Tired of only having 4 Levels of Nested Gosub's ??
Or, maybe you want to write a "Recursive" routine in PicBasic Pro ?? (MPASM required)
Now you can !!!
swStack.inc is an include file that will allow you to create up to a 48 level Software Stack on a 14-bit Core PIC.
On an 18F PIC, the Stack size is only limited by the amount of available memory.
The include file gives 2 Macro Commands:
swGosub - Software Gosub
swReturn - Return from Software Gosub
The Macro's are used almost exactly like PBP Gosub and Return, but since they are Assembly language the syntax is a little bit different.
PBP Example of normal Gosub:swGosub Example:Code:Sub1: Hserout ["Hello"] Return Gosub Sub1The Stack size must be set using the Constant "StackSize", prior to including swStack.incCode:Sub1: Hserout ["Hello"] @ swReturn @ swGosub _Sub1 ; Note the underscore before Sub1
It is limited by the largest Word Array that you can fit into 1 bank, which varies, depending on the PIC chip used. With some modifications, that maximum could be increased.
Status of the Stack can be monitored with these variables that are defined in the swStack.inc file:
Code:StackPTR Var Byte ' Pointer to current Top of Stack StackFull Var bit ' if=1, you cannot do another swGosub StackEmpty var bit ' if=1, you cannot do a swReturn SToverflow var bit ' swGosub called when Stack was Full STunderflow var bit ' swReturn called when Stack was Empty
** An overflow or underflow does not reset the PIC like a Hardware overflow would. It simply won't execute the Gosub or Return. So you will either need to make sure it never happens, or handle the error in your program. You could also modify the swStack.inc file, and have it reset the PIC on an over/underflow. **
For an example of how to use swStack.inc, see the Test_swStack.pbp program.
Thanks again to John Barrat for solving my forward declaration problem.
Hope this helps your program.
Darrel Taylor
P.S. If you like this program, do me a favor and scroll down to the bottom of this page and "Select a rating" for this thread. Thanks!
