if ... then loop
Results 1 to 11 of 11
    Sep 2006
    Default if ... then loop
    Hi, here is a simple program, I do not see anything wrong with it, but the compiler gives the following error:
    Line 86: Endif without a matching IF..THEN
    .. If I remove the endif then I do not get an error message, but I need it there, I will have more if then loops.
    thanks
    Mainloop:
    ADCON0.2 = 1 'Start Conversion
    ADCIN 0, voltage_selector 'analog pin 1 get the 8 bit result Check the battery voltage
    If (voltage_selector >=0) AND (voltage_selector < 205) Then gosub SixVolt
    Endif
    goto Mainloop
    The ENDIF is only used if there are multiple line to to IF
    IF x = 5 THEN
      DO THIS
      DO THAT
    You can have multiple IF statements like you have it.
    IF x = 5 THEN LABEL_B
    IF x = 15 THEN LABEL_A
    Dec 2008
    Ploiesti, ROMANIA
    My opinion :
    Gosub SixVolt
    Endif
    Sorry Mr.Mackrackit, post in the same time...
    The more the merrier
    Sep 2006
    Default humm compiler problem after all
    Hi now I am getting these error messages:
    I even tried with some good working code and I still get these errors, any ideas ??
    C:\PBP>pbp -p16f88 CHARGEUR2.bas
    PICBASIC PRO(TM) Compiler 2.50c, (c) 1998, 2008 microEngineering Labs, Inc
    All Rights Reserved.
    PM Assembler 4.08, Copyright (c) 1995, 2006 microEngineering Labs, Inc.
    Error C:\PBP\CHARGEUR.ASM 3 : [235] Opcode Expected Instead of ''
    Error C:\PBP\CHARGEUR.ASM 5 : [235] Opcode Expected Instead of ''
    Error C:\PBP\CHARGEUR.ASM 9 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 9 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 10 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 10 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 11 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 11 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 12 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 12 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 13 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 13 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 14 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARGEUR.ASM 14 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARGEUR.ASM 15 : [238] Preprocessor Directive Expected
    Fatal C:\PBP\CHARGEUR.ASM 15 : [300] Too Many Errors
    C:\PBP>
    From PM.txt
    235 Opcode Expected Instead of 'Token'
    Any text starting in column 2 or later which is not a commented is assumed
    to either be an opcode, a pseudo-op or the name of a defined macro. All
    other tokens will generate this error.
    Can we see your code?
    Sep 2006
    its copied right off the net:
    Include "modedefs.bas" ' Include serial modes
    SO con 0 ' Define serial output pin
    B0 Var byte
    B1 Var byte
    mainloop:
    For B0 = 3 To 1 Step -1 ' Countdown step size
    For B1 = 0 To 10 Step B0 ' Count to 10 (or so)
    Serout SO,N2400,[#B1," "]
    Next B1
    Serout SO,N2400,[13,10] ' End of line
    Pause 100 ' Delay
    Next B0
    Goto mainloop
    Sep 2006
    I just tried to compile some of my old working codes. Nothing is compiling...weird..
    still get:
    C:\PBP>pbp -p16f88 CHARG2.bas
    Error C:\PBP\CHARG2.ASM 3 : [235] Opcode Expected Instead of ''
    Error C:\PBP\CHARG2.ASM 5 : [235] Opcode Expected Instead of ''
    Error C:\PBP\CHARG2.ASM 9 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 9 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 10 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 10 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 11 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 11 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 12 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 12 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 13 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 13 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 14 : [238] Preprocessor Directive Expected
    Error C:\PBP\CHARG2.ASM 14 : [235] Opcode Expected Instead of ' (( '
    Error C:\PBP\CHARG2.ASM 15 : [238] Preprocessor Directive Expected
    Fatal C:\PBP\CHARG2.ASM 15 : [300] Too Many Errors
    I get a good compile, with the same PM and the same PBP, using code from post 7. Don't know what to tell you.
    PICBASIC PRO(TM) Compiler 2.50c, (c) 1998, 2008 microEngineering Labs, Inc.
    243 words used.
    C:\PBP>
    http://www.scalerobotics.com
    Sep 2006
    Default Grrrr
    you know what, I just installed the compiler, did not reboot since.
    rebooted now and guess what... o Yes... somebody want to spank me ?
    sooo stupid
    Not me!!! I will pass on that!!!
