debouncing switches with a timer interrupt?
Results 1 to 28 of 28
    Dec 2009
    Kalamazoo
    Default debouncing switches with a timer interrupt?
    hi everyone,
    im experimenting with the "menu builder" application on a 18f2431 and im having a bit of a problem. it inserts a lot of "pause 200" commands, to debounce the switches, which is causing havoc on my real time timer on an lcd. if i remove the pauses, there's no debounce, and one push of a button cycles through alot of menus. i tried the portb interrupt on change, and im getting the same results. i've read some rumours that debouncing can be done using a timer interrupt. is it possible? im using 4 buttons: up, down, enter, exit. any help/idea on pseudocode will really be appreciated; portb interrupt, timer interrupt, software debounce, etc
    NAG CON WIFE!
    WIFE VAR MOOD
    Perth, Australia
    If you can change the hardware, one option would be to use capacitors across the switches. Software denounce would no longer be required.
    Otherwise you do do this:
    port b change interrupt: detects a button press and takes action, an the end of the interrupt it sets a timer so that it will overflow in say 50ms, and then disables the port b interrupt.
    when the timer interrupt goes off 50ms later it simply needs to re-enable the port b interrupt and stop the timer.
    Sep 2005
    Campbell, CA
    Could it be that you don't need a debouncer at all?
    If you are polling the pin that is connected the switch every program loop, and the loop is longer than the switch bounce time, you don't need a debounce, since it will see the transition, and the "bounces" will be over before you check the switch again.
    Charles Linquist
    Charles, I do just exactly that. In my interrupt routine. I copy th state of my button and add it to a shifted result. When the button is connected to ground with a pullup to VDD, the value after the 8 cycle (interrupt) debounce is equal to zero. When the button is released the value after the 8 cycle (interrupt) debounce is equal to 255. I use a 10 millisecond interrupt timer so the debounce time is 80 milliseconds. That way all the main has to do is interrogate debounce variable for it's value.
    May 2008
    Italy
    I would apply a flag condition to control the key state.
    False        CON  0
    True         CON  1
    KEYPRESS  VAR portXx
    KeyFlag      VAR BIT
    Counter      VAR WORD
    LOOP:
    PAUSE 1
    IF KEYPRESS = False then
    IF KeyFlag = False Then
    Counter = Counter + 1
    KeyFlag = True
    KeyFlag = False
    GOTO LOOP
    In the above snippet every time you press the key "KEYPRESS" the word variable "Counter" will increment of one unit, no matter how long you keep the key down. If you remove the flag control using pauses, it will be rather complicate to reach the same results.
    Al.
    Perth, Australia
    Quote Originally Posted by aratti View Post
    This would still require some kind of debouncing. The logic state can "bounce" a number of times when pressing a button, so if it toggles back and forth a few times it could still advance the counter more than once for a single key press if the loop is quick enough.
    May 2008
    Italy
    Contact's debouncing should be solved with proper RC filter! If proper filtering is not possible an additional IF/THEN statement should reduce greatly the debouncing effect.
    False        CON  0
    True         CON  1
    KEYPRESS  VAR portXx
    KeyFlag      VAR BIT
    Counter      VAR WORD
    LOOP:
    PAUSE 1
    KeyFlag = True
    KeyFlag = False
    IF  KEYPRESS = False THEN  KeyFlag = True    ' re-checks the key logic state
    GOTO LOOP
    Al.
    Dec 2009
    Kalamazoo
    thanks guys.
    i tried the capacitor method, and that did not work well. still skipping menu items.
    im using proteus simulation, and i tried every value of cap, 1000uf to 0.000001 uf., and everything in between.
    ill try integrate the software flag idea into the problem, and hope that it fixes it. thanks
    NAG CON WIFE!
    WIFE VAR MOOD
    Dec 2009
    Kalamazoo
    Default still not functioning
    hi all
    i tried to implement the flag idea, but still the same result. menu item cycles through 3 to 6 items with one push of a button. here's the code snippet
    RB_MainMenuLoop:
    ' BTN_PLUS is the Next Choice button
        PAUSE 1
          IF BTN_PLUS=0 THEN
          ;PAUSE 200
          IF FLAG_PLUS = 0 THEN
          bMenuPos=bMenuPos+1
          FLAG_PLUS = 1
          FLAG_PLUS = 0
          IF BTN_PLUS = 0 THEN FLAG_PLUS = 1
          ;ENDIF
          IF bMenuPos>22 THEN
             bMenuPos=1
          Goto DisplayMainMenuLoop:
    im beginning to think that debouncing is not the problem. is there any other way to skin this cat?
    NAG CON WIFE!
    WIFE VAR MOOD
    May 2008
    Italy
    Counter Var Byte
    RB_MainMenuLoop:
    PAUSE 1
    IF BTN_PLUS=0 THEN
    bMenuPos = bMenuPos + 1
    FLAG_PLUS = 1
    Counter = 0
    Pause = 10
    IF Counter > 50 THEN FLAG_PLUS = 0 : Counter = 0
    IF bMenuPos>22 THEN
    bMenuPos=1
    Try this snippet and see how it works. You can tune the PAUSE 10 and Counter > 5, to better values to suite your need.
    Al.
    Quote Originally Posted by DDDvvv View Post
    hi all
    You should understand debouncing NEED time, where ever this time comes from ( capacitor, timer ...)
    the idea of debouncing is :
    " Does the electrical state of pin still changes afer X milliseconds ??? "
    so, you can't get a correct answer before X milliseconds !!! - Obvious -
    But 200 ms is debouncing time for really poor quality switches, 20 ms can be obtained easily.
    note also switches " bounce " when closing its contact ... not when opening it !!!
    so, ... is it here THE good idea ???
