Determining LONG compiler
Results 1 to 3 of 3
    Sep 2005
    Campbell, CA
    Default Determining LONG compiler
    In the 2.6x versions of the compiler, you set a switch to choose PBP or PBPL.
    If there were no LONGS in your pogram, you could still compile with PBPL, and it didn't tell you.
    I think I remember someone telling me that I could put an ASM block - something like
    ifdef PBPL_USED
    LIST
    NOLIST
    But I can't remember the details. Could someone please refresh my (failing) memory on how to detect if the PBPL compiler has been used, or block it from compiling at all if I try to use PBPL?
    Charles Linquist
    Default Re: Determining LONG compiler
    PBP 2.50/2.60/PBP3
        if ((R1-R0) == 4)
            error "Compiled with PBPL"
    PBP3 only (faster)
    #IF __LONG__ = 1
        #ERROR "Compiled with PBPL"
    #ENDIF
    The second one is faster because PBP picks up the error.
    The first one has to go through the assembly process before you get the error.
    Sep 2005
    Campbell, CA
    So my next question is --
    Is there some trick that I can use that will automatically invoke PBP if no LONGs are declared, and invoke PBPL if they are?
    Charles Linquist
