hserin buffer
Results 1 to 9 of 9
Thread: hserin buffer
    Default hserin buffer
    Why only a 2 byte hserin buffer? I'm communicating with MIDI (baud 31250) and I'm not seeing any way to check the hserin fast enough to prevent overflow. It over flows when I get a big packet of straight bytes.
    Any tips or tricks?
    Sep 2009
    Default Re: hserin buffer
    I read what you posted in the link. I saw the UART recieve interupt but I'm not sure what an interupt is and how it will help me.
    Sep 2009
    eg
    http://www.picbasic.co.uk/forum/showthread.php?t=11320
    Then just put received chars in array
    Get_char:
         hserin 100,noreceived,[mybyte] 'Get byte
         MyArray[Index]=mybyte
         Index=Index+1
         noreceived: 'or if timeout return
    @ INT_RETURN
    Pedja089 ... Can you explain in more detail. What i think im reading is this code sets up the hserin to continously read into an array and the program simply needs to check that array?
    Sep 2009
    When byte is received, PIC jump to Get_char, and get one char, and put it in array. Then PIC goes to do what it was doing before interrupt...
    What pedja089 posted on #4 is a Interrupt Service Routine (ISR) that is part of a bigger program.
    Interrupts might be a difficult subject for the novice, so you have to break your project in small parts and test each part, ensuring you understand the steps you take.
    Darrel Taylor has put up this extremely helpful packet for 16 or 18 series PIC controllers but to understand how to do it you have to read a little.
    Example (untested):
    1. setup the ISR for the serial receive:
                INT_Handler   RX_INT,	 _Get_char,		 PBP,  yes
    Whenever you are ready to receive characters place this command
    @ INT_ENABLE RX_INT
    Your ISR could be the above posted:
    Get_char:
         Index=Index+1
         If index>max_array-1 then
             index=0
             flag_endarray_reached=1
         EndIf
    @ INT_RETURN
    Now every time there is a character available it will be put in the array mybyte untill the end is reached.
    Then it will wrap arround and a flag will be set so you know that the array was filled up.
    Don't forget to include the appropriate files of the DT-INTS for your chip used.
    HTH,
    Haman03's Avatar
    Haman03 Guest
    Hserin buffer 16F87x serires input and output buffers are each 47 bytes.
    If you mean the hardware buffer, then NO. It is only 2 bytes deep.
  1. Replies: 2
    Last Post: - 27th July 2011, 21:06
  2. Replies: 3
    Last Post: - 12th February 2007, 18:32
  3. EasyHID and buffer entry 0
    By Demon in forum USB
    Last Post: - 19th August 2006, 19:34
  4. Input buffer
    By jrt4fun in forum Schematics
    Last Post: - 23rd March 2005, 07:49
  5. TX RX Buffer Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 14th January 2005, 01:49
