I am using a 16F684 with the internal OSC set to 8Mhz and I'm trying to read a 5 volt PWM signal that has the following widths:
1.4mS
1.6mS
2.4mS
3.3mS
4.4mS
5.4mS
6.0mS
8.0mS
9.0mS
I know that PULSIN depends on the actual OSC speed and not the defined OSC speed. and 4MHz will have 10uS resolution, which means 8MHz should have 5uS resolution in my thinking, maybe I'm wrong. If so, then all of my numbers divide nicely by 5 and 1.4mS should equal 1400uS in my PULSIN Variable right? or something close enough.
or would my above widths measure something else in the variable?
