Stable ADC readings - Page 3
Page 3 of 3 FirstFirst 123
Results 81 to 91 of 91
  1. #81
    Default Re: Stable ADC readings
    You'll also need to disconect the GND line then. When you apply power to your PIC, the Hi-Z is granted on the output port, while not when you disconnect the power...
  2. #82
    California, USA
    Look again at the photo of the circuit board. That resistor near the top right is 39K ohms, NOT 3902 ohms!
    Remember, the last digit is a MULTIPLIER. It tells how many zeros to add after the other digits.
  3. #83
    it's been said at post 59
  4. #84
    Too long to remember....
    Apr 2011
    How I can set (configure) ADCON1 register when I use 16F877A external Vref on RA2, RA3
  6. #86
    Take a look at table 11-2 in the data sheet.
    ADCON1 = %00001111
    Sets the VREF pins and makes AN0 analog with the remainder digital.
    Bits 6 an 7 will set for 8 or 10 bit resolution and FOSC/x
  7. #87
    Nov 2011
    Hello to all
    I'm new in this forum and there is no other way to tell this: i'm the most ignorant in terms of electronics.
    My english also sucks, but i will try my best to communicate.
    I have the same Mazoul72's issues. I have the same steering wheel remotes and want to build some interface PIC based to enable the buttons to work with my Kenwood DNX5260BT, but in the last months i have been looking for the kenwood values, but achieve to nothing and i'm so frustrated. It appears that Pioneer's communication protocol is the resistive type, but kenwood is via data and i don't know what to do.
    Do you experts think that is possible to build one interface like the mazoul72 did and try to change the values in order to work with kenwood?
    Or, what else can i do? I have a ir remote control that works with radio. This is a good think?
    Thank you all
    Karlos
  8. #88
    Aug 2011
    Hello Karl ,
    glad to see you in this forum .
    I hope that you will find for this new type of Car radio steering wheel command's .
    I had news and very usefull help from mister_e , i hope you will have these information .
    Do you have a Line-K or Bus can wires behind your radio car ?
    Perhaps , it is the best to access to all car radio commands ??
    Regards.
    Mazoul72
  9. #89
    Nov 2011
    Hello Mazoul72
    I think that you will be the one who can help me in this particulary issue. With all the respect for the experts of this great forum, but most of the users use so tecnical language that i don't understand. My formation is in philosophy...
    Behind my radio i have the k line, althrought my car is not can bus. As far as i understand the communications protocol is 3LB.
    Some months ago i've bought all the wiring for the multifunction steering wheel of the golf4, the relay 452 and the buttons (left and right). But i'm trying to make more buttons enable, because on the Golf4 MFSW there are only 4 buttons for control the radio and 3 buttons for cruise control. At least i would like to have six buttons to radio (volume up and volume down, next and previous track, next and previous source).
    I'm very frustrated because it all remain the same and i have a gorgeous multifunction steering wheel without functions...
    Perhaps you are kindness and maybe you could make one interface for me. If you want so, i can send you the money for the materias. I don't mind to take a change and i feel that i can trust you.
    Karlos
  10. #90
    Aug 2011
    I think it is more reliable to use Kline to access to all functions (i am going to try to use these adresses Kline functions)
    i have a code but i have to work on it (Kline access based) .i will give a part of it in a new post to hope that someone can help us about it .
    Because my FIS display base code is the same than Golfop...(take on a yahoo group FREELY and freely redistriable but now it is too expensive to buy it---lot of work on it) .
    For try it , we have to use a little program to send caracters between DB25// and K-line .(see logs) LOGS.zip
  11. #91
    Aug 2011
    EDIT :
    See logs for what reacts FIS with sent caracters ... Attachment 6112
    LineK schematics , but we need a program to send values to see how reacts car radio LineK wire ...
    Name:  K-line E1_E2 PIC 16F877A.JPG
    code :
    data(data line),clk(clock)
    suma=0
    dat=126
    Shiftout data, clk, 5,[dat]
    suma=suma ^ dat
    Rem High data
    dat=237
    Shiftout dato, clk, 5,[dat]
    suma=suma ^ dat
    Rem Low data
    dat=15
    suma=suma ^ dat
    Rem High data
    It is for DATA Line send (ENA/CLOCK/DATA)
    For cont=0 To 15
    tmp=msg[cont]
    Rem dat=255 - tmp
    dat= ~ tmp
    suma=suma ^ dat
    Rem Low data
    Next cont
    'Somme de controle (sum)
    dat=suma + 1
    Rem Low data
    High ena
    posy=255
    GoSub display
    FisDw:
    Low ena
    suma=0
    dat=169
    sum=sum ^ dat
    know 255-longitude del msg
    dat=241
    sum=sum ^ dat
    It is for example ,but it is a little part of sent values .
    Thanks in advance to ameliorate or given answers .
