Need some examples using Lookup( I'm playing with led matrix sample code)
Results 1 to 6 of 6
Threaded View
    Jun 2011
    Philippines
    Default Need some examples using Lookup( I'm playing with led matrix sample code)
    Hi everyone, I know this is a beginner question but I need help how on how to understand this code(not mine) below and perhaps later on modify it for my application.
    Lookup yazi_reg,[30,"HELLO WORLD LED MATRIX DISPLAY "],harf_reg
    "LOOKUP statement can be used to retrieve values from a table of 8-bit constants." I got this from the manual but unfortunately I don't really get it yet.
    Hope anyone can tell me how the above line should work..and can I make an array variable to place "HELLO WORLD LED MATRIX DISPLAY "? Assuming string of characters was entered from PC - mcu.
    The whole code:
    porta=0  :  portb=0  :  portc=0  :  portd=0
    trisa=0  :  trisb=0  :  trisc=0  :  trisd=0
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    sutun_reg var byte[300]
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    sure var byte
    yedek var byte
    'Define OSC 48
    CLEAR  :  portd=255:sure=200 :GOTO oku:
    oku:
    call yazi  : yazi_reg=yazi_reg+1  :  z=harf_reg
        for i=1 to z
            call yazi  : yazi_reg=yazi_reg+1  : call data_sec
            for y=0 to yinele
                call datalar
                sutun_reg[t]=veri  :  t=t+1
                adres_sec=adres_sec+1
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15 ' 15
            portb=sutun_reg[t]  :  t=t+1
            porta=i
            portc=111110:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111101:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111011:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=110111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=101111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=011111:pauseus sure:portc=111111
        next i
        for i=0 to 15
            porta=i
            portc=111111:pauseus sure:portc=111111
        next i
         for i=0 to 15
            porta=i
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
            sutun_reg[i]=sutun_reg[i+1]
        next i
            sutun_reg[240]=yedek
    goto gonder
    yazi:
    lookup yazi_reg,[30,"HELLO WORLD LED MATRIX DISPLAY "],harf_reg
    data_sec:
    select case harf_reg
    case "A"
    adres_sec=0  :  yinele=5  :  return
    case "B"
    adres_sec=6  :  yinele=5  :  return
    case "C"
    adres_sec=12  :  yinele=5  :  return
    case "D"
    adres_sec=18  :  yinele=5  :  return
    case "E"
    adres_sec=24  :  yinele=5  :  return
    case "F"
    adres_sec=30  :  yinele=5  :  return
    case "G"
    adres_sec=36  :  yinele=5  :  return
    case "H"
    adres_sec=42  :  yinele=5  :  return
    case "I"
    adres_sec=48  :  yinele=3  :  return
    case "i"
    adres_sec=52  :  yinele=3  :  return
    case "J"
    adres_sec=56  :  yinele=5  :  return
    case "K"
    adres_sec=62  :  yinele=5  :  return
    case "L"
    adres_sec=68  :  yinele=5  :  return
    case "M"
    adres_sec=74  :  yinele=5  :  return
    case "N"
    adres_sec=80  :  yinele=5  :  return
    case "O"
    adres_sec=86  :  yinele=5  :  return
    case "P"
    adres_sec=92  :  yinele=5  :  return
    case "Q"
    adres_sec=98  :  yinele=5  :  return
    case "R"
    adres_sec=104  :  yinele=5  :  return
    case "S"
    adres_sec=110  :  yinele=5  :  return
    case "T"
    adres_sec=116  :  yinele=5  :  return
    case "U"
    adres_sec=122  :  yinele=5  :  return
    case "ü"
    adres_sec=128  :  yinele=5  :  return
    case "V"
    adres_sec=134  :  yinele=5  :  return
    case "W"
    adres_sec=140  :  yinele=5  :  return
    case "X"
    adres_sec=146  :  yinele=5  :  return
    case "Y"
    adres_sec=152  :  yinele=5  :  return
    case "Z"
    adres_sec=158  :  yinele=5  :  return
    case " "
    adres_sec=164  :  yinele=5  :  return
    case "0"
    adres_sec=170  :  yinele=5  :  return
    case "1"
    adres_sec=176  :  yinele=3  :  return
    case "2"
    adres_sec=180  :  yinele=5  :  return
    case "3"
    adres_sec=186  :  yinele=5  :  return
    case "4"
    adres_sec=192  :  yinele=5  :  return
    case "5"
    adres_sec=198  :  yinele=5  :  return
    case "6"
    adres_sec=204  :  yinele=5  :  return
    case "7"
    adres_sec=210  :  yinele=5  :  return
    case "8"
    adres_sec=216  :  yinele=5  :  return
    case "9"
    adres_sec=222  :  yinele=5  :  return
    end select
    datalar:
     lookup adres_sec,[$7C,$0A,$09,$0A,$7C,0_      ;A
                       ,$7F,$49,$49,$49,$36,0_      ;B
                       ,$3E,$41,$41,$41,$22,0_      ;C
                       ,$7F,$41,$41,$41,$3E,0_      ;D
                       ,$7F,$49,$49,$49,$41,0_      ;E
                       ,$7F,$09,$09,$09,$01,0_      ;F
                       ,$3E,$41,$49,$49,$3A,0_      ;G
                       ,$7F,$08,$08,$08,$7F,0_      ;H
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$20,$40,$41,$3F,$01,0_      ;J
                       ,$7F,$08,$14,$22,$41,0_      ;K
                       ,$7F,$40,$40,$40,$40,0_      ;L
                       ,$7F,$02,$04,$02,$7F,0_      ;M
                       ,$7F,$04,$08,$10,$7F,0_      ;N
                       ,$3E,$41,$41,$41,$3E,0_      ;O
                       ,$7F,$09,$09,$09,$06,0_      ;P
                       ,$3E,$41,$51,$61,$3E,0_      ;Q
                       ,$7F,$09,$19,$29,$46,0_      ;R
                       ,$26,$49,$49,$49,$32,0_      ;S
                       ,$01,$01,$7F,$01,$01,0_      ;T
                       ,$3F,$40,$40,$40,$3F,0_      ;U
                       ,$1E,$41,$01,$41,$1E,0_      ;Ü
                       ,$1F,$20,$40,$20,$1F,0_      ;V
                       ,$3F,$40,$30,$40,$3F,0_      ;W
                       ,$63,$14,$08,$14,$63,0_      ;X
                       ,$07,$08,$70,$08,$07,0_      ;Y
                       ,$61,$51,$49,$45,$43,0_      ;Z
                       ,$00,$00,$00,$00,$00,0_      ;Space
                       ,$3E,$51,$49,$45,$3E,0_      ;0
                       ,$42,$7F,$40,0_              ;1
                       ,$62,$51,$49,$45,$42,0_      ;2
                       ,$22,$49,$49,$49,$36,0_      ;3
                       ,$18,$14,$12,$7F,$10,0_      ;4
                       ,$2F,$49,$49,$49,$31,0_      ;5
                       ,$3E,$49,$49,$49,$32,0_      ;6
                       ,$61,$11,$09,$05,$03,0_      ;7
                       ,$36,$49,$49,$49,$36,0_      ;8
                       ,$26,$49,$49,$49,$3E,0],veri ;9
    Thanks in advance,
    tacbanon
