12f675_fuse_about_to_blow! - Page 23
Page 23 of 24 FirstFirst ... 13192021222324 LastLast
Results 881 to 920 of 929
  1. #881
    Feb 2010
    I live in the UK
    Default Re: 12f675_fuse_about_to_blow!
    I'm having major problems trying to get the TX program to do what I want it to, namely TX after a timing loop executes. Just for information, if I comment out the timing loop the program TX's no problem and sends and receives a test WORD.
    Here's the setup:
    INTCON = %00001000  ' Enable port change wakeup from sleep
    WPU = %00010000     ' pull-up on for GPIO.4 (external pull-up already on GPIO.3)
    It's GPIO.4 we're looking at here. That's the pin that will receive the input from a 555 timer / potential divider using an ldr to detect that it's dark and therefore TX the days count over.
    OPTION_REG = %00001111 'Watch_Dog_Timer ON with a 128 prescaler
    Here's the main body of the program. it's a little bit of a mess because I've commented out the GPIO.3 COUNTS part of the program and also added then commented out INTCON.0 = 0 in various places to try and get it to do the timer loop / COUNT then TX.
    IF GPIO.3= 1 AND GPIO.4= 1 THEN ' Nothing has happened so SLEEP
           E_OUT=0       ' Disable transmitter
           INTCON.0 = 0  ' No Inputs detected or it's still light so clear int on change flag
           @ SLEEP       ' and start snoozin..zzzzzzzzzzz indefinatly
           @ NOP         ' Do nothing for 1st instruction on wake-up
       'IF  GPIO.3=0 THEN GOSUB COUNTS 'Bird detected at box - GOTO LABEL COUNTS
       IF  GPIO.4=0 THEN DARK   'It's got dark? or just cloudy - GOTO LABEL DARK
      GOTO MAIN          'Back to sleep / continue counting
     'COUNTS:
        '  VISITS = VISITS +1 'Bird at box so increment counter
        '  INTCON.0 = 0       ' Clear int on change flag
      'RETURN                 ' Then back to sleep....
          DARK:
          'INTCON.0 = 0     ' Clear int on change flag
                           ' It could be night time...It might only be a cloud though...
                           ' so back to sleep / wake / sleep for half an hour..zwzwzw
          COUNTER=0        ' clear before entry
    WHILE COUNTER < 2      ' 4.608sec Loop time (Loop for 30 mins = 781)
         @ SLEEP
         COUNTER=COUNTER+1
         'IF  GPIO.3= 0  THEN COUNTS 'Bird at box (it's not dark) so continue counting
    WEND
        if  GPIO.4= 0  then ENCODE  ' It really ia dark so carry on and transmit VISITS
        'IF  GPIO.4= 1  THEN Main  '(changed from return) It's not dark after all so carry_on_sleeping_counting
    Encode:
        E_OUT=1     ' Turn transmitter on
        pauseus 25  ' Let transmitter settle
        DAT_OUT = %10101001
        'Build checksum of 2 data bytes
        CHK_SUM = (DAT_OUT * 2)
    Transmit:
        'LET VISITS = VISITS / 2  'Just VISITS too not from the box
        LET VISITS = 300 'Test data number
        SEROUT2 D_OUT,BAUD,[PreAmble,Synch,DAT_OUT,DAT_OUT,CHK_SUM,VISITS.highbyte,VISITS.lowbyte]
        PAUSE GUARD ' 5mS guard time gives decoder time to respond,calculate,change,etc.
        INTCON.0 = 0  ' Clear int on change flag - moved here from above
        GOTO Main
    I think the problem maybe that the COUNTER loop never gets completed because the IOC which comes from GPIO.4 isn't reset and the counter loop is using @SLEEP but never gets that far.
    Any ideas greatfully received.
  2. #882
    What happens if the @SLEEP below is commented?
         @ SLEEP
         COUNTER=COUNTER+1
    WEND
  3. #883
    Feb 2010
    I live in the UK
    It TX's straight away and the led on the Pickit1 (receiver) flashes three times (as intended). There is no 5 sec delay from the timing loop though.
    It's as if the timing loop COUNT is just being bypassed, have I set it up right?
  4. #884
    Feb 2010
    I live in the UK
    If I press and hold down push button GP4 on the transmitter, the receiver flashes the led continually. I would have thought / was expecting that when the push button on GPIO.4 was pressed and held down you would get a four / five second delay before the receiver received anything and started to flash.
