DS1302 Problem, again :(
Results 1 to 10 of 10
    Default DS1302 Problem, again :(
    Hello.
    I'm fighting with bloody DS1302 and PICBASIC PRO, but have no luck.
    I have DS1302 assembled on separate PCB with backup battery, and using Chris Savage's code on Basic Stamp, it runs just fine, time is OK, everything is OK. But, when I decided to use it with picbasic pro, it does not works.
    I have PIC16F870 and the simple code is below, I've shorted it quite much, because DS1302 is already preset and no need for time programming:
    include "MODEDEFS.BAS"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    define OSC 4
     ' ** Declare the Variables **
     B0 VAR BYTE
     B1 VAR BYTE
     B2 VAR BYTE
     RST var PORTC.3
     dq var PORTC.2
     clk var PORTC.1
    '------------------------- Read Commands For DS1302 -------------------------
    readsec con $81 ' Read seconds from DS1302
    readmin con $83 ' Read minutes from DS1302
    readhour con $85 ' Read hours from DS1302
    readdate con $87 ' Read date from DS1302
    readyear con $8D ' Read year from DS1302
    readmonth con $89 ' Read month from DS1302
    '------------------------------ Time Variables ------------------------------
    mem var byte ' Temporary data holder
    outbyte var byte ' Second byte to ds1302
    reg_adr var byte ' First byte to DS1302
    date var byte ' Date variable
    ss var byte ' Seconds variable
    mm var byte ' Minutes varibale
    hh var byte ' Hours variable
    mo var byte ' Month variable
    yr var byte ' Year variable
    '------------------------ Initial Settings For Ports ------------------------
    low rst ' Set reset pin low
    low clk ' Set clock pin low
    trisb = 0
    trisa = 0
    '----------------------- Set Initial Time Variables -------------------------
    start:
    reg_adr = readsec ' Read seconds
    gosub w_in
    ss = mem
    reg_adr = readmin ' Read minutes
    gosub w_in
    mm = mem
    reg_adr = readhour ' Read Hours
    gosub w_in
    hh = mem
    reg_adr = readyear ' Read Year
    gosub w_in
    yr = mem
    reg_adr = readdate ' Read Date
    gosub w_in
    date = mem
    reg_adr = readmonth ' Read Month
    gosub w_in
    mo = mem
    lcdout $fe,1,"TIME:",HEX2 hh,":",HEX2 mm,":",HEX2 ss
    goto start
    '----------------------- Time Commands Subroutines --------------------------
    w_in:
    mem = reg_adr ' Set mem variable to reg_adr contents
    high rst ' Activate the DS1302
    shiftout dq,clk,0, [mem] ' Send control byte
    shiftin dq,clk,1, [mem] ' Retrieve data in from the DS1302
    low rst ' Deactivate DS1302
    w_out:
    mem = outbyte ' Set mem variable to outbyte contents
    shiftout dq,clk,0, [mem] ' Send data stored in mem variable to DS1302
    The screen always shows 00:00:00, but if I unconnect the data pin, it displays FF FF FF
    What I'm doing wrong?
    I've checked all treads regarding DS1302, should be OK with this code...
    Default Re: DS1302 Problem, again :(
    I've never used the DS1307 so this is purely speculations, thinking out loud kind of stuff. The DS1302 datasheet says
    A clock cycle is a sequence of a rising edge followed by a falling edge. For data inputs, data must be valid during the rising edge of the clock and data bits are output on the falling edge of clock.
    For the SHIFTOUT you're using mode 0 (LSB first, clock idles low) which looks correct but the SHIFTIN is using mode 1 which is LSB first, clock idles low but data is read before sending clock. But since the DS1307 outputs data on the falling edge of the clock you want to read data after sending the clock. I think you should use mode 3 for the SHIFTIN.
    Hmmmm, more reading.....it also says
    Note that the first data bit to be transmitted occurs on the first falling edge after the last bit of the command byte is written.
    Which seems to indicate that the LSB of the output byte is put on the I/O-pin on the falling edge of the 8th clock pulse generated by the SHIFTOUT - looking at the timing diagram shows this so perhaps mode 1 is correct after all. But, if that is the case then you might have trouble with both pins being driven at the same time. Do you have a resistor between the dq-pin on the PIC and the I/O pin on the DS1302? If not, perhaps you should try that, something like 1k or whatever.
    Ah, like I said, just thinking out loud.....
    Bombay, India
    I am not cent % sure since I have not used the DS1307 with PBP. However, at first glance, comparing with the C code I have, it seems you have the SHIFTOUT command configured to MODE= (0)LSBFIRST+CLOCK IDLES LOW. I believe this should be MODE=(1)MSBFIRST+CLOCK IDLES LOW for it to work correctly. Both SHIFTOUT and SHIFTIN should be set to MODE=1
    Let us know if this works for you.
