Interrupt RPM and Taylors Elapsed time on 18F4620 - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 71 of 71
  1. #41
    If Charles hadn't done it with DT_INTS, I might have been upset (longer).
    But he did ...
    More things to simulate.
    I might have to send Charles a 6-pack too.
    You ain't getting off that easy bud .. you still have to prove me wrong, and show a solution to the problem....)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  3. #43
    Agreed, and accepted.
    But just so I'm clear, what I'm proving wrong is that it's a revision or errata sheet problem with the 18F4620 itself.
    And that using an 18F4431 will solve it?
    In other words, I gotta do it in hardware too?
    You just have to prove that my recommendations throughout this thread (for this specific controller) were wrong, and show your solution to the problem - using the same controller.
    My point thus far has been that this particular controller is doo-doo. Your entry point on this thread stated;
    I think you need to clear the timer sooner.
    -Bruce
    tech at rentron.com
  5. #45
    Feb 2008
    Michigan, USA
    Darrel, help me understand here...
    I thought that Proteus dealt with many versions of compilers except PBP.
    Are you just running the already compiled program and reverse troubleshooting in your head? I imagine that watching the registers would let you know where you are at and if you could transpose between the two, it would work.
    Care to elaborate on how you use it to help you?
    Bo
  6. #46
    I had missed post#22 while working with proteus, but it didn't matter ... it works too.
    So, at the risk of loosing beer ... and buying chips ...
    Other than the problems that were fixed earlier ... CCP1CON missing ... period instead if CCPR1L:H ...
    This is the problem ....
    The 4620's oscillator is running at 20.13 mhz
    If it's a crystal, the caps are wrong or the crystal is off (or a radio crystal).
    If it's a cheap resonator, then it's only to be expected.
    That's my story ... and I'm sticking to it.
    No way to prove it unless Toby checks it.
    If I run the simulator at 20.13mhz, I get the exact same numbers across the board.
    Sep 2005
    Campbell, CA
    I rive in China. The address in my bio is just to confuse people.
    Charles Linquist
  8. #48
    Theoretically I should be able to swap oscillators and the problem will be on the 877A. Give me a bit and I will try that.
    Here is a link to the one I have on the boards.
    http://mouser.com/ProductDetail/Kyoc...XFVfiWpjmqo%3d
  9. #49
    I think Darrel nailed it with the oscillator problem. Nice catch. I just assumed you were
    testing different PICs on the same board.
    -Bruce
    tech at rentron.com
  10. #50
    its the osc. I had no idea there could be that much variance. Can you suggest a better part number?
  11. #51
    Woohoo!
    I can taste it already.
    Quote Originally Posted by Tobias View Post
    The datasheet for that resonator shows that they have other versions of the same thing but with tighter tolerances (down to 0.1%).
    At least it will have the same footprint.
    With 0.1%, at 6000 RPM it will read between 5990-6010. (according to proteus).
    Quote Originally Posted by boroko View Post
    Currently, you can only simulate the .hex files directly in Proteus.
    No single stepping through the program.
    But you can use it as a debugger in MPLAB where you can single step and watch variables in PBP.
    It's too slow for me that way though. It simulates in "Real-Time" when not animating.
    It's like real hardware is sitting in front of you, only you can't create Smoke or Fry your chips.
    I'm getting hooked on it.
    It's just so nice not to have to build a breadboard to test things.
    20 minutes, and you can draw it on the computer.
    Plus, with the Logic Analyzer, O-Scope, I2C debugger etc.
    It saves thousands on test equipment.
    And my cats can't play with the wires.
    Darrel,
    Are you using the free or full version?
    -Bruce
    tech at rentron.com
  15. #55
    Using the Full version.
    The free version doesn't let you draw your own circuits.
    Thanks for the help on getting the RPM working right.
    Next question, when I want to incorporate this into other code how do I keep it from taking up as much time as just measuring the pulse width with Pulsin? I can't have it in the little CaptureLoop routine waiting for the next rpm pulse.
    Looking through the spec sheet on the 4620, I see CCP1IE (PIE1.2). If I enable that bit, will I get an interrupt on each cylinder fire? I know there is a way to start and stop timer1 based on the cylinder firing and not just looping for the cylinder firing.
