Hi All,
I am trying to use SERIAL LCD BPI-216
from Scott Edwards Electronics, Inc in my project
to monitor setting parameters.
'Processor p16F84A
DEFINE OSC 20
INCLUDE "modedefs.bas"
TRISA = $0F ' Set PORTA to all input
TRISB = %00000000 ' Set all of PORTB to outputs
PORTB = $00
I CON 254
CLR CON 1
LINE2 CON 192
L1_C7 CON 135
FR1 CON 255
FR2 CON 128
FR3 CON 64
FR4 CON 32
FR5 CON 16
FR6 CON 8
FR7 CON 4
FR8 CON 2
FR9 CON 1
SER var PORTA.3
'N2400 con 4
MYVAR VAR BIT
UP VAR BIT
DOWN VAR BIT
NV VAR BYTE
CNT VAR BYTE
CNT = 0
MAIN:
PAUSE 1000
PORTB = $00
MYVAR =PORTA.0
IF MYVAR = 1 THEN RUN
UP = PORTA.1
IF UP = 1 THEN INCNV
DOWN = PORTA.2
IF DOWN = 1 THEN DECNV
LOOKUP CNT,[FR1,FR2,FR3,FR4,FR5,FR6,FR7,FR8,FR9],NV '
serout SER,N2400,[I,CLR] 'clear and move to home position
serout SER,N2400,[I,L1_C7,"mSEC"]' Print on the first line
serout SER,N2400,[I,LINE2] 'Redirect to second line
Serout SER,N2400,[#NV," "] 'Print Value of NV
GOTO MAIN
RUN:
MYVAR =PORTA.0
IF MYVAR = 0 THEN MAIN
'Get CNT from string to var NV
PORTB = %10011001
PAUSE NV
PORTB = %10101010
PAUSE NV
PORTB = %01100110
PAUSE NV
PORTB = %01010101
PAUSE NV
GOTO RUN
INCNV:
PAUSE 500
CNT = CNT + 1
IF CNT = 9 THEN CNT = 8
DECNV:
PAUSE 500
CNT = CNT - 1
IF CNT = -1 THEN CNT = 0
Program is working fine, only serial LCD is behaved.
Where I can find info how to use serial LCD in PICBASIC Pro
enviroment?
Thanks in advance.
Best Regards