    Will try it later.
    I also have DS1307, but I can't get it work, even with Basic Stamp, I2C sucks, so this is why I've resorted to old beloved SPI
    I even have DS3231 board from ebay, but also can't get it to work.
    In fact, I was not able to get ANY I2C device to work (eeprom, light sensor, humidity sensor, etc).
    I've tried to adapt the code from basic stamp, but it does not works:
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    define OSC 4
    DataIO VAR PORTC.2               ' DS1302.6
    Clock VAR PORTC.1               ' DS1302.7
    CS1302 VAR PORTC.3              ' DS1302.5
    WrSecs          CON     $80             ' Write Seconds
    RdSecs          CON     $81             ' Read Seconds
    WrMins          CON     $82             ' Write Minutes
    RdMins          CON     $83             ' Read Minutes
    WrHrs           CON     $84             ' Write Hours
    RdHrs           CON     $85             ' Read Hours
    CWPr            CON     $8E             ' Write Protect Register
    WPr1            CON     $80             ' Set Write Protect
    WPr0            CON     $00             ' Clear Write Protect
    WrBurst         CON     $BE             ' Write Burst Of Data
    RdBurst         CON     $BF             ' Read Burst Of Data
    WrRam           CON     $C0             ' Write RAM Data
    RdRam           CON     $C1             ' Read RAM Data
    Hr24            CON     0               ' 24 Hour Mode
    Hr12            CON     1               ' 12 Hour Mode
    index           VAR     Byte            ' Loop Counter
    reg             VAR     Byte            ' Read/Write Address
    ioByte          VAR     Byte            ' Data To/From DS1302
    secs            VAR     Byte            ' Seconds
    mins            VAR     Byte            ' Minutes
    hrs             VAR     Byte            ' Hours
    date            VAR     Byte
    month           VAR     Byte
    day             VAR     byte             ' Day
    year            VAR     Byte            ' Year
    ampm            VAR     hrs.BIT5        ' AM/PM Flag Bit
    clockMode       VAR     hrs.BIT7        ' 12/24 Hour Mode Bit
    ampmFlag        VAR     Bit             ' 0 = AM, 1 = PM
    modeFlag        VAR     Bit             ' 0 = 24, 1 = 12 (Hours)
    work            VAR     Byte            ' Work Data
    MAINLOOP:
    GOSUB GET_TIME
    lcdout $fe,1,"T:",#SECS, " ", #MINS, " ", #HRS, " "
    PAUSE 1000
    GOTO MAINLOOP
    Get_Time:                               ' DS1302 Burst Read
      HIGH CS1302                           ' Select DS1302
      SHIFTOUT DataIO, Clock, LSBFIRST, [RdBurst]
      SHIFTIN DataIO, Clock, LSBPRE, [secs, mins, hrs, date, month, day, year]
      LOW CS1302                            ' Deselect DS1302
    Displays 0s....
    Haha, found the reason, jumper wire was faulty !
    So code from the first post works properly, just checked.
    Bombay, India
    Aha - never underestimate the value of a visual inspection.
    Dec 2011
    Sofia, BG
    Myspirtc1.pdf
    Hi all,
    Because of my specially attitude to picbasic, i want to share little xp.
    I had to move from I2C to SPI RTC, i had lack of pins and this would save me one pin.
    So i needed hardware driven SPI RTC. There is many true SPI chips, but i decide to use DS1302 with his serial interface.
    Addition of one transistor solved the problem to unity SDI and SDO lines by CE line. That way the line remains accessible for other serial
    devices. In my case this is FAT32 SD card.
    The rest was trivial. I wrote 3 simple procedures to access the chip trough microchip SPI. Well, i had issues to reorder the bytes, because $81 is a 'gay' number (do not read literally ) but that is another topic )
    Dec 2011
    Sofia, BG
    My apologies, the base emitter junction do not like reversed voltages. It's better to connect diode in series to the resistor.
    You can left the speed up capacitor but in parallel of R-D. Be careful with this capacitor, use the smallest possible. The recovery time and currents depend of how deep is the transistor in saturation. Bigger base resistor (47k+) with no capacitor is an option too.
  1. RTC Problem using DS1302
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 5th July 2010, 18:48
  2. TRIS setting for the DS1302
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2010, 01:14
  3. Using the DS1302 scratchpad RAM ?
    By Kman in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 16:27
  4. DS1302 and 18F452
    By Astro in forum mel PIC BASIC
    Last Post: - 9th May 2006, 22:02
  5. Ds1302
    By willie in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2005, 18:04
