Problem with Timer Interrupt, PortB5-7 gets disabled
Results 1 to 2 of 2
Threaded View
    Exclamation Problem with Timer Interrupt, PortB5-7 gets disabled
    Dear fellows, I'm trying to implement a timer which would get enabled on a specific action perfor a specific task ones the time is reached.
    I've achieved the timer thing using interrupts and breaking it down furthur and keeping a check on it. But achieving so i've came accross a number of problems
    1. Serin/Serout data started to messup...so used disable/enable before and after to run serial communication smoothly...
    2. Data read using names symbols on PortB failed so again disable/enable and used directly like PORTB instead of variable...this solved problem with Porb.0-Portb.4
    3. Now the actual problem being: I'm unable to deal with my inputs at Portb.5-Portb.7...
    I'm using 18F452 with a 4MHz XTAL
    The code for my interrupt and all is:
    '''''''''''''''''''''DEFINING and ENABLING INTERRUPT'''''''''''''''
    T0CON = %11000111
    INTCON = %00100000
    On Interrupt GoTo SwitchOff
    GoTo ProgramInitializationCont
    Disable
    SwitchOff:
    If CountIntTimer < TimerInSMS Then
    CountIntTimer = CountIntTimer + 1
    INTCON.2 = 0
    ElseIf CountIntTimer = TimerInSMS Then
    Power = 1 'Power Off
    Else
    Resume
    EndIf
    Resume
    Enable
    ''''''''''''''''''''''DEFINING and ENABLING INTERRUPT FINISHED'''''''''''''''
    TimeInSMS = 100
    ProgramInitializationCont:
    If PortA.0 = 1 then
    CountIntTimer = 0
    INTCON.2 = 0
    if PortB.7 = 1 then 'I'M NOT ABLE TO READ PORTB.5-7
    'Some other action
    ''''''''''''''''''END OF CODE'''''''''''''''''''''''''''''''''
    An urgent solution in timers implementation and PortB reuse would be appreciated
    Best Regards
    JD
    PS: Although the code functions well on the OshonSoft PIC18 Simulator but am NOT ABLE TO READ MY PORTB IN PHYSICAL
    Last edited by jamshid.dastur; - 6th April 2010 at 18:53. Reason: forgot to mention simulation results