    Here is what I am working on assuming that is the right path to take. I haven't worked with interrupts much so I am sure I need more work.
    DEFINE OSC 20
    Prefix          con     $FE           ' needed before each command
    LcdCls          CON     $51           ' clear LCD (use PAUSE 5 after)
    CursorPS        con     $45           'Cursor Position
    Capture         VAR     PIR1.2		    ' CCP1 capture flag CCP1IF
    Overflow        VAR     PIR1.0	    	' Timer1 overflow flag TMR1IF:
    RPM             var     word
    period          var     Word
    TotalTime       var     word      'Holds seconds and tics
    Counter         var     word
    Detect          var     bit
    LCD             VAR     PortC.6    'LCD output
    ADCON0 =0       'A/D Off
    ADCON1.3=1      'All AN channels digital
    ADCON1.2=1      '''
    ADCON1.1=1      '''
    ADCON1.0=1      '''
    TRISE.0=1       'EO input
    TRISE.1=1       'E1 input
    CCP1CON = %00000110  ; Capture mode, every rising edge 0101 , Fourth 0110
    T1CON.7=1     'enable timer  16 bit `
    T1CON.6=1     'Timer1 OSC
    T1CON.5=1     '1:4 prescaler
    T1CON.4=0     '1:4 prescaler
    T1CON.3=0     'Timer1 OSC off
    T1CON.2=0     'sychro clock
    T1CON.1=0     'internal clock
    T1CON.0=0     'stop timer
    PIE1.2=1      'Enables the CCP1 interrupt
    pause 10
    SEROUT2 LCD,84, [Prefix, LcdCls]
    Include "modedefs.bas"	' Mode definitions for Serout
    SEROUT2 LCD,84, [Prefix,CursorPS,0,"RPM test"]
    TMR1H = 0    'Clear 8-bit register
    TMR1L = 0    'Clear 8-bit register
    capture = 0  'Clear Timer
    Detect = 0
    ON Interrupt goto Measure_Time
    Loop:
      Counter = Counter + 1
      SEROUT2 LCD,84, [Prefix,CursorPS,0,dec5 Counter]
      SEROUT2 LCD,84, [Prefix,CursorPS,20,"RPM ",dec5 RPM, " ", #Detect]
    goto loop
    Disable
    Measure_Time:
    SEROUT2 LCD,84, [Prefix,CursorPS,40,"Int ",dec5 RPM]
    If Detect = 0  then
      T1CON.0=1
      detect = 1
      capture = 0
    If Detect = 1  then
      T1CON.0=0
      detect = 0
      period.LowByte=CCPR1L
      period.HighByte=CCPR1H
      capture = 0
      TMR1H = 0
      TMR1L = 0
      RPM = 10000
      RPM = RPM * RPM ' 100,000,000
      RPM = DIV32 period ' 100,000,000 / RevCount
      RPM = RPM * 60 ' Per minute
      RPM = DIV32 1600
      RPM = (RPM*5)
    Enable
    [HTML][/HTML]
  17. #57
    May 2007
  18. #58
    Thanks for the link. The thing is though I don't want to go into a loop waiting for the tach pulse. I want to be able to do it by interrupt so I can be doing other things in between pulses and on the pulse go start/stop the timer.
  19. #59
    May 2007
    Look at post #9. This is its main loop:
      ' do other stuff here as required
      IF CF.0 THEN         ' figure out & print result only after last capture
        PW = PW-T1         ' High pulse width = PW-T1
        CF.0 = 0           ' clear flag bit
        HSEROUT [DEC PW,"uS High",13,10]
      GOTO Main
  20. #60
    Thanks, when I insert the RPM part of code I get an error. Except for when I comment out the DIV32.
