Serout2 at 9600 problem
Results 1 to 5 of 5
    May 2012
    Default Serout2 at 9600 problem
    Hello,
    My code is:
    DEFINE OSC 8
    OSCCON = %01110000
    __CONFIG _CONFIG1L, _PLLDIV_2_1L ; Divide by 2 (8 MHz oscillator input)
    __CONFIG _CONFIG1H, _FOSC_HS_1H
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L
    include "modedefs.bas"
    ADCON1 = 15 ' Set all I/Os to Digital
    CMCON = 7 ' Disable Comparators
    high Led_1
    Serout2 Portc.1,84,["Test",10,12]
    pause 200
    Goto Main
    I'm using a 8MHz Cristal, and define it at the begining of the program. The 84 at serout command is for 9600, but it sends the text at 2400...
    Anyone understand why?
    Nuno
    Default Re: Serout2 at 9600 problem
    You did not give the chip you are using.
    But this may give you a clue.
    http://www.picbasic.co.uk/forum/show...8359#post68359
    Sep 2012
    Australia - Gold Coast
    Firstly, use TOGGLE Led_1.... as your LED will never go off
    Second, how are you verifying the rate is 2400? What terminal program are you using?
    May 2012
    Hello,
    Thank for your answers.
    I'm using a 18F2550. To verify the baud rate, i'm using the hyperterminal from windows.
    I think that my problem is in definition of the Pic, I not understand why we need to define the oscilator 2 times:
    DEFINE OSC 8
    Nuno
    Try this
    @   __CONFIG   _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @   __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    DEFINE OSC 48
