Decimal to binary conversion
Results 1 to 10 of 10
    Post Decimal to binary conversion
    Weeee! My 1st useful contribution to this forum (a welcome change from my habitual leeching and strolling about in left field).
    Here are code snippets to change a decimal 5 digit array into a binary 2 byte field (I use it as an address for external memory EEPROMs).
    Note: The digits are reversed and the results are concatenated in NUMHI and NUMLO.
    DATAIN VAR BYTE[5]
    DIGIT0 VAR BYTE
    DIGIT1 VAR BYTE
    DIGIT2 VAR BYTE
    DIGIT3 VAR BYTE
    DIGIT4 VAR BYTE
    BCD48 CON %00110000
    NUMHI VAR BYTE
    NUMLO VAR BYTE
    DIGIT4 = DATAIN[0] - BCD48
    DIGIT3 = DATAIN[1] - BCD48
    DIGIT2 = DATAIN[2] - BCD48
    DIGIT1 = DATAIN[3] - BCD48
    DIGIT0 = DATAIN[4] - BCD48
    ; 5 digit decimal to 16 (17) bit binary. By Peter Hemsley, March 2003.
    ; Input decimal digits in D0 (LSD) to D4 (MSD)
    ; Output 16 bit binary in NUMHI and NUMLO
    ; No temporary variables required
    ; Code size: 33 instructions
    ; Execution time: 33 cycles (excluding Call and Return)
    ; Returns carry set if > 65535 (and NUMHI-LO MOD 65536)
    ; ALTERATIONS:
    ; - variables and label prefixed with "_" to suit MPASM requirements.
    ; - variables renamed to suit individual requirements.
    ; - some instructions substituted to suit MPASM requirements.
    _DEC2BIN
    movf _DIGIT1,W ; (D1 + D3) * 2
    addwf _DIGIT3,W
    movwf _NUMLO
    rlf _NUMLO,F
    swapf _DIGIT2,W ; + D2 * 16 + D2
    addwf _DIGIT2,W
    addwf _NUMLO,F
    rlf _DIGIT4,W ; + (D4 * 2 + D3) * 256
    addwf _DIGIT3,W
    movwf _NUMHI
    rlf _NUMLO,F ; * 2
    rlf _NUMHI,F
    swapf _DIGIT3,W ; - D3 * 16
    subwf _NUMLO,F
    BTFSS 3,0 ; SKPC (not supported in MPASM
    decf _NUMHI,F
    swapf _DIGIT2,W ; + D2 * 16 + D1
    addwf _DIGIT1,W
    addwf _NUMLO,F
    BTFSC 3,0 ; SKPNC (not supported in MPASM
    incf _NUMHI,F
    swapf _DIGIT4,W ; + D4 * 16 + D0
    addwf _DIGIT0,W
    rlf _NUMLO,F ; * 2
    rlf _NUMHI,F
    addwf _NUMLO,F
    incf _NUMHI,F
    movf _DIGIT4,W ; - D4 * 256
    subwf _NUMHI,F
    swapf _DIGIT4,W ; + D4 * 16 * 256 * 2
    addwf _NUMHI,F
    addwf _NUMHI,F
    return ; Q.E.D.
    Italy
    Hi!
    The following will also work.
    Example:
    "6" "2" "3" "4" "7"
    Your 5 digits represents the decimal number 62347
    Pseudo-Code:
    variable_tenthousands = 6
    variable_thousands = 2
    variable_hundreds = 3
    variable_tens = 4
    variable_units = 7
    variable_ee_address = 0
    variable_ee_address = variable_units
    variable_ee_address = variable_ee_address + (variable_tens * 10)
    variable_ee_address = variable_ee_address + (variable_hundreds * 100)
    variable_ee_address = variable_ee_address + (variable_thousands * 1000)
    variable_ee_address = variable_ee_address + (variable_tenthousands * 10000)
    Now the variable_ee_address will contain the value 62347
    From your code I see that the 5 decimal digits (input data)
    are stored in a 5 bytes array. One byte per digit, so there is
    no binary-coded decimal. (No BCD).
    Best regards,
    Luciano
    Wink
    Hi Luciano,
    "From your code I see that the 5 decimal digits (input data)
    no binary-coded decimal. (No BCD)."
