read/write eeprom
Results 1 to 18 of 18
    Jun 2006
    Default read/write eeprom
    First give credit to Peter Olsen who wrote these programs for a picaxe. I'm trying to convert using a 12F683 to write to a 24LC256 and read back from it. The Angel file downloads file to 24lc256 from PC. Newtoyshop is suppose to read from the 24lc256 and output to 2 74hc595's. When I write to eeprom then read back I get jumbled up mess. The Angel file runs in power basic.
    In my opinion..
    You would be better off not wasting time trying to convert a program that may or may not have worked for another platform.
    You know what you want the program to do?
    Write from scratch. In PBP...
    Jun 2006
    It did work on a picaxe. I'm trying to write it in PBP with the other program as a reference, being new at this having a heck of a time. Not giving up.
    Not giving up is good!
    To learn how to work with external eeproms try the I2C sample here
    http://www.melabs.com/resources/samples.htm
    Or wait till someone comes along that knows picaxe...
    and this may help with the 595s.
    http://www.picbasic.co.uk/forum/showthread.php?t=10200
    Put something together in PBP and we will help you debug it.
    May 2008
    Italy
    Tray adding the following two defines:
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    Al.
    DOH!!!
    My apologies...
    The way I read the first post I did not think you had any code of your own.
    And I hate opening attachments...
    Use code tags in the future.
    Jun 2006
    I'll try the Defines and whenever I use code tags the code jumbles up or leaves stuff out, tried this a couple times on other questions and it left parts of the code out.
    Quote Originally Posted by mel4853 View Post
    replace the word magic with the word code
    [magic] your code goes here [/magic]
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. External EEPROM can't read/write
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 22:13
  3. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