    Further, May I tell you a real time timer might not be disturbed by a keypress ... - or your program is " not so good " ...
    the delay needed by the RTC to be updated is so far smaller than a key press action ...
    Aug 2005
    Michigan, USA
    Consider using a switch state latch and relatively simple logic to sample your switches and detect the "new press" state while ignoring the other switch states. Here are the switch states;
    swnew swold  switch state
      1     0    a "new press"
      1     1    still pressed
      0     1    a "new release"
      0     0    still released
    Sample the switches at a decent debounce interval (16 to 25 msecs) either in your main program loop or in a timer based interrupt service routine. You only need a few lines of code to implement the switch state logic for multiple switches (perhaps one of the PBP gurus can interpret the C code? Sorry!);
    //  swnew  ____---____-----_____   new switch sample
    //  swold  _____---____-----____   switch state latch
    //  delta  ____-__-___-____-____   changes, press or release
    //  newhi  ____-______-_________   filter out release bits
    while(1)                  //
      delay_ms(24)            // 24-msec debounce interval
      swnew = ~porta;         // sample active-lo switches
      swnew &= 0x0F;          // on RA3..RA0 pins
      swnew ^= swold;         // changes, press or release
      swold ^= swnew;         // update switch state latch
      swnew &= swold;         // filter out "new release" bits
      if(swnew)               // if any "new press" bits
      { beep();               // task a "new press" beep
      if(swnew.0)             // if RB0 "new press"
      if(swnew.1)             // if RB1 "new press"
    If you implement the method in an ISR you'll need to inclusive-or "swnew" with a "flags" register for your main program.
    Kind regards, Mike
    Sep 2005
    Campbell, CA
    The code below was written to use a momentary pushbutton switch as an ON/OFF control.
    It is written to be used in a Timer interrupt routine.
    PowerOnDelayTimer is the number of interrupts that the button must be held before turning ON the unit.
    PowerOFFDelayTimer is the number of interrupts that the button must be held before turning OFF the unit
    SwitchUpDelayTimer is the number of interrupts that must expire before the button can be pushed again (useful when you don't want someone rapidly turning ON and OFF a piece of hardware).
                IF !EnableSw THEN     ; Aliased pin, goes low when button pushed.
                     IF SwitchFlag THEN ; Switch has been pushed, but prevously released.
                       IF PowerSwitchCounter < 250 THEN
                               PowerSwitchCounter = PowerSwitchCounter + 1  ; don't let it overflow
                       IF PowerONstate = 0 THEN  ; Currently OFF
                           If PowerSwitchCounter >= PowerOnDelayTimer then           ; Turn on or off
                              Gosub PowerOn
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                        ELSE      ; Currently OFF
                           If PowerSwitchCounter >= PowerOffDelayTimer then
                             GOSUB PowerOff
                              SwitchFlag = 0
                              SwitchUpCounter = 0
                    IF SwitchUpCounter < 250 THEN
                          SwitchUpCounter = SwitchUpCounter + 1
                    IF SwitchUpCounter > SwitchUpDelayTimer THEN
                         SwitchFlag = 1          ; Switch has been released
                         PowerSwitchCounter = 0
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should state that SwitchFlag must be initialized to a non-zero value at the top of the program.
    Charles Linquist
    Aug 2005
    Michigan, USA
    I'd like to supplement Charles' fine example with an interrupt driven version of the "parallel switch state logic" example I posted earlier.
    This example uses a 1-msec timer driven interrupt "heart beat" which is perfect for toggling a piezo speaker at 500-Hz and it uses a simple counter to produce a 32-msec debounce/sample interval.
    Using a momentary switch to emulate a "toggle" switch (press to toggle from on-to-off or from off-to-on) can be accomplished directly by the driver by exclusive-or'ing the debounced "new press" bits with the "flags" switch flag bits variable. Main should test the switch flag bit and then clear it for "momentary" switches or simply test the switch flag bit for an emulated "toggle" switch.
    void interrupt()                // 1-msec Timer 2 interrupts
      pir1.TMR2IF = 0;              // clear TMR2 interrupt flag
    //  beep task (32-msec 500-Hz tone using 1-msec interrupts)
      if(beep)                      // if beep task running
      { spkrpin ^= 1;               // toggle speaker pin and
        beep--;                     // decrement beep msec counter
    //  switch state management (multi-switch "parallel" logic)
      if(--dbcount == 0)            // if 32-msec debounce interval
      { dbcount = 32;               // reset debounce timer and
        swnew = ~porta;             // sample active low switches
        flags ^= swnew;             // toggle flag bits for 'main'
          beep = 32;                // task a "new press" beep
    //  in "main"
      while(flags.0)                // while sw0 (RA0) "on" (toggle), do this block
      {                             // until new sw0 press toggles flags.0 to "off"
        if(flags.1)                 // if sw1 (RA1) "new press" (momentary)
        { flags.1 = 0;              // turn off flag and
          ...                       // do something
    Can you post the code you're having problems with? I suspect there's a very simple solution.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2009
    Kalamazoo
    thanks for all the replies guys. ive been away for the weekend, with no computer access. here's the code, fresh from the menubuilder application.
    its a gadget that im making, to keep track/records of my workout sessions. it will also have a realtime clock/stopwatch, all displayed on a 20x2 lcd with 4 menu buttons (next, previous, up down.)
