Using Gsm module in Data Mode
Results 1 to 5 of 5
    brighton
    Smile Using Gsm module in Data Mode
    Hello All
    i would be interested in hearing from anyone who has used a gsm module like Wavecom for Data Transfer.
    I have successfully being able to send/receive SMS text from my remote data logger and i am just planning to add remote data download to it.
    what i am really looking for is what process i need to go through not actually the code or program. (A Link would do )
    As i have heard that might have to get data service enabled by my service provider etc.
    All The Best
    Isaac
    Lancashire
    Default Re: Using Gsm module in Data Mode
    Hi Isaac
    I`ve used the Tellit GM864 sucessfully in data mode for socket to socket communications and also http posting of data to a webserver which is probably the less complicated way to send data. I don`t know the Wavecom, but if you can get the Tellit module I could help on that.
    Cheers Pete
    brighton
    Thanks pete
    What Tellit module did you use
    Isaac
    Lancashire
    Hi Isaac
    Its the GM864-GPS which is the same as the basic GM864 but with built in GPS. I buy these direct but they are obtable from Sparkfun I think along with a dev board to mount it on.
    Cheers Pete
    Lancashire
    Where are you based?
    Cheers Pete