    Tonights silly question:
    How does setting the OPTION reg and WDT then become associated with the loop COUNTER? The WDT has a period of 18ms so setting the bits 111 gives 128*18ms =2.304secs the COUNTER loop should run twice giving a delay of 4.608secs right? But if the program doesn't read COUNTER as being associated with the WDT it's going to count to two in a flash and it will appear that the TX sends the data instantly(which is what is happening). Should the WDT and COUNTER be 'joined' via a 'SYMBOL statement in the program under SYMBOL? or something like this?
  5. #885
    Just guessing as I have not done this before...
    WHILE COUNTER <= 2      ' 4.608sec Loop time (Loop for 30 mins = 781)
          INTCON.0 = 0
         @ SLEEP
         COUNTER=COUNTER+1
    WEND
    I hope someone else will jump in on this...
  6. #886
    Feb 2010
    I live in the UK
    Hi mackrackit,
    I've made the changes and the Transmitter lights the it's reference led about once every nine seconds but doesn't transmit at all (doesn't seem to get that far).
    I still can't get my head around how the WDT associates with the loop COUNTER, plus the more I read on this it seems that if the WDT isn't reset back to zero before it reaches FF+1 (I think) it then reboots the program which makes sense....Mmm, more reading and thinking to do, interesting though.
    Aug 2010
    Maryland, USA
    First let me say, this is an awesome thread. I have been meaning to read it from the beginning, but I am a slow reader.
    LEDave, WDT in the snippet you just posted works like this:
    Assuming PBP knows you are using the WDT, clear WD is sprinkled around the program for you to keep from resetting the chip. But to get to these, the program must run.
    @sleep basically stops the program and the chip just, well sleeps. Because of this, the WDT never gets cleared. The WD can wake up the PIC, so when WDT overflows, the PIC wakes up and resumes where it left off. So this is how the WDT is associated with the counter.
    Hope this helps
    -Bert
  8. #888
    Bert,
    will this make it work as expected?
          INTCON.0 = 0
         @ SLEEP
        CLEARWDT
         COUNTER=COUNTER+1
    WEND
  9. #889
    Aug 2010
    Maryland, USA
    Dave, sorry for being only clear as mud with my explaination. I ment to say : because of this, the WD never gets cleared WHILE SLEEPING. When the pic is asleep, WDT overflows thus waking up the PIC.
    I tried to quickly look over the program a few posts up, but I don't have a good feel for it yet. I don't think adding the CLRWDT will help only because when the pic wakes, it should be a long time (~2sec) before the next overflow.
    I did notice when @SLEEP is used elsewhere in the program, the line following is @NOP. Maybe this is needed to give the pic a chance to get the sleep from its eyes? I would try using @NOP right after the @SLEEP and see if this works.
    I have never used any of the power saving modes before, but if the pic needs a nop upon waking up, it may be ignoring the counter=counter+1. Therefore the while is never satisified.
    In any event,if the NOP is needed, adding CLRWDT may solve the problem, we just won't know why it did.
    -Bert
  10. #890
    Feb 2010
    I live in the UK
    Hi Bert
    Thanks for your input and welcome to the thread. I was heading towards the CLRWDT after reading this (quite an interesting website):
    http://www.hobbyprojects.com/pic_tut...utorial13.html
    Well here's the section of code as it stands:
    DARK:
         @ SLEEP
         @ NOP
         CLEARWDT
         COUNTER=COUNTER+1
    WEND
    Encode:
    What happens now is when the push button on GPIO.4 is pressed (and held down) After a count of 9 seconds approx (I was expecting a count of two to give half that time) the TX board led lights but still nothing is transmitted.
    The program still doesn't seem to get to encode and transmit, frustrating, any other thoughts?
    Feb 2010
    I live in the UK
    Bert
    As an aside to the problem, earlier on in the program we have:
        ' Read port to clear missmatch, if with no buttons pressed, then
        ' clear int-on-change flag & snooze until wake up on change. This
        ' conserves battery power on the demo board with 3V coin cell.
    Does this mean that using a WDT and a SLEEP command to save power are kind of mutually exclusive? The SLEEP command turns the PIC off (saving power) then the WDT turns the PIC back on again 4.6seconds later in our case? The above code would keep looping on and off until a button is pressed or the 3v cell goes flat?