    ' Measuring signal pulse widths with capture module & interrupt
    ' Procedure for high-going pulse:
    ' 1. Configure CCP to capture on rising edge
    ' 2. Setup Timer1 so it will not overflow during max pulse width time
    ' 3. Enable ccp capture
    ' 4. Once capture flag bit is set, save captured value as T1
    ' 5. Reconfigure CCP to capture on falling edge
    ' 6. On 2nd capture, save 2nd value as PW
    ' 7. Subtract T1 from PW for the pulse width value
    LcdLine1        CON      $00             ' move cursor to line 1
    LcdLine2        con      $40             ' move curson to line 2
    LcdLine3        con      $14             ' move curson to line 3
    lcdLine4        con      $54             ' move curson to line 4
    LcdCol1         con      $00             ' move cursor to column 1
    LcdCol2         con      $07             ' move cursor to column 7
    Backlight       con      $53             ' Backlighting 1-8
    CursorOn        con      $47             'Cursof On
    CursorOff       con      $48             'Cursor Off
      DEFINE OSC 20              ' 4MHz for 1uS resolution TMR1 counts
      DEFINE INTHAND CCP_INT    ' declare high-pri interrupt handler
      Symbol Capture = PIR1.2   ' CCP1 capture flag
      SYMBOL CapIE = PIE1.2     ' CCP1 interrupt enable bit
      SYMBOL CapPriEn = IPR1.2  ' priority enable bit for CCP1 interrupt
      SYMBOL PriEnable = RCON.7 ' set to enable priority levels on interrupts
      T1     VAR WORD BANKA SYSTEM ' 1st capture value
      PW     VAR WORD BANKA SYSTEM ' 2nd capture value & ultimately final pulse width
      CF     VAR BYTE BANKA SYSTEM ' indicates when last capture is ready
      RPM    var word
      Period var word
      CLEAR                ' clear RAM on POR
      TRISC.2 = 1          ' CCP1 input pin (Capture input on 18F242)
      INTCON = 0           ' Interrupts off for now
      GOTO Init            ' jump over interrupt handler
    CCP_INT
      BTFSS CCP1CON,0      ; capture from rising edge?
      BRA Fall             ; no .. goto falling edge
      MOVFF CCPR1L, T1     ; get low capture byte into T1
      MOVFF CCPR1H, T1+1   ; get high capture byte into T1
      BRA IntExit          ; outta here
    Fall
      MOVFF CCPR1L, PW     ; get low capture byte into PW
      MOVFF CCPR1H, PW+1   ; get high capture byte into PW
      BSF CF,0             ; indicate last capture
    IntExit
      BTG CCP1CON,0        ; toggle between rising/falling edge captures
      BCF PIR1,2           ; clear capture interrupt flag bit
      RETFIE FAST          ; return/restore W, STATUS and BSR
    Init: ' initialize a few things first
      CCP1CON = %00000110  ' Capture mode, capture on rising edge
      'T1CON = 0            ' TMR1 prescale=1, clock=Fosc/4, TMR1=off
      TMR1H = 0            ' Clear high byte of TMR1 counter
      TMR1L = 0            ' Clear low byte
      PriEnable = 1        ' enable priority levels on interrupts
      Capture = 0          ' clear capture flag bit
      CapPriEn = 1         ' set CCP1 int to high priority
      CapIE = 1            ' enable the CCP1 capture interrupt
      INTCON = %11000000   ' global + peripheral ints enabled
      T1CON.0 = 1          ' Turn TMR1 on here
        Period = PW
       RPM = 10000
       'RPM = RPM * RPM ' 100,000,000
       'RPM = DIV32 period ' 100,000,000 / RevCount
       'RPM = DIV32 1600
       RPM = (RPM*5)
        SEROUT2 LCD,84, [Prefix,CursorPS,0,#PW]
      GOTO Main
    Change T1 VAR WORD BANKA SYSTEM to something else. My example was a PBP
    re-make from a Microchip app note using T1 as a variable, and didn't use DIV32.
    PBP has an internal variable it uses named T1 for complex math equations. Just changing
    the name of this variable should clear the problem.
    -Bruce
    tech at rentron.com
  22. #62
    May 2008
    Italy
    Bruce, thank you for this information (there is no trace into the PBP manual!)
    There are other reserved words, we should avoid and not mentioned into the PBP manual?
    Al.
