my project Capacitive Sensing LED dimmer 12F1822 via PWM
Results 1 to 40 of 43
Threaded View
    Oct 2009
    Utah, USA
    Default my project Capacitive Sensing LED dimmer 12F1822 via PWM
    Well, After posting here a couple of days ago fishing for someone who has had success setting up the Cap Sense module on the 12F1822, and getting no response, I did some searching and was finally able to get it going.
    I found a couple of threads where HankMcSpank had tackeled it... (thanks hank)
    Which led to another thread where some correcttions reggarding the use of TMR0 vs TMR1.
    (I can't find either of those threads now or I'd post a link)
    Any way here is a little project I have wanted to do and CapSense seems to work and makes it a bit simpler.
    See attached schematic.
    This is the LED I am using... http://dx.com/p/g4-1-2w-108-lumen-35...b-dc-12v-51269
    Which makes use of Darrel's Instant Interrupts (thanks Darrel!). You will have to go get those include files from his web site dt.cambs.net
    here is the code...
    '*  Author  : Dwight and others                                 *
    '*  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/29/2013                                        *
    '*  Notes   :   PIC12F1822                                                *
      __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_SWDTEN & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
      __CONFIG _CONFIG2, _LVP_OFF
    DEFINE  OSC 8                'tell picbasic what speed the oscillator is
    INCLUDE "DT_INTS-14.bas"     '
    OSCCON = %01110010
                            '0 = 4x PLL is disabled
                            ' 1110 = 8 MHz
                            '     0 = unused
                            '      1X = Internal oscillator
    ANSELA = %00000100        'make port A.2 is analog
    TRISA  = %00000100        'port A.2 is input
    WPUA   = %00000000        'turn off weak pull ups
    APFCON = %00000001        'Alternate Pin Function Control Reg (default %00000000)
                              'move CCP to PortA.5 (for PWM output)
    OPTION_REG = %10000111
                            '1 = All weak pull-ups are disabled (except MCLR, if it is enabled)
                            ' 0 = Interrupt on falling edge of RB0/INT pin
                            '  0 = Timer0 clock is internal cycle clock (Fosc/4)
                            '   0 = Increment on low-to-high transition on RA4/T0CKI pin
                            '    0 = Prescaler is assigned to the Timer0 module
                            '     111 = 1:256 Timer0 prescaler rate
    T1CON = %11000001       'enable timer 1 (bit 0) & source the clock from the CPS module (bit 6 & 7 =11
    CPSCON0 = %10001100     'set the CPS module highest frequency availabe (for vcc mode) + timer0 clock sourced from CPS module. (BIT 1)
                            '1 = CPS module is enabled
                            ' 0 = CPS module is in the low range. Internal oscillator voltage references are used.
                            '  00 = unused
                            '    11 = Oscillator is in High Range. Charge/Discharge Current is nominally 18 µA
                            '      0 = Capacitive Sensing Oscillator Status bit (only readable)
                            '       0 = Timer0 clock source is controlled by the core/Timer0 module and is FOSC/4
    CPSCON1 = %00000010        '0010 = channel 2, (CPS2)
    CM1CON0 = 0   ' COMPARATOR OFF
    CM1CON1 = 0   ' COMPARATOR OFF
    CPS2_PRESENT    var WORD
    CPS2_THRESHOLD  var WORD
    CPS2_LAST       var WORD
    '       Software variables
    Duty    VAR WORD
    stepp   var byte
    ' ----------------[ I/O Definitions ]-----------------------------------
    FET VAR PORTA.5  ' PWM output to control the FET switch
    '       Software/Hardware initialisation
    PAUSE 50                           ' OSC settle delay
    Duty = 0
    stepp = 5
    hpwm 1,255,250                     ' Start with Light full ON
            INT_Handler   TMR0_INT,  _Timer0_Int,   pbp,  yes
    TMR0 = 0                  'clear  TIMER0
    @ INT_ENABLE  TMR0_INT    'enable timer0 interrupts
    '------------------------------< Main program >-------------------------
    pause 100   ' not a whole lot going on here
    Timer0_Int:
    @ INT_DISABLE  TMR0_INT   ' stop timer0 interrupts while we're in here
    pause 25
    CPS2_PRESENT = TMR1                                ' take a snapshot of Timer1's present count.
    CPS2_THRESHOLD = CPS2_LAST - ((CPS2_LAST/10)*2)    ' this sets the 'trigger' up for a 20% diversion (finger press)
    CPS2_LAST = CPS2_PRESENT                           ' store away the present timer0count for the next time we come into the interrupt routine
    if cps2_present < cps2_threshold then
        stepp = stepp +1
        if stepp>6 then stepp=0            ' check for rollover
        lookup stepp, [0,1,16,64,128,255,255],duty  'choose level, 5 levels plus OFF
        if stepp=6 then
            hpwm 1,0,1000    'off              ' arrive here when brightness is MAX
            pause 100                          '    So blink to let user know.
            hpwm 1,255,1000  'on
            hpwm 1,0,1000    'off
            hpwm 1,255,1000  'on              ' blink to show that you are at the highest level
        hpwm 1,duty,250                    ' else set new level                       ' button pressed so increment stepp
    pause 50
    TMR0 = 0                  ' clear TIMER0
    TMR1 = 0                  ' clear TIMER1
    @ INT_ENABLE  TMR0_INT    ' re-enable timer0 interrupt
    @ INT_RETURN
    enjoy! and tell me what you think (good or bad)
    Dwight
  1. 16F726 Capacitive sensing module
    Last Post: - 15th May 2014, 19:40
  2. Need help setting up Capacitive Sense 12F1822
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 29th November 2013, 21:10
  3. Replies: 1
    Last Post: - 6th August 2012, 10:57
  4. Capacitive sensing module on 16f1936
    By grahamg in forum mel PIC BASIC Pro
    Last Post: - 25th April 2010, 14:17
  5. mTouch capacitive sensing
    By jrprogrammer in forum mel PIC BASIC Pro
    Last Post: - 1st November 2008, 22:54
