Help : Byte calculation question
Results 1 to 3 of 3
    May 2007
    Area 71
    Default Help : Byte calculation question
    how to get result C ?
    C shall be byte size integer
    input :
    A : byte , function as a ratio to B
    B : byte
    output:
    C : byte
    for example :
    if A = 100
    if B = 200
    result shall be 78 :
    Formula : C= (A /255 * B)
    To get result, I tried :
    C = A / 255 * B
    and
    C= A */ B
    but I cannot get C = 78, am I missing something ?
    Thank you
    May 2008
    Italy
    Default Re: Help : Byte calculation question
    Since the operand */ takes the middle 16 bits risult C must be a word variable
    Cheers
    Al.
    May 2007
    Area 71
    Ok, it works now . Thank you Aratti