    even with the "pause 200" debouncing, (default) everytime i try to cycle through menu items, with the push of a button, it skips three to six items. (same goes when you try to change a variable) at first, i thought that proteus simulation on my pentium 4 was slow (always bitching about "simulation not running in real time because of excessive cpu load" ) so i transferred the simulation to my intel i7 laptop, and proteus is not complaining any more. still having the same skipping items problem.
    ill try mr Arrati's snipet again, but meanwhile, here's the code.
            clear
    define OSC 16                                ;40 MHZ HS CRYSTAL
    OSCCON = %01110000
    ADCON0= %00000000                         ;PORT A ALL DIGITAL
    ANSEL0= %00000000                         ;PORT A ALL DIGITAL
    TRISA = %00000000                         ;
    TRISB = %11111100                         ;
    TRISC = %10111000                         ;
    LATA = %00000000                          ;
    LATB = %00000000                          ;
    LATC = %00000000                          ;
    'VARIABLE DECLARATION
    bMenuPos    var Byte     'Main menu position
    bSubMenuPos var Byte     'Sub menu position
    BTN_NEXT    var PORTB.4  'Next button
    BTN_PREV    var PORTB.5  'Previous button
    BTN_PLUS    var PORTB.6  'Plus button
    BTN_MINUS   var PORTB.7  'Minus button
    SQUATS_WT  VAR  Byte
    SQUATS_RP  VAR  Byte
    PULLDOWN_WT  VAR  Byte
    PULLDOWN_RP  VAR  Byte
    LATRAISE_WT  VAR  Byte
    LATRAISE_RP  VAR  Byte
    OVHEADPRESS_WT  VAR  Byte
    OVHEADPRESS_RP  VAR  Byte
    PREACHERCURL_WT  VAR  Byte
    PREACHERCURL_RP  VAR  Byte
    PUSHDOWN_WT  VAR  Byte
    PUSHDOWN_RP  VAR  Byte
    PECDECK_WT  VAR  Byte
    PECDECK_RP  VAR  Byte
    CABLESHRUG_WT  VAR  Byte
    CABLESHRUG_RP  VAR  Byte
    CALFRAISES_WT  VAR  Byte
    CALFRAISES_RP  VAR  Byte
    DBWRISTCURL_WT  VAR  Byte
    DBWRISTCURL_RP  VAR  Byte
    DECLINESITUP_WT  VAR  Byte
    DECLINESITUP_RP  VAR  Byte
    'END OF VARIABLE DECLARATION
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 1
    PAUSE 500
    LCDOUT $FE, $01
    LCDOUT $FE, $80, " FITNESS GYM ASSIST"
    LCDOUT $FE, $C0, " COPYRIGHT DAVID M"
    PAUSE 1000
    MAIN
    GOSUB DisplayMainMenu
    GOTO MAIN
    'SUB ROUTINES
    'ROUTINE DisplayMainMenu
    'This routine handles the display of the main menu choices
    'All you need is to call from your main program this routine,
    'and have the button ports setup,
    DisplayMainMenu:
       bMenuPos=1   'This is the default menu option
       IF bMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS WT"
       IF bMenuPos=2 THEN
          LCDOUT $FE,1,"SQUATS RP"
       IF bMenuPos=3 THEN
          LCDOUT $FE,1,"PULLDOWN WT"
       IF bMenuPos=4 THEN
          LCDOUT $FE,1,"PULLDOWN RP"
       IF bMenuPos=5 THEN
          LCDOUT $FE,1,"LAT RAISE WT"
       IF bMenuPos=6 THEN
          LCDOUT $FE,1,"LAT RAISE RP"
       IF bMenuPos=7 THEN
          LCDOUT $FE,1,"OVHEAD PRESS WT"
       IF bMenuPos=8 THEN
          LCDOUT $FE,1,"OVHEAD PRESS RP"
       IF bMenuPos=9 THEN
          LCDOUT $FE,1,"PREACHER CURL WT"
       IF bMenuPos=10 THEN
          LCDOUT $FE,1,"PREACHER CURL RP"
       IF bMenuPos=11 THEN
          LCDOUT $FE,1,"PUSHDOWN WT"
       IF bMenuPos=12 THEN
          LCDOUT $FE,1,"PUSHDOWN RP"
       IF bMenuPos=13 THEN
          LCDOUT $FE,1,"PEC DECK WT"
       IF bMenuPos=14 THEN
          LCDOUT $FE,1,"PEC DECK RP"
       IF bMenuPos=15 THEN
          LCDOUT $FE,1,"CABLE SHRUG WT"
       IF bMenuPos=16 THEN
          LCDOUT $FE,1,"CABLE SHRUG RP"
       IF bMenuPos=17 THEN
          LCDOUT $FE,1,"CALF RAISES WT"
       IF bMenuPos=18 THEN
          LCDOUT $FE,1,"CALF RAISES RP"
       IF bMenuPos=19 THEN
          LCDOUT $FE,1,"DBWRIST CURL WT"
       IF bMenuPos=20 THEN
          LCDOUT $FE,1,"DBWRIST CURL RP"
       IF bMenuPos=21 THEN
          LCDOUT $FE,1,"DECLINE SITUP WT"
       IF bMenuPos=22 THEN
          LCDOUT $FE,1,"DECLINE SITUP RP"
    RB_MainMenuLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 200
          bMenuPos=bMenuPos+1
          IF bMenuPos>22 THEN
             bMenuPos=1
    ' BTN_PREV is the Exit button
       IF BTN_PREV=0 THEN
          PAUSE 200
    ' BTN_NEXT is the Goto SubMenu Choice button
       IF BTN_NEXT=0 THEN
          PAUSE 200
          GoSub DisplaySubMenu
    Goto RB_MainMenuLoop:
    'ROUTINE DisplaySubMenu
    'This routine handles the display of the sub menu choices
    DisplaySubMenu:
       bSubMenuPos=1   'This is the default menu option
    DisplaySubMenuLoop:
       IF bMenuPos=1 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS WT ADJ"
       IF bMenuPos=2 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"SQUATS RP ADJ"
       IF bMenuPos=3 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PULLDOWN WT ADJ"
       IF bMenuPos=4 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PULLDOWN RP ADJ"
       IF bMenuPos=5 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"LAT RAISE WT ADJ"
       IF bMenuPos=6 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"LAT RAISE RP ADJ"
       IF bMenuPos=7 AND bSubMenuPos=1 THEN
       IF bMenuPos=8 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"OVHEAD PRESS RP ADJ"
       IF bMenuPos=9 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PREACHER CURL WT ADJ"
       IF bMenuPos=10 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PREACHER CURL RP ADJ"
