout Tx, 2, [" 2 Abort Homing", 13, 10, 10]
    Serin RX, 2, cereal
    if cereal = "1" then goto StartHoming
    if cereal = "2" then goto MainMenu
    goto HomeDish
    JogMode:
    gosub CLR
    serout TX, 2, [" JOG MENU ", 13, 10, 10]
    serout TX, 2, ["*** UNDER CONSTRUCTION *** ", 13, 10]
    pause 3000
    goto MainMenu
    AutoAcquire:
    gosub CLR
    serout TX, 2, [" AUTO-ACQUIRE ", 13, 10, 10]
    pause 3000
    goto MainMenu
    StowDish:
    gosub CLR
    serout TX, 2, [" STOW DISH ", 13, 10, 10]
    pause 3000
    goto MainMenu
    StartHoming:
    gosub CLR
    serout TX, 2, [" Begin Homing, Homie ", 13, 10, 10]
    pause 3000
    goto MainMenu
    Jun 2009
    Sc*nthorpe, UK
    Default Re: serin trouble with PIC16F877A
    Move the pause statement
     MainMenu:
     gosub CLR
     Serin RX, 2, cereal
     goto MainMenu
    to before the serin statement. Also with serial communication I always use timeouts and qualifiers where I can.
    OK, I put a pause 500 in front of the serin command with no change. Two questons... 1.Why did you think that would work? (Not being smart here, I assume you had logical reasoning or experience that might be of some use someday) 2. Can I use multiple qualifiers? Like if I want to reject everything except 1 2 3 or 4?? thanks!
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by thasatelliteguy View Post
    You have made my day
    Jun 2009
    Sc*nthorpe, UK
    You have a loop that is constantly being executed except for the 500 pause. You Tx then instantly Rx with no time for a response to be sent.
    Well that was my thinking but obviously there is more to it than I first thought.
    try
    Serin RX, 2, 500,MainMenu,cereal
    serin will wait 500 msecs waiting for data to come in. cereal you have as a word it only needs to be a byte.
    Serin RX, 2, 500, MainMenu, cereal
    If cereal = "2" then goto JogMenu
    serout TX, 2, ["Dingleberry"]
    pause 1500
    goto MainMenu
    Now I can see the 500 passing as the Main Menu 'blinks' from being called over and over, but still no go. The above code still yields:
    [00]Dingleberry
    instead of 1Dingleberry
    Jun 2009
    Sc*nthorpe, UK
    Let me get this correct
    you are sending 1 from the terminal?
    but receive nothing?
    Jun 2009
    Sc*nthorpe, UK
    and you send the menu instructions and receive them on the terminal?
    Are you sure this is not a hardware issue? Wires not connected to correct pins or something like that.
    Jun 2009
    Sc*nthorpe, UK
    TRISC=%10000000 is missing to set portsc.7 as input.
    I did the input thing both ways...TRISC.7 = 1 and TRISC=%10000000 - no change
    I have two HC-05's hooked up to the RX and TX ports. They are hooked up backwards from one another. So I see the menu show up on one terminal screen, and I see the echo of what I type(a mirror of what the MC is receiving) show up in the other terminal on my screen on a different BT-com port. The second BT (as well as the MC presumably) receives 1 or 2 or whatever I type. But the when the menus didnt respond, I added the SEROUT and 1500 pause (to read it) and underneath the menu it'll only output [00] everytime no matter what key I hit. Just to be certain I added the next line for a total of:
    pause 1500
    and I get
    [00]Dingleberry
    then after 1.5 seonds, it dissappears and the Main Menu is reborn to await another keystroke.....
    Jun 2009
    Sc*nthorpe, UK
    This line goes to MainMenu if nothing is received after 500 ms therefore [00]Dingleberry will only be printed if something is received.
    What is going on?
    Can you send the whole code again please?
    you are correct. However, when that didnt work, I removed it again. But when its there, it just cycles back (basically blinks) to the Main Menu unless you send a keystroke, in which case you get [00]Dingleberry.
    [00] is Null is it not? Is it possible somewhere in the serin process it's trying to take the char before or after my keystroke? I tried 11, and 23 tho and still returns [00] even though 11 and 23 showed on the receiving terminal. I even tried it with a wait command llike wait for "A" then take the next char. Still same thing. And that was straight from the PBP manual....