  23. #63
    Hi Al,
    PBP declares several internal variables as it needs them. Names are R0 - R8, T0 - T7, FLAGS, GOP, RM1, RM2, RR1, RR2, RS1, RS2, PRODL, TBLPTRU, TBLPTRH, TBLPTRL and perhaps some I've missed. Some get's declared in every program and some only depending on what your PBP code does.
    This, of course, isn't something I've figured out myself - I've simply looked at Darrels Instant Interrupt code - specifically the ReEnterPBP18 file.
    Tobias, The RESERVED words are in the manual and are not to be used, they are on the last couple of pages or so...
    May 2008
    Italy
    Hi Henrik, thank you for your post. "Every day is a good to learn something knew, but again, let me stess my point "NO MENTION IN THE MANUAL" (at least mine) and this is pretty bad.
    What now will make me worring for a while (till I will forget it) is your statement
    "... and perhaps some I've missed". Is there a way to obtain the full list?
    Al.
  26. #66
    Hi Al,
    I don't see anything about the system variables in the manual either but I don't think it's that big of a problem. If you're trying to declare T2 (or whatever) in your program but the compiler also declares T2 as it needs it for its library calls you'll get an error saying Redefinition of VAR - which I guess is the error Tobias got when he was using T1. So, it shouldn't cause any real trouble.
  27. #67
    What happens is something like this;
    Declaring T1 VAR WORD BANKA SYSTEM creates a user VAR T1 without the underscore. Then you can use T1 in your assembler routine without the underscore like in my example.
    T1 VAR BYTE BANKA removing the SYSTEM part would create the user variable with the underscore _T1, which wouldn't clash with the PBP temp system variable T1.
    I.E. the user var would be _T1. PBPs system var would be T1.
    A good rule-of-thumb would be to just never declare a system variable with any PBP system variable name. Totally my fault on this one. I did this for someone that asked me to translate a Microchip Tips & Tricks example to PBP, and just didn't consider T1, like used in the Microchip example.
    Maybe it wouldn't be a bad idea for the PBP manual to include a complete list of all temp system variables?
    Standard PBP system variables are listed in the reserved words section, but none of the temp variables, that may or may not even be used, for heavy number crunching are.
    -Bruce
    tech at rentron.com
  28. #68
    The RPM code works great. I changed a few things around like the scaler configs to work with a V-8. I incorporated it into the other code I have that also uses the elapsed time code. When I compile I got an error centered around DEFINE INTHAND CCP_INT. So I looked in the elapsed-18-t3con.bas file and it has Define INTHAND _ClockCount I did some research on the forums and found I can used INTLHAND. Apparently I am defining two high priority interrupt handlers and that is a no-no. So I changed the line to Define INTLHAND _ClockCount . From what I have learned the LHAnd is another interrupt handler with a lower priority.
    I have changed the Elapsed code to use T3 and also go to the thousandths of a second. It worked fine separately too. The code is on the next post.
    When I start the timer, apparently the code goes into a loop on the elasped time code. If I don't start the timer, the code progresses to the next line of code and beyond. I have tried changing around the INTLHAND and INTHAND but same result.
    Start           var     PortB.0
    OnOff           var     PortB.1    'Input to start timers
    Dig4            Var     PortB.2
    Reset           var     PortB.3
    SOR             VAR     PortC.7    'Shift Over-Ride
    Dig1            Var     PortC.0
    Dig2            var     PortA.0
    Dig3            var     PortA.1
    Up1             var     PortA.3    'Up button to change seconds
    Down1           var     PortA.2    'Down button to change seconds.
    Up001           var     PortE.0    'Up button to change tenths of second.
    Down001         var     PortE.1    'Down button to change tenths of second.