       IF bMenuPos=11 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PUSHDOWN WT ADJ"
       IF bMenuPos=12 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PUSHDOWN RP ADJ"
       IF bMenuPos=13 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PEC DECK WT ADJ"
       IF bMenuPos=14 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"PEC DECK RP ADJ"
       IF bMenuPos=15 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CABLE SHRUG WT ADJ"
       IF bMenuPos=16 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CABLE SHRUG RP ADJ"
       IF bMenuPos=17 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CALF RAISES WT ADJ"
       IF bMenuPos=18 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"CALF RAISES RP ADJ"
       IF bMenuPos=19 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DBWRIST CURL WT ADJ"
       IF bMenuPos=20 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DBWRIST CURL RP ADJ"
       IF bMenuPos=21 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DECLINE SITUP WT ADJ"
       IF bMenuPos=22 AND bSubMenuPos=1 THEN
          LCDOUT $FE,1,"DECLINE SITUP RP ADJ"
    RB_SUBMenuLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 200
          bSubMenuPos=bSubMenuPos+1
          IF bMenuPos=1 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=2 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=3 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=4 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=5 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=6 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=7 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=8 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=9 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=10 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=11 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=12 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=13 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=14 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=15 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=16 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=17 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=18 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=19 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=20 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=21 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          IF bMenuPos=22 AND bSubMenuPos>1 THEN
             bSubMenuPos=1
          GoTo DisplaySubMenuLoop
       IF BTN_PREV=0 THEN
          PAUSE 200
       IF BTN_NEXT=0 THEN
          PAUSE 200
             GoSub SUB_1_1
             GoSub SUB_2_1
             GoSub SUB_3_1
             GoSub SUB_4_1
             GoSub SUB_5_1
             GoSub SUB_6_1
             GoSub SUB_7_1
             GoSub SUB_8_1
             GoSub SUB_9_1
             GoSub SUB_10_1
             GoSub SUB_11_1
             GoSub SUB_12_1
             GoSub SUB_13_1
             GoSub SUB_14_1
             GoSub SUB_15_1
             GoSub SUB_16_1
             GoSub SUB_17_1
             GoSub SUB_18_1
             GoSub SUB_19_1
             GoSub SUB_20_1
             GoSub SUB_21_1
             GoSub SUB_22_1
    GoTo RB_SUBMenuLoop
    '*************** SUB SUB_1_1*********
    SUB_1_1:
    'First read the variables from eprom
       READ 1,SQUATS_WT
    SUB_1_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC SQUATS_WT
    SUB_1_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF SQUATS_WT>=255 THEN
             SQUATS_WT=0
             SQUATS_WT=SQUATS_WT+1
          GoTo SUB_1_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF SQUATS_WT<=0 THEN
             SQUATS_WT=255
             SQUATS_WT=SQUATS_WT-1
          GoTo SUB_1_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 1,SQUATS_WT
    GoTo SUB_1_1MLoop
    '*************** SUB SUB_2_1*********
    SUB_2_1:
       READ 2,SQUATS_RP
    SUB_2_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC SQUATS_RP
    SUB_2_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF SQUATS_RP>=255 THEN
             SQUATS_RP=0
             SQUATS_RP=SQUATS_RP+1
          GoTo SUB_2_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF SQUATS_RP<=0 THEN
             SQUATS_RP=255
             SQUATS_RP=SQUATS_RP-1
          GoTo SUB_2_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 2,SQUATS_RP
    GoTo SUB_2_1MLoop
    '*************** SUB SUB_3_1*********
    SUB_3_1:
       READ 3,PULLDOWN_WT
    SUB_3_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PULLDOWN_WT
    SUB_3_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PULLDOWN_WT>=255 THEN
             PULLDOWN_WT=0
             PULLDOWN_WT=PULLDOWN_WT+1
          GoTo SUB_3_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PULLDOWN_WT<=0 THEN
             PULLDOWN_WT=255
             PULLDOWN_WT=PULLDOWN_WT-1
          GoTo SUB_3_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 3,PULLDOWN_WT
    GoTo SUB_3_1MLoop
    '*************** SUB SUB_4_1*********
    SUB_4_1:
       READ 4,PULLDOWN_RP
    SUB_4_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PULLDOWN_RP
    SUB_4_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PULLDOWN_RP>=255 THEN
             PULLDOWN_RP=0
             PULLDOWN_RP=PULLDOWN_RP+1
          GoTo SUB_4_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PULLDOWN_RP<=0 THEN
             PULLDOWN_RP=255
             PULLDOWN_RP=PULLDOWN_RP-1