    TRISC=%10000000
    DEFINE OSC 12
    el var PORTD.7
    TRISD.7 = 0
    low el
    az var PORTB.5
    TRISB.5 = 0
    low az
    dir var PORTD.5
    TRISD.5 = 0
    low dir
    TX var PORTC.6
    TRISC.6 = 0
    RX var PORTC.7
    CNT var word
    cereal var byte
    i var byte
    goto MainMenu
    CLR:
    For i = 0 to 30
    serout TX, 2, [10]
    next i
    MainMenu:
    gosub CLR
    pause 1500
    goto MainMenu
    HomeDish:
    gosub CLR
    Serin RX, 2, cereal
    goto HomeDish
    JogMenu:
    gosub CLR
    serout TX, 2, ["1. Elevation", 13, 10]
    serout tx, 2, ["2. Azimuth", 13, 10]
    serout tx, 2, ["3. Skew", 13, 10]
    serout tx, 2, ["4. Main Menu", 13, 10, 10]
    serout tx, 2, ["Enter Your Selection:"]
    serin RX, 2, cereal
    goto MainMenu
    AutoAcquire:
    gosub CLR
    pause 3000
    goto MainMenu
    StowDish:
    gosub CLR
    pause 3000
    goto MainMenu
    StartHoming:
    gosub CLR
    pause 3000
    goto MainMenu
    TestPattern:
    HIGH el
    low el
    high dir
    pause 50
    high el
    low el
    low dir
    HIGH az
    low az
    high dir
    pause 50
    high az
    low az
    low dir
    goto TestPattern
    Man! I know this has to be something crazy simple to fix. This was the basis of my very first PIC project 6 weeks ago when I used a PICaxe 20M2 to build a BT controlled tank to pull wire under houses. It worked beautifully! But alas, PICAXE is a lil different from PBP, and I wiped the bootloader from that chip as soon as I got my picKIT3. It sux too cuz I want my tank running again and I cant do that either until I solve this same issue.......
    Jun 2009
    Sc*nthorpe, UK
    I agree with you it has to be something simple.
    Cut down the program to the bare minimum and test.
     DEFINE OSC 12
     TX var PORTC.6
     RX var PORTC.7
     cereal var byte
     i var byte
     For i = 0 to 30
     serout TX, 2, [10]
     next i
     MainMenu:
     goto MainMenu
    Jun 2009
    Sc*nthorpe, UK
    I do not understand how you are getting [00]Dingleberry surely it should be 00Dingleberry.
    Apr 2011
    Welches, Oregon
    Your comment about getting "[00]Dingleberry" makes me wonder...
    Why would you get two zeros? Your not formatting "cereal" with DEC - or any qualifier. Perhaps you should; perhaps you are getting an ASCII non printing character "printed" to your output (a non-printing character of ASCII value 1 for example)? It seems to me that somewhere, something is happening as the 00 is coming from somewhere.
    You might also try adding a cereal = 65 prior to MainMenu; if you get an "A", then you'll know the serial input is getting nothing in the loop. If you don't... then something is changing the value...
    Jun 2009
    Sc*nthorpe, UK
    Amoque,
    I really do not understand the []. Where do they come from?
    Apr 2011
    Welches, Oregon
    Quote Originally Posted by EarlyBird2 View Post
    Amoque,
    I don't know... I was quoting the OP. If the output is a direct quote, there is much about it I don't understand. Why TWO zeros (in addition to the brackets)? PicBasic doesn't default to double digit display; perhaps the subroutine fails and runs through another subroutine or the WDT causes a second response. Perhaps the brackets were only added for clarity.
    For myself, I think that I'd:
    1) Set a default value for Cereal, so as to know it was changed (or not).
    2) Extend the timeout so that I could be sure that no amount of key-banging elicited an input.
    3) Format the output as DEC or BIN so as to standardize the output.
    It was the pins. I was on the hardware TX/RX pins and I guess it didnt like it.
    Do you mean it works now?
    I wouldn't repaint the menu in my loop, I'd return right below it.
  1. Having trouble with SERIN command and MAX6675
    By emerson in forum mel PIC BASIC Pro
    Last Post: - 16th April 2017, 19:48
  2. Control de puertos PIC16F877A / Port Control PIC16F877A
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 4th October 2013, 03:49
  3. i'm in trouble...help me please...
    By texas5 in forum mel PIC BASIC Pro
    Last Post: - 25th September 2008, 19:50
  4. Trouble with P.W.M
    By Muller in forum mel PIC BASIC Pro
    Last Post: - 8th April 2008, 21:18
  5. Replies: 9
    Last Post: - 4th February 2008, 19:12