    That's why I do this:
    Using 0 as an example, I convert each digit individually from an ASCII value (0011 0000), to a binary value (0000 0000), by subtracting 48 (0011 0000). I am left with digits which are compatible with BCD format; bits in the lower nibble representing 0 to 9.
    The Assembler sub-routine takes care of doing all the math, all I had to do was prepare the digits. I tested the routine with numbers like 56,789 and it worked flawlessly, the 2nd time (11011101 11010101). LOL I had some stuff backwards and used the wrong variable as input. But that's a chair-keyboard problem, the sub-routine is good.
    I'm curious though, can you tell me how many cycles your code converts into once it's all said and done? The author of the sub-routine boasts 33 cycles, I wonder if that is truly remarkable, or if he's only 2 or 3 cycles less than your solution.
    Thumbs up
    Luciano,
    One thing that appeals to me about your solution is the ease of expansion. I can easily add digits without convoluted maths exercises. I requested an expanded version of the sub-routine from the author to support 128MBytes, but I don't like doing that. If I need additionnal digits for gigabytes for example, then his sub-routine won't work and I am unable to expand it myself.
    I really like the fact that your solution can be easily expanded with an extra variable and a simple math statement.
    I'm just curious in the resulting performance difference. Is it really a big deal?
    Italy
    Robert,
    From where do you receive the 5 digits?
    (Terminal program > Serial port)?
    Luciano
    Smile
    Hi Luciano,
    Yes, and no. Yes from the serial port, no from the terminal program, kinda. I'm using an RS232 chip into COM1. I'm using the serial window in IDE 'cause it's the only way I can transfer data down to the PIC. The reception variable is defined as VAR BYTE[5].
    You probably know my opinion of HyperTerminal if you read my post in the other thread. LOL I'm trying RealTerm, but I don't know what I have to set. I get the COM1 8N1 thing done, but I must be missing other key parameters 'cause I can't get it to work.
    My goal is to download a file in one instruction. Right now I'm sending parts of a record at a time manually. Good for testing, bad for final implementation. I have 2 sequential HSERINs for now:
    HSERIN recordtype
    IF recordtype = bla-bla-bla
    HSERIN recordformat
    When I send "recordtype-recordformat" in one SEND, it doesn't work. I'm still trying to figure what I'm missing. I can send both separately, but I can't chain them in a single string and have the program treat data section by section.
    The plan is to add several other formats, and have them processed depending on the record type prefix. I'm still learning serial communication so I can quite easily have flaws in my approach. This works on main frames, but I'm not in Kansas any more.
    Italy
    Hi Robert!
    Pseudo-Code:
    ee_address VAR WORD
    SERIN2 RxPin,84,[DEC5 ee_address]
    Type the decimal number 62347 in
    your PC terminal program.
    After receiving the 5 ASCII bytes
    the SERIN2 command will store the
    decimal value 62347 in the
    variable ee_address.
    See PBP manual for SERIN2 modifiers, works
    also with command HSERIN and HSERIN2.
    Luciano
    Red face
    Uhhh, so you're saying I'm doing this conversion for nothing?
    LMAO!
    Indeed dude.
    go to 'pin' tab then uncheck RTS and DTR... you'll be in business. Chances are because you're using an ICD adapter and those pins force your chip to reset.... that's it IMHO. OR you type in text box... you can send number
    pretty sure HSEROUT is not working also ?!?
    you may need 1 or 2 extra flow control pin for that to avoid dumb or messy download. 1 to tell the pic you're going to receive data, one from the pic to the PC to confirm you receive a byte and you're ready to receive another.
    Thanks, but oh poop...
    I guess I'm not finished getting this darned RS232 download to work if I'm a couple pins short.
  1. Binary Coded Decimal
    By -Dan- in forum mel PIC BASIC Pro
    Last Post: - 25th May 2009, 09:23
  2. Help for decimal conversion
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:20
  3. microns to decimal conversion
    By Rleonard in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 14:37
  4. Decimal to Binary Conversion
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2006, 14:58
  5. Binary to Decimal from ADC
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 27th July 2005, 18:51