          GoTo SUB_4_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 4,PULLDOWN_RP
    GoTo SUB_4_1MLoop
    '*************** SUB SUB_5_1*********
    SUB_5_1:
       READ 5,LATRAISE_WT
    SUB_5_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC LATRAISE_WT
    SUB_5_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF LATRAISE_WT>=255 THEN
             LATRAISE_WT=0
             LATRAISE_WT=LATRAISE_WT+1
          GoTo SUB_5_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF LATRAISE_WT<=0 THEN
             LATRAISE_WT=255
             LATRAISE_WT=LATRAISE_WT-1
          GoTo SUB_5_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 5,LATRAISE_WT
    GoTo SUB_5_1MLoop
    '*************** SUB SUB_6_1*********
    SUB_6_1:
       READ 6,LATRAISE_RP
    SUB_6_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC LATRAISE_RP
    SUB_6_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF LATRAISE_RP>=255 THEN
             LATRAISE_RP=0
             LATRAISE_RP=LATRAISE_RP+1
          GoTo SUB_6_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF LATRAISE_RP<=0 THEN
             LATRAISE_RP=255
             LATRAISE_RP=LATRAISE_RP-1
          GoTo SUB_6_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 6,LATRAISE_RP
    GoTo SUB_6_1MLoop
    '*************** SUB SUB_7_1*********
    SUB_7_1:
       READ 7,OVHEADPRESS_WT
    SUB_7_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC OVHEADPRESS_WT
    SUB_7_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_WT>=255 THEN
             OVHEADPRESS_WT=0
             OVHEADPRESS_WT=OVHEADPRESS_WT+1
          GoTo SUB_7_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_WT<=0 THEN
             OVHEADPRESS_WT=255
             OVHEADPRESS_WT=OVHEADPRESS_WT-1
          GoTo SUB_7_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 7,OVHEADPRESS_WT
    GoTo SUB_7_1MLoop
    '*************** SUB SUB_8_1*********
    SUB_8_1:
       READ 8,OVHEADPRESS_RP
    SUB_8_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC OVHEADPRESS_RP
    SUB_8_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_RP>=255 THEN
             OVHEADPRESS_RP=0
             OVHEADPRESS_RP=OVHEADPRESS_RP+1
          GoTo SUB_8_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF OVHEADPRESS_RP<=0 THEN
             OVHEADPRESS_RP=255
             OVHEADPRESS_RP=OVHEADPRESS_RP-1
          GoTo SUB_8_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 8,OVHEADPRESS_RP
    GoTo SUB_8_1MLoop
    '*************** SUB SUB_9_1*********
    SUB_9_1:
       READ 9,PREACHERCURL_WT
    SUB_9_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PREACHERCURL_WT
    SUB_9_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_WT>=255 THEN
             PREACHERCURL_WT=0
             PREACHERCURL_WT=PREACHERCURL_WT+1
          GoTo SUB_9_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_WT<=0 THEN
             PREACHERCURL_WT=255
             PREACHERCURL_WT=PREACHERCURL_WT-1
          GoTo SUB_9_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 9,PREACHERCURL_WT
    GoTo SUB_9_1MLoop
    '*************** SUB SUB_10_1*********
    SUB_10_1:
       READ 10,PREACHERCURL_RP
    SUB_10_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PREACHERCURL_RP
    SUB_10_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_RP>=255 THEN
             PREACHERCURL_RP=0
             PREACHERCURL_RP=PREACHERCURL_RP+1
          GoTo SUB_10_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PREACHERCURL_RP<=0 THEN
             PREACHERCURL_RP=255
             PREACHERCURL_RP=PREACHERCURL_RP-1
          GoTo SUB_10_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 10,PREACHERCURL_RP
    GoTo SUB_10_1MLoop
    '*************** SUB SUB_11_1*********
    SUB_11_1:
       READ 11,PUSHDOWN_WT
    SUB_11_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PUSHDOWN_WT
    SUB_11_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_WT>=255 THEN
             PUSHDOWN_WT=0
             PUSHDOWN_WT=PUSHDOWN_WT+1
          GoTo SUB_11_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_WT<=0 THEN
             PUSHDOWN_WT=255
             PUSHDOWN_WT=PUSHDOWN_WT-1
          GoTo SUB_11_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 11,PUSHDOWN_WT
    GoTo SUB_11_1MLoop
    '*************** SUB SUB_12_1*********
    SUB_12_1:
       READ 12,PUSHDOWN_RP
    SUB_12_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PUSHDOWN_RP
    SUB_12_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_RP>=255 THEN
             PUSHDOWN_RP=0
             PUSHDOWN_RP=PUSHDOWN_RP+1
          GoTo SUB_12_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PUSHDOWN_RP<=0 THEN
             PUSHDOWN_RP=255
             PUSHDOWN_RP=PUSHDOWN_RP-1
          GoTo SUB_12_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 12,PUSHDOWN_RP
    GoTo SUB_12_1MLoop
    '*************** SUB SUB_13_1*********
    SUB_13_1:
       READ 13,PECDECK_WT
    SUB_13_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PECDECK_WT
    SUB_13_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PECDECK_WT>=255 THEN
             PECDECK_WT=0
             PECDECK_WT=PECDECK_WT+1
          GoTo SUB_13_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PECDECK_WT<=0 THEN
             PECDECK_WT=255
             PECDECK_WT=PECDECK_WT-1
          GoTo SUB_13_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 13,PECDECK_WT
    GoTo SUB_13_1MLoop
    '*************** SUB SUB_14_1*********
