Problem converting 12F683 code to 12F1840
Results 1 to 8 of 8
    Default Problem converting 12F683 code to 12F1840
    I'm trying to port over code from a PIC12F683 to a PIC12F1840 as I need the USART Rx/Tx. I thought I had all the config changes right, but the button connected to MCLR doesn't work (well, at least the display doesn't change so I'm assuming the interrupt isn't being fired) and the LED just stays on - no blinking. Can someone please point me to where I'm going wrong? The code lists the pin connections (the clock is provided from the CLCKOUT/OSC2 pin on a PIC16F690).
    PIC12F683 [working]
    ' Pin Connections
    ' GP0                      -> LED output
    ' GP2                      -> Mode Btn input
    ' GP5                      -> CLCKIN (CLCKOUT from PIC16F690)
    DEFINE OSC 20            ' Set oscillator 20Mhz
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
           __config _FOSC_EC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_ON & _CP_OFF & _CPD_OFF
    ' Initialization
    GPIO     = 0               ' Set initial value of port to 0
    CMCON0   = %0000111	       ' Turn off comparators
    ANSEL.0  = 0               ' Digital only on LED pin
    ANSEL.2  = 0               ' Digital only on button pin
    ADCON0.0 = 0               ' ADC is disabled
    TRISIO   = %00100100	   ' Make GPIO.2 input for mode button;
                               ' GPIO.5 input for CLCKIN
    ' The INTEDG bit of the OPTION_REG register determines on which edge the
    ' interrupt will occur. When the INTEDG bit is set, the rising edge will
    ' cause the interrupt. When the INTEDG bit is clear, the falling edge will
    OPTION_REG.6 = 1           ' 1=Rising edge (default) or button "PRESS";
                               ' 0=Falling edge or button "RELEASE"
    FlashMode_Default CON  0
    EE_FlashMode      DATA FlashMode_Default
    FlashMode         VAR  BYTE
    READ EE_FlashMode, FlashMode
    LED_0          VAR GPIO.0         ' Alias GPIO.0 as "LED_0"
    DUTY           VAR BYTE
    CYCLE          VAR BYTE
    STEP_CNTR      VAR BYTE
    Old_Flash_Mode VAR BYTE
    LGHTS_ON_MS    VAR WORD
    LGHTS_OFF_MS   VAR WORD
    ' Includes
    INCLUDE "DT_INTS-14.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"    ' Include if using PBP interrupts
                                ' --> copy both files to PBP main folder
                                ' (i.e. c:\pbp3)
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ' ASM Interrupt Definitions
    INT_LIST  macro    ; IntSource,           Label,  Type, ResetFlag?
            INT_Handler    INT_INT, _Flash_Mode_Btn,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    Cycle = 1
    STEP_CNTR = 2
    ' Set defaults
    Old_Flash_Mode = FlashMode
    GOSUB SetFlashRates
    ' Enable interrupt
    INTCON    = %10010000       ' Global int enabled (GIE), INTE enabled, INTF flag bit 0 clr
    @ INT_ENABLE   INT_INT      ; GP Port Change Interrupt
        ' Check if flash mode has changed
        IF FlashMode <> Old_Flash_Mode Then
            GOSUB SetFlashRates
        EndIF
    	' Fade in
    	For Duty = 0 TO 255 step STEP_CNTR
    		PWM LED_0, Duty, Cycle
    	Next
        ' Stay on LGHTS_ON_MS
        HIGH LED_0
    	Pause LGHTS_ON_MS
        ' Fade out
    	For Duty = 255 TO 0 STEP -STEP_CNTR
    	Next
    	' Stay off for LGHTS_OFF_MS
        Pause LGHTS_OFF_MS
    	GOTO Main
    SetFlashRates:
        If FlashMode = 0 Then
            LGHTS_ON_MS = 1500
            LGHTS_OFF_MS = 500
        ElseIf FlashMode = 1 Then
            LGHTS_ON_MS = 500
            LGHTS_OFF_MS = 1500
        Else
            LGHTS_ON_MS = 750
            LGHTS_OFF_MS = 833
        EndIf
    ' [INT - interrupt handler]
    Flash_Mode_Btn:
        ' Toggle flash mode between the 3 values (0, 1 or 2)
        FlashMode = FlashMode + 1
        If FlashMode > 2 Then FlashMode = 0
        ' Save selected running light flash mode
        WRITE EE_FlashMode, FlashMode
        PAUSE 100
        INTCON.1  = 0    ' Clear GP2/INT External Interrupt Flag
    @ INT_RETURN
    PIC12F1840 [not working]
    #DEFINE USE_LCD_FOR_DEBUG     ; comment out for non-debug use
    ' Pin Connections
    ' RA0                      -> EUSART Tx
    ' RA1                      -> EUSART Rx
    ' RA2                      -> LED output
    ' RA3                      -> Mode Btn input
    ' RA5                      -> CLCKIN (CLCKOUT from PIC16F690)
    DEFINE HSER_TXSTA 20h        ; Set transmit status and control register
    DEFINE HSER_BAUD  2400       ; Set baud rate
    ' Device Fuses
       __config _CONFIG1, _FOSC_ECH & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    ' Initialization
    pause 100                    ' As advised by Darrel Taylor for EEPROM issue
    APFCON.2 = 0                 ; Tx on RA0 for LCD display
    APFCON.7 = 0                 ; Rx on RA1
    BAUDCON.4 = 1                ; Transmit inverted data to the Tx pin
    FVRCON   = 0
    ANSELA.2 = 0                 ' Digital only on LED pin
    ANSELA.3 = 0                 ' Digital only on button pin
    TRISA    = %00001010	     ' Make RA1 & RA3 input for Rx & mode button
    FlashMode         VAR  BYTE
    LED_0          VAR PORTA.2   ' Alias PORTA.2 as "LED_0"
    DUTY           VAR BYTE
    CYCLE          VAR BYTE
    STEP_CNTR      VAR BYTE
    #IFDEF USE_LCD_FOR_DEBUG
        LCD_INST   CON 254       ' Instruction
        LCD_CLR    CON 1         ' Clear screen
        LCD_L1     CON 128       ' LCD line 1
        LCD_L2     CON 192       ' LCD line 2
    #ENDIF
    ' Includes
                                ' (i.e. c:\pbp3)
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    Cycle = 1
    STEP_CNTR = 2
    ' Set defaults
    GOSUB SetFlashRates
    ' Enable interrupt
        HSEROUT [LCD_INST, LCD_CLR]
        pause 5
        HSEROUT ["FlashMode=", DEC FlashMode, "    ", 13, 10] ' Send text followed by carriage return and linefeed
    #ENDIF
            GOSUB SetFlashRates
        EndIF
    	' Fade in
    	Next
        HIGH LED_0
    	Pause LGHTS_ON_MS
        ' Fade out
    	Next
        Pause LGHTS_OFF_MS
    	GOTO Main
    SetFlashRates:
            LGHTS_ON_MS = 1500
            LGHTS_OFF_MS = 500
            LGHTS_ON_MS = 500
            LGHTS_OFF_MS = 1500
        Else
            LGHTS_ON_MS = 750
            LGHTS_OFF_MS = 833
        EndIf
            pause 5
        #ENDIF
    Flash_Mode_Btn:
        PAUSE 100
    @ INT_RETURN
    Default Re: Problem converting 12F683 code to 12F1840
    I'm confused....