  12. #892
    Feb 2010
    I live in the UK
    Have spent several interesting but largely fruitless hours trying to make some progress with the program.
    However if I jump passed the COUNTER / WDT routine the TX & RX work fine which is good to know.
    Here's the code for it:
         @ SLEEP
         @ NOP
         CLEARWDT
         COUNTER=COUNTER+1
    One thought does occur to me though, at the start of the program the PIC is placed into SLEEP mode, only to be woken on INTERRUPT.
    Code below.
           CLEARWDT
       IF  GPIO.4=0 THEN   encode 'DARK 'Encode 'DARK   'It's got dark? or just cloudy - GOTO LABEL DARK
    However, GPIO.4 must be pressed and held down (simulating night time) which causes the wake up from SLEEP interrupt, the program then moves down to the COUNTER / WDT loop. I think I might have found a problem here though. For the COUNTER / WDT loop to work and give a 4.6sec test delay the PIC must go into SLEEP mode, if GPIO.4 is continually held down simulating night time and hence causing an INTERRUPT from SLEEP (continually, even resetting the interrupt won't help as button continually pressed) then my thinking says the COUNTER /WDT loop will never work because the PIC is always being woken up.
    A bit garbled I know, sorry, but am I onto something.
    Feb 2010
    I live in the UK
    I'm having a problem getting the rfpic transmitter to Tx when I want it to. I've set up an ON INTERRUPT with DISABLE - RESUME - ENABLE and have the INTCON & IOC set at:
    INTCON = %00001000 & IOC = %00011000
    What happens is, when buttons GPIO3/4 are pressed (and released)the RFEN led after a 5sec delay briefly flashes but no data is sent. If GPIO.3/4 are pressed and held down after 10 secs the RFEN led lights up the five seconds later (button still held down) data is Tx'd, the button is then released and five seconds later the RFEN led goes out.
    What I'd like is for the buttons GPIO.3/4 to be pressed, ON INTERRUPT runs then five seconds later after the delay loop the data is Tx'd. Does anyone have any idea on what's going wrong?
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
        DEFINE OSCCAL_1K 1
        DEFINE NO_CLRWDT 1
        SYMBOL D_OUT = GPIO.2 ' RF serial data output
        SYMBOL E_OUT = GPIO.5 ' RF transmitter enable output
        ON INTERRUPT GOTO  Delay
        DAT_OUT  VAR BYTE   ' Holds 8-bit data byte
        CHK_SUM  VAR BYTE   ' Holds calculated checksum of outbound data
        VISITS   VAR WORD   ' Loop variable (300 for test)
        I        VAR word   ' Delay Loop Count value
        BAUD     VAR WORD   ' Holds baud rate
        ' Constants
        PreAmble CON $A5    ' 10100101 preamble
        Synch    CON "~"    ' 01111110 synch byte
        N4800    CON 188    ' 4800 bps
        N2400    CON 16780  ' 2400 bps
        GUARD    CON 5      ' 5mS guard time pause
        ' hardware init
        GPIO = 0            ' Everything off on boot
        ' GPIO.2=data out, GPIO.5=RF enable, GPIO.3,4 = Bird_visit_count / It's dark..maybe
        TRISIO = %00011011  '
        ANSEL = 0           ' Disable A/D
        IOC = %00011000     ' Wakeup on change enabled for GPIO.3,4
        VRCON = 0           ' Disable internal Vref
        CMCON = 7           ' Disable comparators
        OPTION_REG = 0      ' Pull-ups on
        D_OUT = 0           ' Idles low for inverted serial output
        E_OUT = 0           ' Enable for RF transmitter=0 (transmiter off)
        BAUD = N2400        ' Set baud rate here
        @ SLEEP          ' and start snoozin..zzzzzzzzzzz indefinatly / Waiting for IOC
        @ NOP
        'ON INTERRUPT starts / returns here with Button_press: goes to LABEL - "DELAY":
    Encode:
        DAT_OUT = %10101001
    Transmit:
         GOTO Main
    disable
    Delay:
    FOR I = 1 TO 5
        PAUSe 1000
    nEXT I
    INTCON.0 = 0
    resume : enable
    goto Main
    I think change this to the number that represents
    the mode referenced by this. I "think" baud is
    1 byte trying to hold 5 byte ASCII word.
    I am not home right now, so I cannot check, does
    this PIC have interrupts? On the pins you want them?