    SUB_14_1:
       READ 14,PECDECK_RP
    SUB_14_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC PECDECK_RP
    SUB_14_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF PECDECK_RP>=255 THEN
             PECDECK_RP=0
             PECDECK_RP=PECDECK_RP+1
          GoTo SUB_14_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF PECDECK_RP<=0 THEN
             PECDECK_RP=255
             PECDECK_RP=PECDECK_RP-1
          GoTo SUB_14_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 14,PECDECK_RP
    GoTo SUB_14_1MLoop
    '*************** SUB SUB_15_1*********
    SUB_15_1:
       READ 15,CABLESHRUG_WT
    SUB_15_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CABLESHRUG_WT
    SUB_15_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_WT>=255 THEN
             CABLESHRUG_WT=0
             CABLESHRUG_WT=CABLESHRUG_WT+1
          GoTo SUB_15_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_WT<=0 THEN
             CABLESHRUG_WT=255
             CABLESHRUG_WT=CABLESHRUG_WT-1
          GoTo SUB_15_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 15,CABLESHRUG_WT
    GoTo SUB_15_1MLoop
    '*************** SUB SUB_16_1*********
    SUB_16_1:
       READ 16,CABLESHRUG_RP
    SUB_16_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CABLESHRUG_RP
    SUB_16_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_RP>=255 THEN
             CABLESHRUG_RP=0
             CABLESHRUG_RP=CABLESHRUG_RP+1
          GoTo SUB_16_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CABLESHRUG_RP<=0 THEN
             CABLESHRUG_RP=255
             CABLESHRUG_RP=CABLESHRUG_RP-1
          GoTo SUB_16_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 16,CABLESHRUG_RP
    GoTo SUB_16_1MLoop
    '*************** SUB SUB_17_1*********
    SUB_17_1:
       READ 17,CALFRAISES_WT
    SUB_17_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CALFRAISES_WT
    SUB_17_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CALFRAISES_WT>=255 THEN
             CALFRAISES_WT=0
             CALFRAISES_WT=CALFRAISES_WT+1
          GoTo SUB_17_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CALFRAISES_WT<=0 THEN
             CALFRAISES_WT=255
             CALFRAISES_WT=CALFRAISES_WT-1
          GoTo SUB_17_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 17,CALFRAISES_WT
    GoTo SUB_17_1MLoop
    '*************** SUB SUB_18_1*********
    SUB_18_1:
       READ 18,CALFRAISES_RP
    SUB_18_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC CALFRAISES_RP
    SUB_18_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF CALFRAISES_RP>=255 THEN
             CALFRAISES_RP=0
             CALFRAISES_RP=CALFRAISES_RP+1
          GoTo SUB_18_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF CALFRAISES_RP<=0 THEN
             CALFRAISES_RP=255
             CALFRAISES_RP=CALFRAISES_RP-1
          GoTo SUB_18_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 18,CALFRAISES_RP
    GoTo SUB_18_1MLoop
    '*************** SUB SUB_19_1*********
    SUB_19_1:
       READ 19,DBWRISTCURL_WT
    SUB_19_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DBWRISTCURL_WT
    SUB_19_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_WT>=255 THEN
             DBWRISTCURL_WT=0
             DBWRISTCURL_WT=DBWRISTCURL_WT+1
          GoTo SUB_19_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_WT<=0 THEN
             DBWRISTCURL_WT=255
             DBWRISTCURL_WT=DBWRISTCURL_WT-1
          GoTo SUB_19_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 19,DBWRISTCURL_WT
    GoTo SUB_19_1MLoop
    '*************** SUB SUB_20_1*********
    SUB_20_1:
       READ 20,DBWRISTCURL_RP
    SUB_20_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DBWRISTCURL_RP
    SUB_20_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_RP>=255 THEN
             DBWRISTCURL_RP=0
             DBWRISTCURL_RP=DBWRISTCURL_RP+1
          GoTo SUB_20_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DBWRISTCURL_RP<=0 THEN
             DBWRISTCURL_RP=255
             DBWRISTCURL_RP=DBWRISTCURL_RP-1
          GoTo SUB_20_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 20,DBWRISTCURL_RP
    GoTo SUB_20_1MLoop
    '*************** SUB SUB_21_1*********
    SUB_21_1:
       READ 21,DECLINESITUP_WT
    SUB_21_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DECLINESITUP_WT
    SUB_21_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_WT>=255 THEN
             DECLINESITUP_WT=0
             DECLINESITUP_WT=DECLINESITUP_WT+1
          GoTo SUB_21_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_WT<=0 THEN
             DECLINESITUP_WT=255
             DECLINESITUP_WT=DECLINESITUP_WT-1
          GoTo SUB_21_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 21,DECLINESITUP_WT
    GoTo SUB_21_1MLoop
    '*************** SUB SUB_22_1*********
    SUB_22_1:
       READ 22,DECLINESITUP_RP
    SUB_22_1MDLoop:
       LCDOUT $FE,192,"                ",$FE,192,DEC DECLINESITUP_RP
    SUB_22_1MLoop:
       IF BTN_PLUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_RP>=255 THEN
             DECLINESITUP_RP=0
             DECLINESITUP_RP=DECLINESITUP_RP+1
          GoTo SUB_22_1MDLoop
       IF BTN_MINUS=0 THEN
          PAUSE 100
          IF DECLINESITUP_RP<=0 THEN
             DECLINESITUP_RP=255
             DECLINESITUP_RP=DECLINESITUP_RP-1
          GoTo SUB_22_1MDLoop
       IF BTN_PREV=0 THEN
          PAUSE 100
          WRITE 22,DECLINESITUP_RP
    GoTo SUB_22_1MLoop
    NAG CON WIFE!
