16F628A UART & B Ports Use
Results 1 to 5 of 5
    Jan 2012
    Default 16F628A UART & B Ports Use
    First of all I'm relatively new to PIC programming but do have some circuits working.
    I'm using the X3 experimenter board to set this project up.
    I'm doing a project that requires 8 inputs and 8 outputs and am attempting to use the 16F628A for this.
    I'm using Portb.2 USART to output commands to a device and that's working great.... but if I attempt to raise or lower the port nothing happens.
    Do I need to temporarily enable/disable the USART?
    In addition... is it possible to use all 8 of the A pins for input and all 8 of the B pins for output?
    Let me know if you need more info. to reply... Thank you... Dave
    Default Re: 16F628A UART & B Ports Use
    Why are you using PORTB.2
    What do you mean?
    And of course your code will help someone figure out what you are doing wrong
    And
    DATA sheets are your friend.
    Please read the chips DATA sheet and make it happy
    Jan 2012
    Doesn't portb.2 share the same pin with the USART transmit?
    Quote Originally Posted by DJDave View Post
    Yes it does.
    That is why it can not be
    raise or lower
    if I understand what you mean by that.