    Finally "On Interrupt" is like asking you teen to
    clean his room, he will, someday.
    Use DT_INTS for fast reliable interrupts, maybe will not fit a 675.
  15. #895
    Feb 2010
    I live in the UK
    Name:  RFRXD0420.pdf - Adobe Reader_2011-05-12_09-34-44.png
    does
    Hi Joe, from the data sheet (pasted above) so yes IOC on pins I need.
    I've changed BAUD to:
    BAUD = 16780        ' Set baud rate here
    Program does same as before though - Also if @SLEEP is commented out as
    mackrackit suggested earlier, the rfpic transmits pretty much transmits on button press.
    I'll have a look into DT_INTS later today, thanks for the pointer.
    PS: Sorry for pasting Data sheet info into the thread instead of as an attachment, not sure what I did wrong there.
    Yes, I told you to use DISABLE-ENABLE-RESUME... I thought you were playing with ONINTERUPPT.
    Looks like you are still using Bruce's code as a base, so lets go back to it and modify it some.
    But first you may want to try Bruce's code as he wrote it to make sure your hardware is working correctly.
    '*  Name    : rfPIC_TX.BAS                                      *
    '*  Author  : B. Reynolds                                       *
    '*  Notice  : Copyright (c) 2007 Reynolds Electronics           *
    '*  Date    : 10/09/2007                                        *
    '*  Notes   : 2-BIT Encoder for remote control with the         *
    '*          : rfPIC12F675 on Microchip rfPIC demo board         *
    @ DEVICE PIC12F675,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_OFF
    @ DEVICE PWRT_ON,PROTECT_OFF
        ' With rfRXD0420 module installed in PICkit 1 board;
        ' SW1 toggles LED D6 on PICkit 1 board
        ' SW2 toggles LED D7 on PICkit 1 board
        DEFINE NO_CLRWDT 1
        DEFINE OSCCAL_1K 1
        LOOPS   VAR BYTE    ' Loop var
        ' Constants
        ' hardware init
        ' GPIO.2=data out, GPIO.5=RF enable, GPIO.3,4=SW1/SW2 switch inputs (rfPIC board)
        IF (GPIO.3=1) AND (GPIO.4=1) THEN ' pins will be 0 only when buttons are pressed
         INTCON.0 = 0    ' No buttons down, so clear int on change flag
        E_OUT=1          ' Enable transmitter (+ lights RFEN LED on demo board)
        PAUSEUS 25       ' Allow RF stage to stabilize
        ' Button pressed (or being held down), so keep going
    ' Here is where you want to put the 5 second loop
    Delay:
    FOR I = 1 TO 5
        PAUSe 1000
    NEXT I
    'Then check the buttons again
    'Look for ENDIF near the end.
    'If button are still pressed then it goes to ENCODE
    'If not, go back to MAIN and the INTERRUPT ON CHANGE will be reset
    Encode:
        ' Only DAT_OUT bits 1 and 2 are used. We add a few 1's in bit
        ' positions 0,3,5,7 to balance out the data packet being sent.
        DAT_OUT = %10101001
        ' Get data on button inputs & invert 0's to 1's
        DAT_OUT.0[1]=~GPIO.3
        DAT_OUT.0[2]=~GPIO.4
        ' Build checksum of 2 data bytes
    Transmit:
        SEROUT2 D_OUT,BAUD,[PreAmble,Synch,DAT_OUT,DAT_OUT,CHK_SUM]
        GOTO Main
  17. #897
    Feb 2010
    I live in the UK
    Hi mackrackit
    I did and I am still hoping to get it working: Post #893 above has ON INTERRUPT -DISABLE-ENABLE-RESUME in the code.
    Thanks for the TX program, I had to change:
    @DEVICEPIC12F675,MCLR_OFF,INTRC_OSC_NOCLKOUT,WDT_OFF,BOD_OFF
    To:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _BODEN_OFF & _PWRTE_ON
    To make the program compile, are the above changes ok?
    So what happened when I ran it? Well the RFEN led lit for five seconds immediately either button was pressed but nothing was transmitted. I then commented out the delay loop, the RFEN led lit when buttons pressed then went off when button released - still no data sent.
    I see where you're coming from with the IF - THEN with the program then going onto the ENDIF statement.