    WIFE VAR MOOD
    Instead of a pause after any button press try using WHILE WEND to wait for it to be released.
    IF BTN_PLUS=0 THEN
        WHILE BTN_PLUS = 0
        WEND
    Also - you have a ton of RETURN statements after GOTOs' so it never lands on these. I haven't followed your code all the way through, but if it needs to land on the returns, that could be another problem.
    See if the attached works without skipping menu options.
    -Bruce
    tech at rentron.com
    Aug 2005
    Michigan, USA
    That's the easy fix but I cringe every time someone suggests waiting for a switch release.
    Since you'll probably be using interrupts eventually to support an RTC or Timer function, I would suggest delegating switch debounce/management to the ISR. Then you're working with fully debounced real-time "new press" flag bits. Your program would need the ISR and a couple subtle changes;
    SWNEW       var Byte     '
    SWOLD       var Byte     ' switch state latch
    FLAGS       var Byte     ' switch flag bits
    BTN_NEXT    var FLAGS.4  'Next button
    BTN_PREV    var FLAGS.5  'Previous button
    BTN_PLUS    var FLAGS.6  'Plus button
    BTN_MINUS   var FLAGS.7  'Minus button
    Changes to your main program include testing for a '1' instead of a '0' and clearing the flag bit when you use it.
    RB_SUBMenuLoop:
       IF BTN_PLUS=1 THEN
          BTN_PLUS=0
       IF BTN_PREV=1 THEN
          BTN_PREV=0
       IF BTN_NEXT=1 THEN
          BTN_NEXT=0
    GoTo RB_SUBMenuLoop
    If you're interested, you might consider trying out a non-interrupt version by adding a sample/debounce subroutine to your program;
    '  I need help with PBP commands for a "delay" and for "compliment"
    SUB_SWITCHES                    '
      delay_ms(16)                  ' 16-msec debounce interval  ??? how
      SWNEW = ~PORTB                ' sample active lo switches  ??? how
      SWNEW = SWNEW AND 0xF0        ' on RB7..RB4 pins
      SWNEW = SWNEW XOR SWOLD       ' changes, press or release
      SWOLD = SWOLD XOR SWNEW       ' update switch state latch
      SWNEW = SWNEW AND SWOLD       ' filter out "new release" bits
      FLAGS = FLAGS XOR SWNEW       ' toggle switch flag bits
    Then you would need to call the subroutine at the top of each of your switch test loops (forgive me for shortening your program and for any PBP syntax errors);
    RB_SUBMenuLoop:
      GoSub SUB_SWITCHES                    ' sample switches
       IF BTN_PLUS=1 THEN
          BTN_PLUS=0
          IF bSubMenuPos>1 THEN
             bSubMenuPos=1
       IF BTN_PREV=1 THEN
          BTN_PREV=0
       IF BTN_NEXT=1 THEN
          BTN_NEXT=0
          IF bSubMenuPos=1 THEN
             GoSub SUB_ADJ
    GoTo RB_SUBMenuLoop
    '   adjust EEPROM value indexed by 'bMenuPos' variable (1..22)
    '   1 SQUATS_WT          9 PREACHER CURL WT  17 CALF RAISES WT
    '   2 SQUATS_RP         10 PREACHER CURL RP  18 CALF RAISES RP
    '   3 PULLDOWN WT       11 PUSHDOWN WT       19 DBWRIST CURL WT
    '   4 PULLDOWN RP       12 PUSHDOWN RP       20 DBWRIST CURL RP
    '   5 LAT RAISE WT      13 PEC DECK WT       21 DECLINE SITUP WT
    '   6 LAT RAISE RP      14 PEC DECK RP       22 DECLINE SITUP RP
    '   7 OVHEAD PRESS WT   15 CABLE SHRUG WT
    '   8 OVHEAD PRESS RP   16 CABLE SHRUG RP
    SUB_ADJ:                        '
      READ bMenuPos,COUNTER         ' read EEPROM location 1..22
    SUB_ADJ_1MDLoop:                '
      LCDOUT $FE,192,"                "
      LCDOUT $FE,192,DEC COUNTER    '
    SUB_ADJ_1MLoop:                 '
      IF BTN_PLUS = 1 THEN          ' if BTN_PLUS press
        BTN_PLUS = 0                ' clear switch flag
        IF COUNTER>=255 THEN        '
          COUNTER=0                 '
        ELSE                        '
          COUNTER=COUNTER+1         '
        ENDIF                       '
        GoTo SUB_ADJ_1MDLoop        ' refresh displayed count
      ENDIF                         '
      IF BTN_MINUS=1 THEN           ' if BTN_MINUS press
        BTN_MINUS=0                 ' clear switch flag
        IF COUNTER<=0 THEN          '
          COUNTER=255               '
        ELSE                        '
          COUNTER=COUNTER-1         '
        ENDIF                       '
      ENDIF                         '
      IF BTN_PREV=1 THEN            ' if BTN_PREV press
        BTN_PREV=0                  ' clear switch flag
        WRITE bMenuPos,COUNTER      ' update EEPROM
        RETURN                      ' exit
      ENDIF                         '
      GoTo SUB_X_1MLoop             ' loop (for key press)
    RETURN                          '
    Have fun. Cheerful regards, Mike
    Mike,
    With his switch inputs on RB7-RB4, how would you go about that without waiting for a switch release, and then clearing the int-on-change flag bit?
    Wouldn't releasing the switch re-trigger the interrupt?
