String of characters(array) to decimal value
Results 1 to 21 of 21
    Jun 2011
    Philippines
    Default String of characters(array) to decimal value
    Hello everyone, I was wondering if there is a way to convert a character to decimal value.
    ArrayWrite myArray, ["Hello"]
     for i=1 to 5
            dec_value =  myArray[i] ' is there a way to convert this to a decimal?
     next i
    So that I will have the following...
    1. dec_value = 72 ' H
    2. dec_value = 101 ' e
    3. dec_value = 108 ' l
    4. dec_value = 108 ' l
    5. dec_value = 111 ' o
    Thanks ,
    tacbanon
    Default Re: String of characters(array) to decimal value
    When you do myArray[0] = "H" the ASCII code for 'H' (which is 72) will be what ends up in the variable. If you want to display it as a decimal number on a LCD or UART then use the DEC modifier:
    LCDOUT $FE, 1, DEC myArray[0]
    myArray[0] = "H"
    myArray[0] = 72
    myArray[0] = %01001000
    myArray[0] = $48
    All of the above are equal - it's just different interpretations of the same thing, in this case the decimal value 72.
    Jun 2011
    Philippines
    Hello Henrik, thank you so much for replying. Sorry for not being clear..I want the value to be use in a SELECT CASE..
    Select Case  dec_value
    case "H"
    Serout PORTC.6, T9600, ["H", 13]
    case "e"
    Serout PORTC.6, T9600, ["e", 13]
    case "l"
    Serout PORTC.6, T9600, ["l", 13]
    case "l"
    case "o"
    Serout PORTC.6, T9600, ["o", 13]
    case "W"
    Serout PORTC.6, T9600, ["W", 13]
    END SELECT
    tacbanon
    I don't understand the problem...The code in your first post should work just fine and so should that in your latest post - have you actually TRIED this or are you just thinking to much ;-)
    myArray[0] = "H"
    If myArray[0] = "H" THEN...
    or
    If myArray[0] = 72 THEN...
    or
    If myArray[0] = 001000 THEN...
    or
    If myArray[0] = $48 THEN...
    Same thing as in my previous response - they are all the exact same thing just expressed in different ways.
    Jun 2011
    Philippines
    Okay I'm a little confused...the following is what I'm actually trying to make it work..
    porta=0  :  portb=0  :  portc=0  :  portd=0
    trisa=0  :  trisb=0  :  trisc=0  :  trisd=0
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    sutun_reg var byte[300]
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    sure var byte
    yedek var byte
    myArray VAR BYTE[11]
    myArray[0]="H"
    myArray[1]="E"
    myArray[2]="L"
    myArray[3]="L"
    myArray[4]="O"
    myArray[5]=" "
    myArray[6]="W"
    myArray[7]="O"
    myArray[8]="R"
    myArray[9]="L"
    myArray[10]="D"
    CLEAR  :  portd=255:sure=200 :GOTO oku:
    oku:
    z=11
        for i=1 to z
            harf_reg = myArray[i]
            call data_sec
            for y=0 to yinele
                call datalar
                sutun_reg[t]=veri  :  t=t+1
                adres_sec=adres_sec+1
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15
            portb=sutun_reg[t]  :  t=t+1
            porta=i
            portc=1111110:PAUSEUS sure:portc=111111
        next i
     for i=0 to 15
            porta=i
            portc=111101:pauseus sure:portc=111111
        next i
     for i=0 to 15
            porta=i
            portc=111011:pauseus sure:portc=111111
        next i
     for i=0 to 15
            porta=i
            portc=110111:pauseus sure:portc=111111
        next i
     for i=0 to 11
            porta=i
            portc=101111:pauseus sure:portc=111111
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
          ' sutun_reg[i]=sutun_reg[i+1]  ' this is for moving characters
        next i
          '  sutun_reg[240]=yedek
    goto gonder
    data_sec:
    select case harf_reg
    case "A"
    adres_sec=0  :  yinele=5  :  return
    case "B"
    adres_sec=6  :  yinele=5  :  return
    case "C"
    adres_sec=12  :  yinele=5  :  return
    case "D"
    adres_sec=18  :  yinele=5  :  return
    case "E"
    adres_sec=24  :  yinele=5  :  return
    case "F"
    adres_sec=30  :  yinele=5  :  return
    case "G"
    adres_sec=36  :  yinele=5  :  return
    case "H"
    adres_sec=42  :  yinele=5  :  return
    case "I"
