Problem Programming 16F870 when adding ON INTERRUPT
Results 1 to 7 of 7
    Jul 2010
    Unhappy Problem Programming 16F870 when adding ON INTERRUPT
    I have a "strange" problem with a 16F870.
    I have a piece of code that gives me an error in the programmer application. But this error only happens if I introduce the line "ON INTERRUPT GOTO ISR". I remove that line and the PIC gets programmed correctly.
    INTCON = %00100000 ' Enable TMR0 interrupts
    OPTION_REG = %00000111 ' Initialise the prescale
    TMR0 = 217 ' Load TMR0 register
    INTCON = %10100000 ' Enable Interrupts
    DISABLE
    ISR:
      TMR0 = 216
      INTCON.2 = 0 ' Re-enable TMR0 interrupts
    RESUME ' Return to main program
    ENABLE
    Any ideas?
    Intcon.5 = 1 'enable tmr0
    Jul 2010
    Unfortunately this didn't do anything
    I just tested this code on a 16F870 and a 16F628A:
    led     var     PORTB.7
            OPTION_REG = $7f        ' Enable PORTB pullups
            On Interrupt Goto myint ' Define interrupt handler
            INTCON = $90            ' Enable INTE interrupt
    loop:   High led                ' Turn LED on
            Goto loop               ' Do it forever
    ' Interrupt handler
            Disable                 ' No interrupts past this point
    myint:  Low led                 ' If we get here, turn LED off
            Pause   500             ' Wait .5 seconds
            INTCON.1 = 0            ' Clear interrupt flag
            Resume                  ' Return to main program
            Enable
    I get the error in the PROGRAMMER in both cases. The error is in the code verification stage.
    Why would the programmer give this type of error, as if the code was not being written properly to the PIC? If I remove the "ON INTERRUPT" line, the code saves perfectly. I have been using this programmer for a while and had no problems until this one.
    Is the PICBASIC compiler inserting code in a non-programable area or something?
    What programmer are you using?
    Jul 2010
    VOLNIA USP 3.0
    I am in contact with the company and sent them the .hex, they will be investigating.
    Jul 2010
    Problem Solved, it was an issue with the programmer. They updated my software (which updated the firmware too), and now it all works.
    Thank you Mackrackit for your responses!
    cmottaa's Avatar
    cmottaa Guest
    Lightbulb Re: Problem Programming 16F870 when adding ON INTERRUPT
    Did u still got the update/firmware file...?
    Or something?
    The company dissappeared and my USP is dropping the same issue...
