Has anyone used MAX6952, MAX6953, MAX6955 With PBP?
Results 1 to 3 of 3
    Default Has anyone used MAX6952, MAX6953, MAX6955 With PBP?
    Hello.
    Want to use any of these chips for a school project, have them on hands, but no sample code available. Maybe someone already did something with these chips?
    Aug 2016
    Default Re: Has anyone used MAX6952, MAX6953, MAX6955 With PBP?
    Here's a simple program for the Crownhill Proton compiler that scrolls a message on a MAX6952 chip, so it should be adaptable for the PIC BASIC Pro compiler.
    ' A scrolling message on a MAX6952 chip
    ' Written for the Proton compiler by Les Johnson
        Device = 16F877
        Declare Xtal = 8
    $define CLK_Pin PORTD.2     ' Attaches to the CLK_Pin pin of the MAX6952
    $define CS_Pin PORTD.1      ' Attaches to the CS_Pin pin of the MAX6952
    $define DIN_Pin PORTD.0     ' Attaches to the DIM pin of the MAX6952
    ' Create some variables
        Dim MyText[11] As Byte = "HELLO WORLD"
        Dim MAX6952_bIndex As Byte
        Dim MAX6952_bLoop As Byte
        Dim MAX6952_bResult As Byte
        Dim MAX6952_Address As Byte
        Dim MAX6952_Data As Byte
        GoTo Main                               ' Jump to the main program loop
    ' Write a byte to the MAX6952
    ' Input     : pAddress holds the address to write
    '           : pData hold the value to write
    ' Output    : None
    ' Notes     : None
    $define MAX6952_Write(pAddress, pData) '
        MAX6952_Address = pAddress         '
        MAX6952_Data = pData               '
        GoSub _MAX6952
    _MAX6952:
    ' Send the address
        For MAX6952_bLoop = 0 To 7
            If MAX6952_Address.7 = 0 Then
                Clear DIN_Pin
                Set CLK_Pin
                Clear CLK_Pin
            Else
                Set DIN_Pin
                Set CLK_Pin
                Clear CLK_Pin
            EndIf
            MAX6952_Address = MAX6952_Address << 1
        Next
    ' Send the byte
            If MAX6952_Data.7 = 0 Then
                Clear DIN_Pin
                Set CLK_Pin
                Clear CLK_Pin
            Else
                Set DIN_Pin
                Set CLK_Pin
                Clear CLK_Pin
            EndIf
            MAX6952_Data = MAX6952_Data << 1
        Next
    ' The main program loop starts here
    ' A simple scroll on the LED display
        MAX6952_bIndex = 0
        High CS_Pin
        Low DIN_Pin
        Low CLK_Pin
        Clear CS_Pin
        MAX6952_Write($04, $01)
        Set CS_Pin
        Clear CS_Pin
        MAX6952_Write($01, $FF)
        Set CS_Pin
        Clear CS_Pin
        MAX6952_Write($02, $FF)
        Set CS_Pin
        Clear CS_Pin
        MAX6952_Write($03, $01)
        Set CS_Pin
        Clear CS_Pin
        MAX6952_Write($07, $00)         ' Set display
        Set CS_Pin
        Clear CS_Pin
        MAX6952_Write($20, "H")
        Set CS_Pin
        While
            Clear CS_Pin
            MAX6952_Write($20, MyText[MAX6952_bIndex])
            Set CS_Pin
            Clear CS_Pin
            MAX6952_Write($21,MyText[MAX6952_bIndex + 1])
            Set CS_Pin
            Clear CS_Pin
            MAX6952_Write($22,MyText[MAX6952_bIndex + 2])
            Set CS_Pin
            Clear CS_Pin
            MAX6952_Write($23,MyText[MAX6952_bIndex + 3])
            Set CS_Pin
            MAX6952_bIndex = MAX6952_bIndex + 1
            If MAX6952_bIndex >= SizeOf(MyText) Then MAX6952_bIndex = 0
            DelayMS 700
       Wend
    Aug 2016
    Here's a program that is more akin to PICBASIC Pro, so it will be a lot easier to adapt from Proton. It uses the Shout command, ShiftOut in Pro, instead of bit manipulating an SPI interface:
        Device = 16F877
        Declare Xtal = 8
    ' Output    : None
    ' Notes     : None
    $define MAX6952_Write(pAddress, pData) SHOut DIN_Pin, CLK_Pin, MsbFirst, [pAddress, pData]
        MAX6952_bIndex = 0
        High CS_Pin
        Low DIN_Pin
        Low CLK_Pin
        Clear CS_Pin
        Set CS_Pin
        Clear CS_Pin
        Set CS_Pin
        Clear CS_Pin
        Set CS_Pin
        Clear CS_Pin
        Set CS_Pin
        Clear CS_Pin
        Set CS_Pin
        Clear CS_Pin
        Set CS_Pin
        While
            Clear CS_Pin
            Set CS_Pin
            Clear CS_Pin
            Set CS_Pin
            Clear CS_Pin
            Set CS_Pin
            Clear CS_Pin
            Set CS_Pin
            DelayMS 700
       Wend
  1. Replies: 2
    Last Post: - 12th November 2014, 07:57
  2. PBP File Extension: .BAS vs .PBP
    By nedtron in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 05:48
  3. max6953 led mnatrix driver
    Last Post: - 10th March 2005, 13:36
