Trying to get an instant interrupt TMR0 counter to work on 16F873 with PBP3.0.
Similar code worked with PBP2.x, but now I'm banging my head on the wall.
Maybe just something simple I have overlooked?
What this should be doing, is presetting the tmr0 counter to 255, so it overflows with every tick,
incrementing a counter Cnt in the interrupt handler.
What is happening, is that the toggled pin in the interrupt handler is toggling every couple of
hundred us, instead of every (0.75 us + interrupt execution time).
What am I missing?
'* Name : ustimer.BAS *
'* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 12/9/2011 *
'* Version : 1.0 *
'* Notes : for 16F873 *
DEFINE OSC 12 'defines clock frequency = 12MHz
OPTION_REG = 000001 'timer0 prescaler divide by 4
'with Fosc = 12 MHz, gives timer tick of 0.75 us
ADCON1 = 000111 ' 16F87x, 16F87xA, disables a-d converter
INTCON = 100000 'allows tmr0 interrupts
TRISA = 001111
high porta.4
high porta.5
INCLUDE "DT_INTS-14.bas" ' Base Interrupt System - THIS FILE MUST BE IN THE COMPILER DIRECTORY!
INCLUDE "ReEnterPBP.bas" 'HELPER FILE FOR REINTERING PBP IN INTERRUPT- THIS FILE MUST BE IN THE COMPILER DIRECTORY!
ASM ;This assembler code is needed for the instant interrupt routines
INT_Handler TMR0_INT, _PULSETIMER, PBP, yes
Cnt var word 'count variable
wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1
@ INT_ENABLE TMR0_INT
roundabout:
' ****************** some code goes here *****************************
' the code uses the Cnt variable and resets it when the job is done
'********************* to here ****************************************
goto roundabout
'This is the tmr0 interrupt handler
PULSETIMER:
TMR0 = $FF 'presets the counter to 255, so it overflows (gives a tock)
'at every tick.
INTCON.2=0 'resets the timer0 overflow flag
TOGGLE PORTA.4 'toggle pin on every interrupt, to check timing with scope!
cnt = cnt + 1 'count every interrupt, so counter increments every 0.75 us
'or in reality 0.75 us + interrrupt handler execution time.
@ INT_RETURN