    adres_sec=48  :  yinele=3  :  return
    case "i"
    adres_sec=52  :  yinele=3  :  return
    case "J"
    adres_sec=56  :  yinele=5  :  return
    case "K"
    adres_sec=62  :  yinele=5  :  return
    case "L"
    adres_sec=68  :  yinele=5  :  return
    case "M"
    adres_sec=74  :  yinele=5  :  return
    case "N"
    adres_sec=80  :  yinele=5  :  return
    case "O"
    adres_sec=86  :  yinele=5  :  return
    case "P"
    adres_sec=92  :  yinele=5  :  return
    case "Q"
    adres_sec=98  :  yinele=5  :  return
    case "R"
    adres_sec=104  :  yinele=5  :  return
    case "S"
    adres_sec=110  :  yinele=5  :  return
    case "T"
    adres_sec=116  :  yinele=5  :  return
    case "U"
    adres_sec=122  :  yinele=5  :  return
    case "ü"
    adres_sec=128  :  yinele=5  :  return
    case "V"
    adres_sec=134  :  yinele=5  :  return
    case "W"
    adres_sec=140  :  yinele=5  :  return
    case "X"
    adres_sec=146  :  yinele=5  :  return
    case "Y"
    adres_sec=152  :  yinele=5  :  return
    case "Z"
    adres_sec=158  :  yinele=5  :  return
    case " "
    adres_sec=164  :  yinele=5  :  return
    case "0"
    adres_sec=170  :  yinele=5  :  return
    case "1"
    adres_sec=176  :  yinele=3  :  return
    case "2"
    adres_sec=180  :  yinele=5  :  return
    case "3"
    adres_sec=186  :  yinele=5  :  return
    case "4"
    adres_sec=192  :  yinele=5  :  return
    case "5"
    adres_sec=198  :  yinele=5  :  return
    case "6"
    adres_sec=204  :  yinele=5  :  return
    case "7"
    adres_sec=210  :  yinele=5  :  return
    case "8"
    adres_sec=216  :  yinele=5  :  return
    case "9"
    adres_sec=222  :  yinele=5  :  return
    end select
    datalar:
     lookup adres_sec,[$7C,$0A,$09,$0A,$7C,0_      ;A
                       ,$7F,$49,$49,$49,$36,0_      ;B
                       ,$3E,$41,$41,$41,$22,0_      ;C
                       ,$7F,$41,$41,$41,$3E,0_      ;D
                       ,$7F,$49,$49,$49,$41,0_      ;E
                       ,$7F,$09,$09,$09,$01,0_      ;F
                       ,$3E,$41,$49,$49,$3A,0_      ;G
                       ,$7F,$08,$08,$08,$7F,0_      ;H
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$20,$40,$41,$3F,$01,0_      ;J
                       ,$7F,$08,$14,$22,$41,0_      ;K
                       ,$7F,$40,$40,$40,$40,0_      ;L
                       ,$7F,$02,$04,$02,$7F,0_      ;M
                       ,$7F,$04,$08,$10,$7F,0_      ;N
                       ,$3E,$41,$41,$41,$3E,0_      ;O
                       ,$7F,$09,$09,$09,$06,0_      ;P
                       ,$3E,$41,$51,$61,$3E,0_      ;Q
                       ,$7F,$09,$19,$29,$46,0_      ;R
                       ,$26,$49,$49,$49,$32,0_      ;S
                       ,$01,$01,$7F,$01,$01,0_      ;T
                       ,$3F,$40,$40,$40,$3F,0_      ;U
                       ,$1E,$41,$01,$41,$1E,0_      ;Ü
                       ,$1F,$20,$40,$20,$1F,0_      ;V
                       ,$3F,$40,$30,$40,$3F,0_      ;W
                       ,$63,$14,$08,$14,$63,0_      ;X
                       ,$07,$08,$70,$08,$07,0_      ;Y
                       ,$61,$51,$49,$45,$43,0_      ;Z
                       ,$00,$00,$00,$00,$00,0_      ;Space
                       ,$3E,$51,$49,$45,$3E,0_      ;0
                       ,$42,$7F,$40,0_              ;1
                       ,$62,$51,$49,$45,$42,0_      ;2
                       ,$22,$49,$49,$49,$36,0_      ;3
                       ,$18,$14,$12,$7F,$10,0_      ;4
                       ,$2F,$49,$49,$49,$31,0_      ;5
                       ,$3E,$49,$49,$49,$32,0_      ;6
                       ,$61,$11,$09,$05,$03,0_      ;7
                       ,$36,$49,$49,$49,$36,0_      ;8
                       ,$26,$49,$49,$49,$3E,0],veri ;9
    I think my trouble is this part..
     for i=1 to z
            call data_sec
    it produce this output (not HELLO WORLD)
    But when I modify it to this code..
     for i=1 to z
            harf_reg = 64+i
            call data_sec
    This is the output..
    What do you think I'm missing in the process?
    tacbanon
    Try using GOSUB instead of CALL.
    Also, your FOR loop starts indexing at myArray[1] instead of myArray[0] but that's not the real problem.
