Hi All:
I am new in Picbasic Pro. I have big problem ,how to write a program to control a stepping motor in accurate timeing.
I use 16F628A and external crystal, two push switch botton(A and B), ULN2003 drive a 5V stepping motor.
The concept is when swith on... motor run clockwise something like 10steps every 2Hz all the time and if
push switch A motor run clockwise as fast as the moter can,or push swith B motor run anticlockwise fast
also. If release swith, motor run 10steps ever 2Hz all the time.
I aleady study in PIC like run stepping motor clockwise, anticlockwise, count step to run, digital clock.
I found Paul Borgmeier made ''Easy & Accurate clock wih out RTC IC''
His code like this(I do test His code realy accurate )
Use PIC 12F629
CMCON=7 'all digital for low power use
GPIO=0
TRISIO=0
OPTION_REG=%10000111 'weak pullups off, TMRO prescale = 256
INTCON=0 'interrupts off
HzTimer VAR Word '1/2 second counter (2 Hz)
HH VAR Byte ' Hours 0-23
MM VAR ByTE ' Minutes 0-59
SS VAR Byte ' Seconds 0-59
col VAR Bit ' colon 1=on, 0=0ff
HzTimer=$7A12 'for 1/2 Sec
HH=12:MM=0:SS=0:col=0 'initial conditions (12:00 O'clock noon)
ClockLoop: IF intcon.2=0 THEN ClockLoop 'Poll for TMRO overflow
INTCON.2=0 ' Clear TMRO overflow flag
HzTimer=HzTimer-$1000 'decrement timer count
IF HzTimer < $1000 THEN
IF Col=1 THEN ' update time'
SS=SS+1
GPIO.1=0 ' Turn off GP1
IF SS=60 THEN ' minute
SS=0
MM=MM+1
IF MM=60 THEN ' hour
MM=0
HH=HH+1
IF HH=24 THEN HH=0
IF HH=20 then GPIO.0 = 1 ' Turn on GP0 at 8:00pm
GPIO.1=1 ' Turn On GP1 for 1 second on the hour
ENDIF ' Adjust these to meet your needs
if MM=15 then GPIO.0 = 0 ' Turn off GP0 at 8:15pm
Col=Col+1
HzTimer=HzTimer+$7A12 ' Add 0.5 seconds to count
' Do something here but must be less than 65.5 mSec
GOTO Main 'forever
My code run stepping motor like this
Use PIC16F628A 4Mhz x'tal, with IC4060 x'tal32.768kHz generate 2Hz to PORTB.3
TRISA = %00000000
DIS VAR BYTE
J VAR BYTE
K VAR BYTE
V VAR BYTE
A VAR BYTE
D VAR BYTE
O VAR BYTE
Start : INPUT PORTB.0
INPUT PORTB.1
IF PORTB.0 = 1 THEN Setclock
IF PORTB.1 = 1 THEN Setacw
IF PORTB.0 = 0 THEN Startclock
IF PORTB.1 = 0 THEN Startclock
GOTO Start
Setclock : TRISA = 0
Mstep VAR BYTE
Steps VAR BYTE
PORTA = 0
Mstep = 0
FOR Steps = 1 TO 4
PORTA = DCD Mstep
PAUSE 3
PORTA = 0
Mstep = Mstep+1
IF Mstep>3 THEN Mstep = 0
NEXT Steps
GOTO Start
Setacw : TRISA = 0
PORTA = 0
Mstep = 0
FOR Steps = 1 TO 4
PORTA = DCD (3-Mstep)
PAUSE 3
PORTA = 0
Mstep = Mstep+1
NEXT Steps
GOTO Start
Startclock : FOR V = 0 TO 87
FOR K = 0 TO 1
GOSUB Negative
NEXT K
FOR J = 0 to 3
Motorrun : DIS = 00000001
M : PORTA = DIS
PAUSE 3
DIS = DIS<<1
NEXT J
IF DIS <> %00100000 THEN M
NEXT V
Startclock2: FOR O = 0 TO 1
FOR A = 0 TO 211
GOSUB Negative
FOR D = 0 to 3
Motorrun2 : DIS = 00000001
M2 : PORTA = DIS
PAUSE 3
DIS = DIS<<1
NEXT D
IF DIS <> %00100000 THEN M2
NEXT A
NEXT O
GOTO Startclock
Negative : IF PORTB.3 = 0 THEN Negative
Positive : IF PORTB.3 = 1 THEN Positive
I am very poor in INTERRUPT(and speak english!) so any one please tell me how to combine two code in one
program. And I don;t need IC CD4060/Xtal 32.768kHz any more.
Pichai Han from Bangkok Thailand.