    Up01            var     PortA.4    'Up button to change hundredths of a second
    Down01          var     PortA.5    'Down button to change hundredths of a second
    Tool            var     PortB.4    'Button to change to diffent menu
    UpStage         var     PortD.0    'Button to change stages
    DownStage       var     PortC.3    'Button to change stages
    RPMInput        var     PortC.2
    Gate1           Var     PortC.1
    Gate2           var     PortD.1
    Gate3           var     PortD.2
    Gate4           var     PortD.3
    Gate5           var     PortD.6
    Gate6           var     PortD.7
    Gate7           var     PortD.5
    Gate8           var     PortD.4
    StageCounter    var     byte
    OnOffType       var     Bit            'Toggles between On/Off part of a Stage
    ETorRPM         var     Bit
    EditStage       var     byte
    Active          var     bit
    TS     VAR WORD BANKA SYSTEM ' 1st capture value
    RPM    var word BANKA SYSTEM
    Period var word BANKA SYSTEM
    define CODE_SIZE 32
    define osc 20
    Capture_Loop = 0
    INTCON2.7 = 0 'Pull Ups enabled
    ADCON0 =0
    ADCON1.3=1
    ADCON1.2=1
    ADCON1.1=1
    ADCON1.0=1
    TRISE.0=1
    TRISE.1=1
    '---------Display Start-Up Info-------
    Include "Elapsed-18-T3CON.bas"
    Pause 200
    gosub ClearScreen
    GOTO Init
    CCP_INT
      MOVFF CCPR1L, TS    ; get low capture byte into T1
      MOVFF CCPR1H, TS+1   ; get high capture byte into T1
    Fall
    IntExit
    Gosub ResetTime
    '---------Pre Run Routine------------------------------
    PreRun:
      Repeat
      Serout2 LCD, 84, [Prefix,CursorPS,64,"Ready ", DEC5 RPM]
        gosub Tach
        Gosub Shift
       Until Start = 0 and OnOff = 0
      '-----------Run Routine--------------------------
      While Start = 0 and OnOff = 0
       PrvOnOffType=0
      wend
      Active = 1
      Run: ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
      While Start=0 and OnOff = 1 '''''!!!!!!!!!!!!!!!
        If Active = 1 then
          Gosub StartTimer
        Serout2 LCD,84,[Prefix,CursorPS,71,"test "]', #Stage3TOn]
    ''''Code doesn't make it this far. If I comment out 'gosub startimer' it makes it to this line.
        Gosub Calc_TotalTime
    Wend
        gosub Tach
  29. #69
    Here is the elasped timer code I modified to use T3 and go to the thousandths. Also I have the interrupt set up as INTLHAND
    '*  Name    : ELAPSED.PBP                                       *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2003                                *
    '*  Date    : 12/16/2003                                        *
    disable debug
    Define  INTLHAND _ClockCount    ' Tell PBP Where the code starts on an interrupt
    Include "ASM_INTS-18.bas"         ' ASM Interrupt Stubs
    Ticks    var Word   ' 1/1000th of a second
    Seconds  var byte
    Minutes  var byte
    Hours    var byte
    Days     var word
    R0save   var word
    R1save   var word
    R4save   var word
    SecondsChanged   var bit
    MinutesChanged   var bit
    HoursChanged     var bit
    DaysChanged      var bit
    SecondsChanged = 1
    MinutesChanged = 1
    Goto OverElapsed
    Asm
      IF OSC == 4                       ; Constants for 100hz interrupt from Timer1
    TimerConst = 0D8F7h                 ; Executed at compile time only
      EndIF
      If OSC == 8
    TimerConst = 0B1E7h
      EndIF
      If OSC == 10
    TimerConst = 09E5Fh
      EndIF
      If OSC == 20
    TimerConst = 0EC80h
      EndIF
      If OSC == 40
    TimerConst = 03CB7h
      EndIF
    ; -----------------  ADD TimerConst to TMR1H:TMR1L
    ADD2_TIMER   macro
        CHK?RP  T3CON
        BCF     T3CON,TMR3ON           ; Turn off timer
        MOVLW   LOW(TimerConst)        ;  1
        ADDWF   TMR3L,F                ;  1    ; reload timer with correct value
        BTFSC   STATUS,C               ;  1/2
        INCF    TMR3H,F                ;  1
