144 LED Games Console Project
Results 1 to 40 of 104
Threaded View
  1. #16
    Default Gerber files and schematic
    Following are links for downloading the latest schematic and PCB Gerber files for the PCB.
    Schematic: http://www.scarydesign.com/144ledgam...dschematic.pdf
    PCB PDF: http://www.scarydesign.com/144ledgame/144ledgame.pdf
    Gerber file (in RAR): http://www.scarydesign.com/144ledgame/144ledgerbers.rar
    The board is 4.5" x 4.75". There are mounting holes on the four corners for a 6-32 screw.
    The Gerber file contains the Gerbers and drill files. You can send this as is to a board house to get boards.
    The leds, transistors, small capacitors and resistors can take either through-hole or SMD components. Resistors and caps are 0805.
    The pushbutton switches are 6mm x 6mm tactile type.
    You can use a three terminal resonator or a crystal and caps; your pick. If you use the HC49U you can lay it down on the board. There is a pad connecting to ground; solder a piece of wire from the metal case to this pad.
    Many input voltage capabilities. No matter what you choose, I'd recommend a 7-9VDC supply; nothing more than 12VDC. Keep in mind that if you use the bridge rectifier input there are 2 diode drops. You can bolt the voltage regulator to the board for a little heatsinking though I don't think it's needed.
    There's a small "proto" area with +5 and ground available.
    Let me know if anything looks squirrely.
    Have fun.
    EDIT: I used "cutePDF" to generate the PDF of the PCB. I don't know why but the pads look a little "odd". They really aren't like that in the Gerbers...
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  3. LCD will not start
  4. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
  5. simple LED Blinking project
    Last Post: - 11th December 2004, 01:25
