3.5" Color LCD code example - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Default Re: 3.5" Color LCD code example
    Wow, he has PBP 6.0 !
    Mar 2008
    Gerogetown, Texas
    Art
    OK, I have another post using the same glcd as a analog clock http://www.picbasic.co.uk/forum/cont...t-Analog-clock
    I don't don't recall any problems with the math. You can call any of the graphic routines in any sequence. You need to use a glcd that the display ram can be read. In this case I use the glcd in 8-bit parallel. If you SPI you can not read the display ram so objects get over written. Also with a display this big it is faster to run with parallel rather than SPI.
  3. #43
    Aug 2003
    Probably disappeared writing for chips we don't have either.
    Quote Originally Posted by DaveC3 View Post
    Art
    I'll look at the clock, you must have got lines then.
    I don't want to look at the LCD RAM, hopefully..
    Take a look at my recent posts, the way I did double buffering
    was set aside a RAM array of the capacity of a screen frame,
    and draw (your circles etc.) to the RAM array, then copy the RAM array to display
    RAM as fast as PBP can do it, then begin drawing the next frame to your RAM
    array while the current frame is being displayed.
    In that case the second buffer is the LCD's RAM.
    (So no raster, and you can't see any drawing).
    The big BUT is 320x240x3 colour components might be
    asking a lot of RAM even of the most modern pics.
    I'll need to be looking into that I guess.
    However, there's no law saying the first buffer has to be the full size
    of a screen frame, and cannot move around the physical screen.
  4. #44
    Mar 2008
    Gerogetown, Texas
    Art
    I have done the same with smaller GLCDs. This display is to large to fit it in ram (I think)
  5. #45
    Aug 2003
    I thought the RAM buffer would be a very tall order, and admittedly
    have never looked past 16F pics yet, except dspics in C.
    But I think that whatever you need to handle quickly such as display panels,
    a wave, a meter, or clock, probably doesn't need to be colour,
    or the full size of the screen, I think that whatever RAM can be afforded
    can either follow the sprite around the display,
    or the RAM buffer actually used to move the sprite around the display.
    So you can either move the position the display buffer is drawn (X-70,Y-50),
    or move the sprite within the buffer, or if it's a panel, just forget about it.
    Then your panels shouldn't interfere with the full colour static display RAM
    that can just sit there unless you overwrite it.
    I assume you can write a data slab to the display from a variable coordinate (or video RAM) address.
    I think I like the idea of cheating
