Varitext clock
Results 1 to 4 of 4
Thread: Varitext clock
    Jun 2004
    Question Varitext clock
    Not really a PBP question. But I have a ex-BR station clock (Big red, cluncky thing!), that seems to work ok. Except it requires a serial I/P (time data) to run. Does anyone know the data/protocols needed for this type of clock?
    If so I could mimic it with a PIC and never be late for work again!
    Thanks.
    Mar 2004
    You could also try looking at railway enthusiast websites as no doubt there are some collectors out there with the whole setup.
    More than likely (if the clocks are old) the clocks are driven via rs485
    take a look here for some info
    http://www.thebelfry.force9.co.uk/ho...s/msfclock.htm
    Is there no manufacturer name on the pcb etc?
    Rob
    Nov 2011
    Default Re: Varitext clock
    Hi srob,
    The clock will likely be a Varitext clock. They work with RS232, 485, 422 and 20mA current loop. The protocol is called TIMC - T:HH:MM:SSOWD:MM:YY CR/LF (0D0Ah)
    H= Hrs, M=mins, S=secs, DOW = day of week 0 being Sunday, D = day of month, M = month, Y= year This is transmitted at 1200baud as i remember! But the clock is configurable for anything from 300baud to 9600baud. Some also work with just the time info part (T:HH:MM:SS)
    PM me and i can send you the test software (as DOS based tool) that will send the clock time data a from PC.
    Cheers,
    Steve.
    Nov 2011
    Replace the smiley faces with 'colon D'
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  2. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 04:22
  3. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 06:27
  4. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