    -Bruce
    tech at rentron.com
    Aug 2005
    Michigan, USA
    Mike,
    Oh no, I wouldn't use IOC interrupts in this application Bruce. Bouncing would be problematic. I would use periodic timer interrupts and poll the switches as in the example in post #15. And since OP is going to include RTC or Stopwatch functionality, periodic timer interrupts make sense.
    Oh! I see what you meant now. Good idea.
    Newer types like the 16F193x series IOC are a lot easier to use. These don't require reading the port to clear IOC flag bits, and they can be set to trigger on any edge..
    -Bruce
    tech at rentron.com
    Dec 2009
    Kalamazoo
    Default yes, success at last.
    thanks guys, all this ideas work! now, all i have to do is implement the rtc and beeper, which are ready to be merged with this code.
    once again, thanks.
    ps; not that im complaining, but is there any other menu builder app in picbasic?
    NAG CON WIFE!
    WIFE VAR MOOD
    Aug 2010
    Default antirrebotes
    yo he implementado esto y funciona correctamente
    Dec 2009
    Kalamazoo
    hi, again, im trying this piece of code, from a previous post
    RB_SUBMenuLoop:
       IF BTN_PLUS=1 THEN
          BTN_PLUS=0
       IF BTN_PREV=1 THEN
          BTN_PREV=0
       IF BTN_NEXT=1 THEN
          BTN_NEXT=0
    GoTo RB_SUBMenuLoop
    then i have this code scanning port b, through a 1ms interrupt:
    Changed = PortB ^ OldPort
             IF Changed.4 = 1 THEN     ; Pick your pin
             OldPort = PortB
             BTN_PLUS = 1
    this code is incrementing one at a time, which is what i want, but the only problem is that it is incrementing on a rising and falling edge of a button push. so if i push the btn_plus, bmenupos increments by 1, and if i release it, bmenupos increments again.
    i want it to increment only on the rising edge, not on the falling edge. any ideas?
    NAG CON WIFE!
    WIFE VAR MOOD
    Aug 2005
    Michigan, USA
    When you exclusive-or "new" and "old" a resulting 1 bit indicates a change of state (either a new hi or new press, or a new lo or new release). You need to filter these "change" bits. If you AND the "change" bit with the "old" bit you filter out the "new press" bits and you're left with "new release" bits. If you AND the "change" bit with the "new" bit you filter out the "new release" bits and you're left with the "new press" bits.
    Hope this helps.
    '  swnew  ____-----_____-----_____   new switch sample (positive logic)
    '  swold  _____-----_____-----____   switch state latch
    '  delta  ____-____-____-____-____   changes, press or release
    '  newhi  ____-_________-_________   new press bits
    '  newlo  _________-_________-____   new release bits
        swnew = PortB                  ' sample active hi switches
        delta = swnew ^ swold          ' changes, press or release
        newhi = delta & swnew          ' get "new press" bits
        newlo = delta & swold          ' get "new release" bits
        swold = swnew                  ' update switch state latch
        IF newhi.4 = 1 THEN            '
          BTN_PLUS = 1                 '
    Dec 2009
    Kalamazoo
    that is just great. thanks for pointing me to the right direction, Mr Mike. its all fixed now.
    cheers
    NAG CON WIFE!
    WIFE VAR MOOD
    Aug 2005
    Michigan, USA
    cheers
    You're very welcome Sir.
    Please note that the previous example can be optimized a bit. Since you're using the "new press" state as the action state in your program you don't need the "newlo" variable and its assignment statement. You can also retask the "swnew" variable and eliminate the "newhi" variable. Some XOR trickery is used to update the "swold" switch state latch to the new PortB pattern.
    '  swnew  ____-____-____-____-____   changes, press or release
    '  swnew  ____-_________-_________   new press bits
        swnew = swnew ^ swold          ' changes, press or release
        swold = swold ^ swnew          ' update switch state latch (swold = new PortB)
        swnew = swnew & swold          ' get "new press" bits
        IF swnew.4 = 1 THEN            ' if RB4 "new press"
          BTN_PLUS = 1                 ' set flag for main
    With your 1-msec interrupt intervals you might consider adding a piezo speaker and code for "new press" beeps;
    '  beep task (32-msec 500-Hz beep using 1-msec interrupts)
        IF beepctr > 0 THEN            ' if beep task running
          PortB = PortB ^ spkrpinmask  ' toggle piezo speaker pin
          beepctr = beepctr - 1        ' decrement beep msec counter
          BTN_PLUS = 1                 ' set flag for main and
          beepctr = 32                 ' task a new press beep
    If you experience bounce problems with a 1-msec sampling interval you might consider adding a counter and executing the switch sample code at some interval between 16 and 32 msecs.
    BTW, assembly language "parallel switch state logic" is incredibly efficient (6 or 8 words);
    ;  wreg  ___-----_____-----____   new switch sample (positive logic)
    ; swold  ____-----_____-----___   switch state latch
    ;  wreg  ___-____-____-____-___   changes, press or release
    ;  wreg  ___-_________-________   filter out new release bits
    ; flags  ___-----------________   toggle sw flags for main
            comf    PORTB,W         ; sample active lo switches
    ;       movf    PORTB,W         ; sample active hi switches
            andlw   b'11110000'     ; on RB7..RB4 pins
            xorwf   swold,W         ; changes, press or release
            xorwf   swold,F         ; update switch state latch
            andwf   swold,W         ; filter out "new release" bits
            skpz                    ; new press? no, skip, else
            bsf     beepctr,5       ; task a "new press" beep
            xorwf   flags,F         ; toggle sw flags for main
