Start on power up pic16f886
Results 1 to 5 of 5
    Apr 2010
    CROATIA
    Unhappy Start on power up pic16f886
    Can any1 tell me how to configure pic16f886 in assembly,to start on power up
    now i start it with my pickit,but i want him to start on power up.thanks
    Yes. Build the minimal required circuit for your PIC like connections to Vcc & ground, resistor to Vcc - MCLR, then apply power. There are no magical instructions in assembler, BASIC, or anything else, to tell it to start...;o)
    Program it, then apply power, and bingo - it starts.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2010
    CROATIA
    Default Startup trouble
    .But i have Vcc & ground, resistor to Vcc - MCLR, and program,but it doesent want to start,i make it start from PC ,with mplab.(i use pickit-3 ).i was hoping there is some start up bit or.....similar.what could be a problem
    THANKS
    When you are trying to start it with out the PicKit3 what are you using for a power supply?
    Apr 2010
    CROATIA
    Thanks guys a lot.The problem was i programming it in debugger,and of course wont start,but when i use programmer...whole different story...
    Thanks for quick reply,i am very new in programing,but planning hard work
