Problem with Serout2 Pic18F4550
Results 1 to 13 of 13
    Apr 2010
    Default Problem with Serout2 Pic18F4550
    Hi :
    I would appreciate if anyone can help me with this problem.
    I am using SDFS code example with Pic18F4550. Although most of the code in the example is working fine , but the Serout2 is giving out garbage.
    I checked and rechecked everything , but still no success , ofcourse I don`t think the problem has anything to do with SDFS , there must be something
    that I am doing wrong with 18F4550 .
    Thanks in advance .
    Default Re: Problem with Serout2 Pic18F4550
    Is this the first time you use that PIC model?
    What CONFIG settings are you using?
    What version of PBP, MPASM, etc.
    Apr 2010
    Thanks Robert.
    this is the example which is not working :
    Define OSC 20 ' 20 MHz oscillator
    ADCON1 = 15 ' All I/O pins digital
    Pause 100
    Serout2 PORTC.6, 84, ["A,B,C"]
    I am using PBP 3 - Microcode Studio Plus 5 - MPLAB IDE v8.80 and my device programmer is melabs U2 Programmer.
    and I have put everything together based on SDFD schematics , connected to RS232 with a MAX232CPCE
    Are you sure about the oscillator setting? Didn't that change with PBP 3.0? (not sure)
    What CONFIG settings did you use? that's often a source of problems.
    Apr 2010
    Thanks Robert.
    It looks like PBP3 automatically sets the config and it works for every other PIC that I have but 18F4550.
    I tested it with various PICs and I even used a brand new 18F4550 , still getting garbage out of portc.6 .
    Did you try setting port C as output?
    TRISC=0
    Apr 2010
    TRISC=0
    I did no change .
    thanks
    Just looking at manual, they have a DEFINE for parity?
    Not sure if this applies to 18F family.
    Apr 2010
    I did try that too , I also tried other routines like HSEROUT or Debug with all the Define s required but still no luck.
    I thank you so very much Robert for trying to help me.
    Set your DEFINE at 48, regardless of your external oscillator.
    I just saw that in another thread just now.
    EDIT: Right here:
    http://www.picbasic.co.uk/forum/showthread.php?t=13039
    Apr 2010
    EDIT: Right here:
    My goodness , you are a genius . It worked . You are a life saver.
    Thanks ever so much. Robert.
    Like I once read in a men's room:
    We aim to please.
    You aim too, please.
    Apr 2010
    Amazing solution. Once again I am truly grateful .
