16F1827 - Timer1 and ADC Conflict?
Results 1 to 3 of 3
    Default 16F1827 - Timer1 and ADC Conflict?
    It seems that using the ADC Timer1 stops counting (No serial data output).
    Can anyone see any conflict between ADC and Timer 1?
    Timer stops when any of the ADCIN commands is un-commended.
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _LVP_OFF & _STVREN_OFF & _BORV_25
    DEFINE OSC 8
    DEFINE INTHAND Tmr1Int
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h				'9600 baud rate, BRGH=1
    DEFINE HSER_BAUD 9600
    'DEFINE HSER_SPBRG 12
    DEFINE HSER_CLROERR 1
    DEFINE ADC_BITS 8 ' Set number of bits in result (8, 10 or 12)
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    OSCCON= %01110000
    flag1    var byte' bank0
    t_flag  var flag1.0
    t_counter   var byte
    over        var word
    an_1        var byte
    an_2        var byte
    an_3        var byte
    clear
    GOTO Init  ' jump over interrupt routine
    Tmr1Int
      ; retfie auto-restores w, status, bsr, fsr and pclath
      bcf   T1CON,TMR1ON ; stop timer 1
      bcf   PIR1,TMR1IF  ; clear over flow flag
      movlw 0xBF         ; load timer for 16,535 * 8 prescaler interrupt on 16 bit timer
      movwf TMR1H        ; load high byte
      movlw 0x69
      movwf TMR1L        ; load low byte
      bsf   T1CON,TMR1ON ; re-enable timer 1
      movlw 0x01
      bsf   _flag1,0    ;xorwf PORTB,f      ; toggle RB0
      retfie             ; Return from interrupt
    Init:
      APFCON0=%00100000
      APFCON1=%00000001
      WPUB=%11000000
      BAUDCON=%00010000
      PORTB = 0
      TRISB = %110001000
      trisa = %11111100
      adcon0 = %00001001
      adcon1 = %11110000
      CM1CON0.7=0
      CM2CON0.7=0
      CPSCON0=0
      CPSCON1=0
      daccon0=0
      ANSELA = %00011100           ' all digital. A/D disabled
      ANSELB = %01000000
      PIR1 = 0             ' clear TMR1 int flag
      PIE1 = %00000001     ' TMR1 int enabled
      INTCON = %11000000   ' global & peripheral ints enabled
      T1CON = %00110001    ' TMR1 1:8 prescale, timer1 on
      if t_flag then
        t_counter=t_counter+1
        t_flag=0
    '    HSEROUT ["Timer overflowed ",#over," times",13,10," ",#an_1,"  ",#an_2,"  ",#an_3,13,10]
      if t_counter=20 then
        t_counter=0
        over=over+1
    '  ADCIN 2,AN_1
    '  ADCIN 3,AN_2
    '  ADCIN 4,AN_3
      GOTO Main
    Default Re: 16F1827 - Timer1 and ADC Conflict?
    Insert BANKSEL T1CON in the top of your interrupt handler. If the interrupt happens during ADCIN, it's in bank1, so your writes to Timer1 registers go to the wrong registers.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Why didn't I think that??
    Thanks Bruce. I was sure it had to be something that simple...
    Works fine now. It is an impressive chip at a very good price. But a pain to setup.