        MOVLW   HIGH(TimerConst)       ;  1
        ADDWF   TMR3H,F                ;  1
    ; -----------------  ADD TimerConst to TMR1H:TMR1L and restart TIMER1
    RELOAD_TIMER  macro
        ADD2_TIMER
        BSF     T3CON,TMR3ON           ;  1    ; Turn TIMER1 back on
        CHK?RP  PIR2
        bcf     PIR2, TMR3IF           ; Clear Timer1 Interrupt Flag
    ; -----------------  Load TimerConst into TMR1H:TMR1L
    LOAD_TIMER  macro
    EndAsm
        T3CON.0 = 0                    ; Turn OFF Timer1
        TMR3L = 0
        TMR3H = 0
    Asm
        ADD2_TIMER
    EndAsm
    ' ------[ This is the Interrupt Handler ]---------------------------------------
    ClockCount:   ' Note: this is being handled as an ASM interrupt
    @ INT_START
    @ RELOAD_TIMER                    ; Reload TIMER1
      R0save = R0                     ; Save 2 PBP system vars that are used during
      R1save = R1                     ; the interrupt
      R4save = R4
        Ticks = Ticks + 1
        if Ticks = 1000 then
           Ticks = Ticks-1000
           Seconds = Seconds + 1
           SecondsChanged = 1
           if Seconds = 60 then
              Minutes = Minutes + 1
              MinutesChanged = 1
              Seconds = 0
           if Minutes = 60 then
              Hours = Hours + 1
              HoursChanged = 1
              Minutes = 0
           if Hours = 24 then
              Days = Days + 1
              DaysChanged = 1
              Hours = 0
      R4 = R4save                     ; Restore the PBP system vars
      R1 = R1save
      R0 = R0save
    @ INT_RETURN                      ; Restore context and return from interrupt
    '-----====[ END OF TMR1 Interrupt Handler ]====---------------------------------
    StartTimer:
        T3CON.1 = 0                   ; (TMR1CS) Select FOSC/4 Clock Source
        T3CON.3 = 0                   ; (T1OSCEN) Disable External Oscillator
        PIR2.1  = 0                   ; (TMR1IF) Clear Timer1 Interrupt Flag
        PIE2.1  = 1                   ; (TMR1IE) Enable TMR1 overflow interrupt
        INTCON.6 = 1                  ; (PEIE) Enable peripheral interrupts
        INTCON.7 = 1                  ; (GIE) Enable global interrupts
        T3CON.0 = 1                   ; (TMR1ON) Start TIMER1
    @ if OSC == 40
        T3CON.5 = 0                   ; Prescaler = 1:2
        T3CON.4 = 1
    @ endif
    StopTimer:
    ResetTime:
        R0save = T3CON.0              ; Save TMR1ON bit
        TMR3L = 0
        TMR3H = 0
    @   LOAD_TIMER                    ; Load TimerConst
        T3CON.0 = R0save              ; Restore TMR1ON bit
        Ticks = 0
        Seconds = 0
        Minutes = 0
        Hours = 0
        Days = 0
        SecondsChanged = 1
    OverElapsed:
    enable debug
  30. #70
    This appears to be working correctly. Are there any problems going this route?
    Of course this isn't all the code, just the part that is relevant.
    DEFINE INTHAND Direction
    Direction
      If PIR1.2 = 1 then
        goto RPMASM
      If PIR2.1 = 1 then
        goto ClockCount
    RPMASM:
    CCP_INT
    Fall
    IntExit
    @ INT_START
      R4save = R4
        Ticks = Ticks + 1
           Ticks = Ticks-1000
           SecondsChanged = 1
              MinutesChanged = 1
              Seconds = 0
              Hours = Hours + 1
              HoursChanged = 1
              Minutes = 0
           if Hours = 24 then
              Days = Days + 1
              DaysChanged = 1
              Hours = 0
      R1 = R1save
      R0 = R0save
  31. #71
    You don't need the bit tests in Direction since you have CCP_INT (or Direction) set as a high-priority interrupt, and you have ClockCount set as a low-priority interrupt.
    Direction will be jumped to automatically when the CCP interrupt fires. ClockCount will be jumped to automatically when the TMR3 interrupt fires. Note that your low-priority interrupt can be interrupted by the high-priority one.
    -Bruce
    tech at rentron.com