    I made a small change adding:
    IF (GPIO.3=1) AND (GPIO.4=1) THEN goto   Main
     if (GPIO.3=0) OR (GPIO.4=0) THEN 'Look for ENDIF
    The result was the RFEN led lit for five seconds immediately either button was pressed but nothing was transmitted (as before) however, when the delay loop was commented out data was trnsmitted.
    It seems to me that the delay loop is killing the data transfer. What do you think?
    I've saved Bruce's original code as Tx - Rx Master, works a treat.
  18. #898
    Feb 2010
    I live in the UK
    A breakthrough, I think....
    I moved the delay loop to run right after the IOC from @SLEEP. So what happens now is if GPIO.3/4 are held down, after 5sec delay data is Tx'd. If GPIO.3/4 are pressed and released within 5secs PIC goes back to @SLEEP.
    mackrackit, idea why moving the delay loop 'made a difference' to my mind it should have worked where you put it too.
        FOR I = 1 TO 5
          PAUSe 1000
          NEXT I
     IF (GPIO.3=1) AND (GPIO.4=1) THEN  Main 'Button not pressed or pressed then released
     if (GPIO.3=0) OR  (GPIO.4=0) THEN       'Carry on to ENDIF & Tx DATA
  19. #899
    Quote Originally Posted by LEDave View Post
    Attachment 5485
    OK, now at home I see why it would work Baud = n2400, because n2400 is set as a symbol in modedefs.bas as 4 (mode 4 ) so its a variable aliasing a constant. Explains Why it Should work. 16780 is a serout2 mode . . . does it work with serout ?
    Edit:
    Oh My Bad, you are using serout2.
  20. #900
    I am really missing something or there is something else in your code...
    I do not see why you had to move the delay. Your way the delay should be jumped over when a button is pressed...
  21. #901
    Feb 2010
    I live in the UK
    Made a mistake, please ignore this post,Dave.
  22. #902
    Feb 2010
    I live in the UK
    Hi mackrackit
    I reloaded your code and the rfpic worked exactly as before, namely:
    The RFEN led lit for five seconds immediately either button was pressed but nothing was transmitted.
    Mm, I thought (hoped) the PIC would go to SLEEP then IOC would wake it and the program would run from where it went to SLEEP, so the next thing it would do was run the delay loop...? ON INTERRUPT is on hold right now until we get the delay loop to work with the rfpic tx-ing after the delay. I'm not using ON INTERRUPT RIGHT now.
        FOR I = 1 TO 5
          PAUSe 1000
          NEXT I
  23. #903
    Aug 2010
    Maryland, USA
    Jumping in again, possibly completely off base here. But, is there any kind of max time between when you enable the tx, and when you send it data? Because all I see different about moving the delay loop is then enable is moved after it.
    As a side note, why not change the for loop to something much bigger like 1 to 250, then make the pause time of 20. This won't help the current problem, but when you are back to on interrupt you will not be trapped in the pause for near as long.
    -Bert
  24. #904
    Feb 2010
    I live in the UK
    Hi cncmachineguy, I suspect timing has a lot to do with it (although I don't kow enough to say or point to why).
    Plenty of head scratching going on here.
    As a side note, why not change the for loop to something much bigger like 1 to 250, then make the pause time of 20. This won't help the current problem, but when you are back to on interrupt you will not be trapped in the pause for near as long..
    Yes, pauses for too long are bad news for what I'm aiming at with this project.
  25. #905
    In my code try moving
    to the beginning of the
    Encode:
    block...
    Search this document for "RFEN"..
    http://ww1.microchip.com/downloads/e...doc/70091a.pdf
  26. #906
    Feb 2010
    I live in the UK
    I moved the code.
    What happens is:
    1/ If a button is pressed and released RFEN briefly flashes after the 5sec delay (no data is Tx'd).
    2/ If a button is continually pressed, nothing happens at all (RFEN doesn't light / no data is Tx'd.
  27. #907
    How is the voltage on the power supply/battery?
    I hope Bruce stops in and sees this as I am lost...
  28. #908
    Feb 2010
    I live in the UK
    I'm using a power supply set at 4.66v.
    For some reason my attachments are appearing here 'inline' rather than at the page bottom, sorry.
    The comment about dataask going high caught my eye. Maybe our timing is off a touch (not sure if or why) with the RFEN coming on and us missing data-ask going high (there is no technical reason why anything I've just typed is remotely true) Just my gut....aka....Agent Gibbs style...!
