how synchronize with rfid reader
Results 1 to 10 of 10
    Apr 2009
    Default how synchronize with rfid reader
    i have rfid reader module sending serial data 8n1 9600 baud at TTL format
    and transmits 7 byte with one second cycle
    i used serin2 and serin commads and received data and displayed them on display without synchronization data is changing and floats even it reads same tag
    at proteus a make coomunication by simulating rfid reader as a pic628 sending 7 byte data like reader and
    i will use hserin command
    how can i synchronize pic877a with rfid reader which command must be used
    at this kind of communication
    I must be silly, sort of, but I read your post again and again, I try to understand, I just can't
    We will need more information, Is this more a ISIS problem or Code problem here?
    Apr 2009
    not isis problem
    it is code problem
    how can i communicate pic16f877 with rfid reader module which sending data 8n1 9600 baud at ttl format
    which command of picbasic must be used to receive this kind of data ?
    For the receiver
    SERIN/DEBUGIN/SERIN2/HSERIN would work. Also possible and recommended to use USART interrupt to allow to do something else while there's no incoming data.
    For the transmitter
    SEROUT/DEBUG/SEROUT2/HSEROUT
    Apr 2009
    i can receive data and show them on display
    but i cant receive correct data
    (i must receive $00,$05,$01,$1A,$01,$2F,$55)
    and codes on the display changing and floating even i read same rfid tag
    i know these serial commands i use them but i dont know how to organize them to receive bytes 8n1 9600 at ttl format
    HSERIN [HEX2 VAR1, HEX2 VAR2, and so on]
    Apr 2009
    i cant try it with rfid reader may be tomorrow
    but trying it with isis
    as transmitter i use 628
    as receiver i use 877a
    can not receive with hserin and hserout
    i write define s from the help of mcs
    i can see the bilinks of sending data on isis but they are yellow
    bu no received data on display
    post your codes, Include your config fuses, and a screenshot of your schematic here, we will have a look at this.
    Apr 2009
    this is my code i receive data but these are not the data i must receive
    i receive wrong bytes
    at the help of picbasic rcsta is90h
    at he data sheet of 16f877a address of rcsta is 18h
    i made it 18h i receive no data
    please help me
    [SIZE="5"]
    INCLUDE "modedefs.bas"
    PORTC=0
    PORTB=0
    PORTD=0
    TRISC=%11111111
    TRISB=%00000000
    TRISD=%00000000
    @ DEVICE pic16F877A
    @ DEVICE pic16F877A , WDT_on
    @ DEVICE pic16F877A , PWRT_ON
    @ DEVICE pic16F877A , PROTECT_OFF
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 25
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_RWREG PORTB
    DEFINE LC_RWBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    A1 VAR BYTE
    RTAG
    LCDOUT $FE,$80,"DIGITAL SIGN"
    HSERIN 1000,JMP,[A1]
    JMP
    LCDOUT $FE,$C0,"TAGID=",hex2 A1
    GOTO RTAG
    /SIZE]
    Dec 2009
    INCLUDE "MODEDEFS.BAS"
    '***********************DEFINITIONS*************** ************************
    DEFINE Osc 4
    '***********************SERIAL COMM DEFINITION**********************
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 19200
    DEFINE LCD_DREG PORTb
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTb
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTb
    DEFINE LCD_EBIT 3
    cmcon=7
    trisb=%00000010
    trisa=%00000001
    a var word
    b var word
    c var word
    d var word
    e var word
    ANAPROGRAM:
    hserin [hex2 a,hex2 b,hex2 c,hex2 d,hex2 e]
    pause 50
    LCDOut $fe, 1,hex2 a,hex2 b,hex2 c,hex2 d,hex2 e
    pause 10
    goto anaprogram
  1. Parallax RFID Reader code example
    By dan-tron in forum Code Examples
    Last Post: - 19th April 2013, 22:16
  2. Replies: 3
    Last Post: - 12th March 2008, 05:33
  3. parallax rfid reader module interface with PC
    By jonil22 in forum Off Topic
    Last Post: - 3rd February 2008, 06:54
  4. Parallx rfid reader module interface with PC
    By jonil22 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 08:50
  5. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
