Variable Problems for Cread
Results 1 to 2 of 2
    Default Variable Problems for Cread
    Hello,
    I'm trying to access memory locations with labels CData for ASCII characters, I am using a graphic display that does not have libraries, and it has no built-in memory characters, for both I and I have to do for now with the method I am using I have not succeeded in compiling it gives me error. Have if I can help.
    What I try to do is when I have to put a word in the display for example "Hello" this word is separated by Letters and each letter H, O, L, A has its ascii code in hexadecimal:
    "H"= $7F,$08,$08,$08,$7F,$00
    "O"=$3E,$41,$41,$41,$3E,$00
    and so on ... then go to the putting them on display in their X and Y coordinates.
    When compiling I get an error on Line 10 the variable "InDexMemoria" and not to do or convert.
    What I want is to concatenate the variable ("ASCI_") + the number of the Letter Ascii and quedase so "ASCI_72", this works butwhen compiling the variable "InDexMemoria" that goes before CData fails.
    Thanks......
    '''Code
    00 Dim X as Byte
    01 Dim InDexMemoria As String * 8
    02 Dim PosMemoria As String * 8
    03 Dim Word1 As Word
    04 Dim Temp As Byte
    05 Word1 = "H"
    06 Ini:
    07 PosMemoria = "ASCI_" ' Part of the Label for CData
    08 InDexMemoria = PosMemoria + Str$(Dec Word1 ) ' Concatenating Label + the number in ascii
    ' The variable "InDexMemoria = "ASCI_72"
    09 For X = 0 To 5
    10 Temp = CRead InDexMemoria + X '>>>>> At Compile fails me here <<<< for the Variable "InDexMemoria"
    11 DelayMS 5000
    12 Next X
    13 GoTo Ini
    14 ASCI_65:
    15 CData $7E,$11,$11,$11,$7E,$00 '65 - A
    16 ASCI_72:-
    17 CData $7F,$08,$08,$08,$7F,$00 '72 - H
    18 ASCI_76:-
    19 CData $7F,$40,$40,$40,$40,$00 '76 - L
    20 ASCI_79:-
    21 CData $3E,$41,$41,$41,$3E,$00 '79 - O
    '' ........All ASCII Code
    22 End
    Default Re: Variable Problems for Cread
    This code is not PBP. Looks like some other syntax.
    EN82fn
  1. Assigning a string variable to another string variable
    Last Post: - 2nd June 2013, 17:55
  2. variable problems
    By DmitriK in forum mel PIC BASIC Pro
    Last Post: - 5th June 2008, 21:19
  3. One variable made up of another variable
    Last Post: - 1st September 2007, 00:18
  4. Problems with variable - Advise welcome
    By tracking in forum mel PIC BASIC Pro
    Last Post: - 13th June 2005, 18:40
  5. 2k barrier variable problems
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 23:35