    Name:  RFRXD0420.pdf - Adobe Reader_2011-05-15_02-38-20.png
  29. #909
    Aug 2010
    Maryland, USA
    Sorry guys, I will have to just keep following. I'm stumpted.
    -Bert
  30. #910
    Can you post your entire program as it stands now?
    (There's no way my feeble mind can remember all changes through a 23 page thread.)
  31. #911
    Feb 2010
    I live in the UK
    Two versions to look at really Demon. I've posted two, it might help you see 'something' because although very similar, what they both do is subtley different things.
    The first one does this on button presses:
        DEFINE NO_CLRWDT 1
        DEFINE OSCCAL_1K 1
        I       VAR BYTE
        ' Constants
        ' hardware init
       ' E_OUT=1          ' Enable transmitter (+ lights RFEN LED on demo board)
       ' PAUSEUS 25       ' Allow RF stage to stabilize
    Delay:
    FOR I = 1 TO 5
        PAUSe 1000
    NEXT I
    Encode:
        DAT_OUT = %10101001
    Transmit:
        GOTO Main
    This one does this:
    1/ Tx's the data after the button is continually held down for 5secs.
    2/ The RFEN led briefly flashes (after 5secs) if either button is pressed and released.
        DEFINE NO_CLRWDT 1
        DEFINE OSCCAL_1K 1
       ' ON INTERRUPT goto  Delay
            I   VAR BYTE
             ' Constants
        ' hardware init
        FOR I = 1 TO 5
         PAUSe 1000
         NEXT I
     IF (GPIO.3=1) AND (GPIO.4=1) THEN Encode 'Button pressed & released But carry on)
    Encode:
        DAT_OUT = %10101001
    Transmit:
        GOTO Main
  32. #912
    I started by looking at your first code:
    Encode:
        DAT_OUT = %10101001
    Transmit:
        GOTO Main
    If GPIO.3 and GPIO.4 are both 1, then neither are being pressed when pull-up resistors are used.
    I read these comments backwards to what the code does.
    Personally, the technique of using 1 for OFF and 0 for ON is extremely confusing; it makes trying to follow your code extremely difficult. I always use pull-down resistors and 0=OFF / 1=ON 'cause that's how binary works as well as power switches.
    EDIT: Unless it's a requirement for Sleep mode to have current ON, and the interruption signals Wake.
    Otherwise, if power consumption is an issue, I'd keep the line OFF, saving power, and only applying a bit of current to Wake.
  33. #913
    Feb 2010
    I live in the UK
    Hi mackrackit / All
    In Bruce's oringinal code, the rfpic (if no buttons are pressed) goes to SLEEP until a button is pressed then Encodes & Tx's straight away.
    It seemed to me the data Tx is dependant on a button press occuring and staying pressed until the data is Tx'd. If a button is pressed then released the RFEN led flashes but no data is ever sent, hence our delay loop problem, the button is pressed then released by the time the loop has run the button press is history. The the only time data has ever Tx'd is when the button is actually pressed when the code gets to 'Transmit'.
    I added LOW GPIO.4 to simulate a button press (staying pressed) result: The rfpic Tx'd no problem after the delay loop had run.
    We now have a IOC that wakes up from sleep, then runs a delay loop, then Tx's the data. We've cracked it you cry.....hoorah! Well almost, problem is the rfpic locks into Tx mode (GPIO.4 is always low - Button is never released if you like).
    Figure a way of GPIO.4 back to 'normal' and we're there, any thoughts. Bear in mind though that GPIO.4 must be 'low' to make the rfpic Tx.
    Any ideas....?
    Transmit:
    LOW GPIO.4
    Feb 2010
    I live in the UK
    Hi Demon
    I hear what you're saying. By the time this project is finished a lot of changes will have been made to the set-up.
    This is my first excursion into RF, with Tx - Rx programs that Bruce kindly posted up. Right now it's a learning curve for me.
    Feb 2010
    I live in the UK
    I think I've sent everyone on a wild Goose chase (sorry).
    Mackrackit's Tx code was working fine all along.
    I now think It's the Rx program that holds the key. The reason I think this is becasue Bruce's Rx program (as I understand it) looks to reset if no data recieved within 65ms of button press ( that's why the data only ever Tx'd with a button actually pressed). Any timing loop throws out the 65ms data arrival, hence no flahing led.