    Your code sets up DT-Ints to use INT_INT as the interrupt source for your handler but you say that you have the button connected to MCLR (RA3) which is not the INT-pin. RA3 has Interrupt on change capability and the comment at the INT_ENABLE says you're enabling IOC interrupt but you aren't.
    I'm pretty sure that you don't need to (or even should) set the GIE or INTE bits when using DT-INTS, it handles all that for you via the @ INT_ENABLE macro. You also don't need to clear the interrupt flag in the handler since you've asked DT-Ints to do that for you.
    Also your clock is internal or external?
    I'm using an external clock configuration (hence FOSC_ECH) - the CLCKOUT/OSC2 pin from a PIC16F690 (which has a 20Mhz crystal connected to OSC1 & OSC2) connects to the PIC12F1840's CLCKIN/OSC1 pin.
    I'm confused....
    Thanks Henrik. There are only 6 I/O pins on the 12F1840 and in trying to keep the EUSART Rx/Tx pins free I mistakenly connected the button input to RA3/MCLR (I do that for another code project). I do indeed want to use the INT interrupt, regardless of the comment. I've rejigged the code to this (I'm not at home so I haven't tested it yet):
    ' Pin Connections
    ' RA0                      -> EUSART Tx
    ' RA1                      -> EUSART Rx
    ' RA2                      -> Mode Btn input (INT interrupt)
    ' RA4                      -> LED_0
    ' Device Fuses
    ' Initialization
    FVRCON   = 0
    ANSELA.2 = 0                 ' Digital only on button pin
    ANSELA.4 = 0                 ' Digital only on LED pin
    TRISA    = %00000110	     ' Make RA1 & RA2 input for Rx & mode button
    FlashMode         VAR  BYTE
    LED_0          VAR PORTA.4   ' Alias PORTA.4 as "LED_0"
    DUTY           VAR BYTE
    CYCLE          VAR BYTE
    STEP_CNTR      VAR BYTE
    #ENDIF
    ' Includes
                                ' (i.e. c:\pbp3)
    Cycle = 1
    STEP_CNTR = 2
    ' Set defaults
    GOSUB SetFlashRates
    ; Henrik Olson says I don't need this
    ;INTCON    = %10010000       ' Global int enabled (GIE), INTE enabled, INTF flag bit 0 clr
    ' Enable interrupt
        pause 5
    #ENDIF
            GOSUB SetFlashRates
        EndIF
    	' Fade in
    	Next
        HIGH LED_0
    	Pause LGHTS_ON_MS
        ' Fade out
    	Next
        Pause LGHTS_OFF_MS
    	GOTO Main
    SetFlashRates:
            LGHTS_ON_MS = 1500
            LGHTS_OFF_MS = 500
            LGHTS_ON_MS = 500
            LGHTS_OFF_MS = 1500
        Else
            LGHTS_ON_MS = 750
            LGHTS_OFF_MS = 833
        EndIf
            pause 5
        #ENDIF
    Flash_Mode_Btn:
        PAUSE 100
        INTCON.1  = 0    ' Clear RA2/INT External Interrupt Flag
    @ INT_RETURN
    I've commented out the line re: set the GIE or INTE bits but left the clearing of the interrupt flag in my handler. Are you sure I don't need that?
    OK, give it a try and see if it springs to life.
    Since you have the ResetFlag "switch" set to Yes, then no you shouldn't have to reset the flag manually. I don't think there's any harm in doing it though, except wasting execution cycles.
    Thanks so much, Henrik - I greatly appreciate the help. I'll try it without the clearing the interrupt flag too.
    It's alive! It's alive!
    Noobie mistakes there, so thanks for being patient.
  1. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 08:32
  2. Problem converting data to what I need
    By oldcarguy85 in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 22:43
  3. Replies: 3
    Last Post: - 16th October 2007, 00:01
  4. Converting compiled code to unsupported PIC
    By jpadfield in forum General
    Last Post: - 20th May 2005, 19:40
  5. Converting Stamp code
    By paul.mcallister in forum General
    Last Post: - 8th February 2005, 11:48
