Calculatorīs LCD
Results 1 to 8 of 8
    Sao Paulo - Brazil
    Question Calculatorīs LCD
    Hi firends,
    Iīm trying to drive an 8-digit LCD (calculatorīs like) with a PIC 16F877
    I know it iso not very easy, but I must use a display like that.
    Have someone ever tried to do that ?
    Some tip on how to start doing that ?
    Thank you !
    Sérgio
    do you have any part# for your LCD or datasheet. That will be helpful in case you really need help by someone here
    Sao Paulo - Brazil
    Question No embeded controller LCD
    Hi Steve,
    youīre right about the Part#
    The problem is : I have a big box full of those 8 digits calculatorīs LCD (aprox 2000 units) with no Idīs, but I know they were origanlly designed for calculators.
    I did some comparisons with some other chinese calculators and the display pinout are practically the same, with some no relevant changes (pin spacing etc)
    What I would like to know is the main idea on how to drive a regular LCD with no embeded controller and if it is possible to be done with PicBasic.
    Sérgio
    Regular LCD must have a regular frequency running on the backplane pin. HPWM can be used for that. Once you have a frequency on this pin, just try to find the according pinout.
    Basically it's not really different than to drive regular multiplexed 7 segment display
    and yes you can handle it under PBP, but it's maybe easier to use LCD driver IC for that depending on your programming skills.
    G8RPI's Avatar
    G8RPI Guest
    Default Calculator LCD
    Hi Sergio,
    Thave a look at the PIC16F913/4/6/7 series of PIC http://ww1.microchip.com/downloads/e...Doc/41250C.pdf
    These have LCD drivers built in and are supported by PBP. They will connect directly to your 7 segment calculator LCD.
    HTH,
    Robert G8RPI.
    Sao Paulo - Brazil
    Smile Thanks
    Hi Steve and Robert,
    thank you for your tips.
    I would check the pic 16F913.
    It seems to be a good option.
    bye
    Sérgio
    EDWARD's Avatar
    EDWARD Guest
    Default Lcd Control
    correct me if i am wrong. a 14 OR 16 PIN LCD WILL WORK WITH THE PicBasic Pro compiler's LCDOUT command. do a search on LCDOUT and connection diargram are around. search this place as well as google. the lcds must have a built in driver, they are really small so you might just see a black blob or tape on the lcd unit. if it meets these requirements then it will be VERY easy to program with minimal wiring, well 10 or so.
    Feb 2004
    Germany
    EDWARD,
    Sergio is talking about "Dumb" LCDs with no embedded logic at all!
    regards
    Ralph
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