    I commented out a section of the Rx program and although not working perfectly, the Rx led now flashes after the time delay and data is sent.
    What do we think? Am I on to something here?
    Again apologies for the curved ball.
    Aug 2010
    Maryland, USA
    Well thats good to know, Thanks Dave!! So does that me the Tx side is done? Do we get to see the Rx side to chew on for a bit?
    -Bert
  37. #917
    Feb 2010
    I live in the UK
    Hi Bert
    Well no the Tx side still has work to be done. The delay loop problem has / had to be overcome to get the project code to do what I want it to. The GPIO.3 / 4 pins will need to be set as as Demon posted earlier, namely:
    I'll tidy it up and post it tomorrow. The big thing for me is that Mackrackit agree's I'm on the right track with my thinking regards Rx being the problem not the Tx side.
  38. #918
    But the other code (Bruce's) worked when my mod did not appear to ???
    Yup, we need to see both ends.
    But it does sound like you are on to something....
  39. #919
    Feb 2010
    I live in the UK
    It did / does. Bruce's code for the Tx - Rx on button press works a treat, it never misses a beat. The problem appears when we try and add in a time delay loop.
    Here's Bruce's original Rx code (a button press on the transmitter = immediate led flash on Rx board).
    '*  Name    : rfPIC_RX.BAS                                      *
    '*  Version : 1.0 (Momentary decoder version)                   *
    '*  Notes   : 2-Bit decoder for Microchip RF dev system         *
    '*          : with rfRXD0420 module installed in PICkit 1 board *
    '*  PIC     :  PIC16F684 Originally PIC16F676!!!                                       *
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _PWRTE_ON
        DEFINE NO_CLRWDT 1      ' Watchdog timer is disabled, so we don't need to reset it
        DEFINE INTHAND RESET_VT ' Interrupt on Timer1 overflow to reset outputs in 65.5mS
                                ' if no serial data received in this time period
        SYMBOL  D_IN = PORTC.1  ' data input pin
        SYMBOL  TMR1IF = PIR1.0 ' Timer1 overflow interrupt flag (reset in int handler)
        SYMBOL  TMR1IE = PIE1.0 ' Timer1 interrupt enable bit
        'Variables for saving state in interrupt handler
        wsave   VAR BYTE $5F system    ' Saves W
        ssave   VAR BYTE bank0 system  ' Saves STATUS
        psave   VAR BYTE bank0 system  ' Saves PCLATH
        fsave   VAR BYTE bank0 system  ' Saves FSR
        ' Working variables
        MATCH     VAR BYTE bank0 system ' Match variable
        DAT_OUTB  VAR BYTE  ' Holds decoded data for output
        DAT_IN1   VAR BYTE  ' 1st Data byte
        DAT_IN2   VAR BYTE  ' 2nd Data byte for verify
        CHK_SUM   VAR BYTE  ' Holds checksum received
        CheckSum  VAR BYTE  ' Computed checksum of all bytes received
        ' Constants
        N2400    CON 16780  ' 2400 bps inverted
        N4800    CON 188    ' 4800 bps inverted
         ' hardware init
        PORTA = 0
        TRISA = %00111001   ' RA1 and RA2 are LED outputs
        PORTC = 0           ' Clear outputs on power-up
        TRISC = %00111110   ' RC1 = RF input
        IOC = 0             ' Interrupt on change disabled
        VRCON = 0           ' Comparator Vref disabled
        CMCON0 = 7           ' Disable comparators
        ANSEL = 0           ' disable A/D
        OPTION_REG = 128    ' Pull-ups off
        ' Setup Timer1 for resets after ~65.5mS
        T1CON = %00000000   ' Internal clock, 1:1 prescale, Timer1 off for now
        TMR1L = 0
        TMR1H = 0           ' Timer1 low & high bytes cleared
        TMR1IF = 0          ' Clear Timer1 overflow flag before enabling interrupt
        TMR1IE = 1          ' Enable Timer1 overflow interrupt
        INTCON = %11000000  ' Global & peripheral ints enabled
        MATCH = 0           ' Clear match count
        GOTO    MAIN        ' Jump over int handler
