Usb work 100%
but hserout not work ... wrong caracters
i use hserout for debug/gsm...
18F25J50
INCLUDE "modedefs.bas"
INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas" ; PBP Re-entry for external interrupt
config WDTEN = OFF ;WDT disabled (enabled by SWDTEN bit)
config PLLDIV = 2 ;Divide by 2 (8 MHz internal oscillator input)
config STVREN = ON ;stack overflow/underflow reset enabled
config XINST = OFF ;Extended instruction set disabled
config CPUDIV = OSC1 ;No CPU system clock divide
config CP0 = ON ;Program memory is not code-protected
config OSC = INTOSCPLL ;HSPLL ;INTOSCPLL ;Internal oscillator, PLL enabled, used by USB
config T1DIG = OFF ;Sec Osc clock source may not be selected, unless T1OSCEN = 1
config LPT1OSC = OFF ;high power Timer1 mode
config FCMEN = OFF ;Fail-Safe Clock Monitor disabled
config IESO = OFF ;Two-Sp Start-up disabled
config WDTPS = 32768 ;1:32768
config DSWDTOSC = INTOSCREF ;DSWDT uses INTOSC/INTRC as clock
config RTCOSC = INTOSCREF ;RTCC uses T1OSC/T1CKI as clock
config DSBOREN = OFF ;Zero-Power BOR disabled in Deep Sleep
config DSWDTEN = OFF ;Disabled
config DSWDTPS = 8192 ;1:8,192 (8.5 seconds)
config IOL1WAY = OFF ;IOLOCK bit can be set and cleared
config MSSP7B_EN = MSK7 ;7 Bit address masking
;config WPFP = PAGE_1 ;Write Protect Program Flash Page 0
;config WPEND = PAGE_0 ;Start protection at page 0
;config WPCFG = OFF ;Write/Erase last page protect Disabled
;config WPDIS = OFF ;WPFP[5:0], WPEND, and WPCFG bits ignored
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 20h
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1
INT_Handler USB_Handler
INT_Handler INT_INT, _Leitor, PBP, yes
endasm
;@ INT_ENABLE INT_INT ; enable external (INT) interrupts
'--- Setup USB -----------------------------------------------------------------
INCLUDE "DT_HID260.pbp"
DEFINE USB_VENDORID 6017
DEFINE USB_PRODUCTID 2000
DEFINE USB_VERSION 1
DEFINE USB_VENDORNAME "MICROSOFT"
DEFINE USB_PRODUCTNAME "USB HID"
DEFINE USB_SERIAL "001"
DEFINE USB_INSIZE 8 ; IN report is PIC to PC (8,16,32,64)
DEFINE USB_OUTSIZE 8 ; OUT report is PC to PIC
DEFINE USB_POLLIN 10 ; Polling times in mS, MIN=1 MAX=10
DEFINE USB_POLLOUT 10
; --- Each USB status LED is optional, comment them if not used ------------
; --- They can be assigned to any pin, and no further action is required ---
DEFINE USB_LEDPOLARITY 1 ; LED ON State [0 or 1] (default = 1)
DEFINE USB_PLUGGEDLED PORTB, 7 ; LED indicates if USB is connected
;DEFINE USB_TXLED PORTD, 1 ; " " data being sent to PC
;DEFINE USB_RXLED PORTD, 2 ; " " data being received from PC
Led var PORTB.7
'DEFINE OSC 8
OSCCON.6 = 1
OSCCON.5 = 1
OSCCON.4 = 1
ANCON0 = %11111111 ' Todas portas digital
ANCON1 = %00001111
ADCON0 = 0 ' ADC off
ADCON1 = 0
INTCON2.7 = 0 ' Desativa PortB Pullups
CM1CON1.7 = 0
CM2CON1.7 = 0
OSCTUNE.6 = 1 ' PLL On
PAUSE 10
LATA = 0
LATB = 0
LATC = 0
PORTA = 0
PORTB = 0
PORTC = 0
TRISA = %00011111
TRISB = %01111111
TRISC = %10000000
'INTCON2.4 = 0 ' PORTB.2 - Lo to Hi
'INTCON2.5 = 0 ' PORTB.1 - Lo to Hi
INTCON2.6 = 0 ' PORTB.0 - Lo to Hi
'while (Plugged = 0)
' PAUSE 1
'wend
hserout["------START------", 13]
Inicio
hserout["HI", 13]
GOTO Inicio
