Upgraded to PBP v2.60 and I can't program
Results 1 to 3 of 3
    Jun 2009
    Default Upgraded to PBP v2.60 and I can't program
    Hey guys,
    I searched around and couldn't find anything similar to this, but I'm working with a PIC18f46k20 and upgraded PBP from v2.5 to v2.6 in order to use MPLAB's ICD 3.
    After the upgrade I'm unable to get the simplest of programs to work when I compile and program (U2 programmer) using the updated version. The programming sequence appears the same as before and I don't receive any erros, but my programs do not run while in the ciurcuit. However, if I copy the code creatred in PBP v2.6 and compile with v2.5 on a different computer everything works!
    Anyone seen this before?
    Mar 2006
    China
    Default Configuration bits
    Have you checked that you use the same configuration bits? If the PIC dont run that can be a good start to look.
    Jun 2009
    I checked that before, but I went back and double checked again and I overlooked one. That did the trick!
    Thanks Jumper!