    ASM  ; Timer1 overflow interrupt resets outputs when no valid key press
         ; is detected within ~65mS
    RESET_VT
        movwf  wsave  ; Save W
        swapf  STATUS, W     ; Swap STATUS to W (swap avoids changing STATUS)
        clrf   STATUS  ; Clear STATUS
        movwf  ssave  ; Save swapped STATUS
        movf   PCLATH, W     ; Move PCLATH to W
        movwf  psave  ; Save PCLATH
        movf   FSR, W  ; Move FSR to W
        movwf  fsave         ; Save FSR
        ; Do interrupt stuff here
        bcf    T1CON,TMR1ON  ; Stop Timer1
        clrf   TMR1L         ; Clear low byte
        clrf   TMR1H         ; Clear high byte
        bcf    PIR1,TMR1IF   ; Clear Timer1 interrupt flag bit
        clrf   PORTA         ; Clear outputs on button release
        clrf   MATCH         ; Clear match variable
        ; Restore FSR, PCLATH, STATUS and W registers
        movf    fsave, W  ; retrieve FSR value
        movwf   FSR   ; Restore it to FSR
        movf    psave, W  ; Retrieve PCLATH value
        movwf   PCLATH  ; Restore it to PCLATH
        swapf   ssave, W     ; Get swapped STATUS value (swap to avoid changing STATUS)
        movwf   STATUS  ; Restore it to STATUS
        swapf   wsave, F  ; Swap the stored W value
        swapf   wsave, W  ; Restore it to W (swap to avoid changing STATUS)
        bsf     T1CON,TMR1ON ; Re-enable Timer1 before exiting interrupt handler
        retfie   ; Return from the interrupt
    MAIN:
        ' Fire up Timer1 before entry to serial input routine
        T1CON.0 = 1
        ' at 4MHz Timer1 overflows in 65536 * 1uS (~65.5mS) if no Synch byte
        ' and serial data arrive on time. SERIN2 timeout & label options
        ' are useless with a noisy RF receiver output - as noise continually
        ' resets the timeout period causing it to hang forever.
        ' Wait for Synch byte, then get new inbound data & checksum
        SERIN2 D_IN,N2400,[WAIT(Synch),DAT_IN1,DAT_IN2,CHK_SUM]
        T1CON.0 = 0    ' Stop Timer1 once we've received data
        TMR1L = 0      ' Clear low byte
        TMR1H = 0      ' Clear high byte
        ' / **** Begin data validation **** /
        ' Calculate checksum by adding 2 data bytes together
        CheckSum = DAT_IN1 + DAT_IN2
        ' Test new checksum against one received in CHK_SUM
        IF CheckSum != CHK_SUM THEN MAIN ' Failed checksum, return
        ' Test data bytes for match
        IF (DAT_IN1) != (DAT_IN2) THEN MAIN ' Failed data comparison, return
        MATCH = MATCH + 1        ' We have a match so increment match count
        IF MATCH = 2 THEN DECODE ' Everything matched twice, we're good
        GOTO Main                ' Else do it all over
        ' Everything looking good - so place new data on outputs
    DECODE:
        ' Place decoded values on port pins..
        PORTA = DAT_IN1 & %00000110
        DAT_IN1 = !DAT_IN2  ' Destroy the match
        MATCH = 0
        GOTO MAIN
    And here's the 'chopped down' version which doesn't Rx on every Tx but DOES Rx after the timing loop on the Tx has run.
        ' Working variables
        VISITS    var word  ' Test BYTE with a value of 3 - DT
        X         VAR BYTE  ' Loop counter value Byte - DT
        Total     var byte
        ' Constants
         ' hardware init
        PORTA = 0
        TRISC = %00101110   ' RC1 = RF input
    MAIN:
        SERIN2 D_IN,N2400,[WAIT(Synch),DAT_IN1,DAT_IN2,CHK_SUM,VISITS.HIGHBYTE,VISITS.LOWBYTE]
      '  MATCH = MATCH + 1        ' We have a match so increment match count
       ' IF MATCH = 2 THEN DECODE ' Everything matched twice, we're good
       ' GOTO Main                ' Else do it all over
    DECODE:
        'DAT_IN1 = !DAT_IN2  ' Destroy the match
       ' MATCH = 0
        IF VISITS = 300 THEN  LED
        GOTO MAIN
    lED:
        for X = 1 to 3  'Test=7  or 600
        HIGH PORTA.1
        PAUSE 500
        LOW PORTA.1
        next X
        GOTO MAIN
  40. #920
    I use config fuse WTD_OFF and never had to use this:
    (still looking over rest of code)
