High Altitude launch platform
Results 1 to 3 of 3
    Default High Altitude launch platform
    Hi All,
    Put my hand up to build the telemetry for a "High Altitude Launch Platform" http://www.halp.co.cc
    Considering using the Altimeter Module MS5607 and reading specs can work up to 120K feet.
    ...Problem is I've "studied" the literature and didn't take long for my eyes to start glazing over when I came across the formula to allow for temperature compensation.
    If someone has already interface to the MS5607 and could provide he relevant code would be very appreciated!
    Or advise a suitable alternative.
    Rob.
    P.S. Also plan to use a GPS module to track it's position (& height), apparently GPS devices are coded to not exceed a ceiling limit of 30000 feet??
    Default Re: High Altitude launch platform
    Quote Originally Posted by robertg View Post
    Hi All,
    Some may be limited but many work higher, 60,000ft seems to be an average limit and 700 knots for speed.I have an old Holux and that does 39000ft ( tested in aircraft) also a HK data logger that does the same. Some careful Googling and you will find specs, though many sellers do not show their limits, you may have to contact them. Found this site http://showcase.netins.net/web/walli...vrsvs60kft.htm
    But 60K is still short of the target height.
    Can anyone suggest something else?
    Rob.
  1. Lookup tables for Altitude determination
    Last Post: - 20th November 2011, 22:22
  2. Use of HIGH and LOW for pin outputs
    By rnuke77 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2011, 18:40
  3. How to set a pin high an keep it there?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 16:01
  4. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 11:50
  5. High End Pre with PIC 16F876A
    By abidr in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 08:13
